Old Mar 16, 2011, 10:46 PM
MØTT is offline
Find More Posts by MØTT
Brasil, São Paulo, São Paulo
Joined Sep 2010
Hello Guys.
Im with a doubt.
I saw some people who used the sky surfer without ailerons for beginner pilots.
He gets a good flight without ailerons?
MØTT is offline Find More Posts by MØTT
Old Mar 16, 2011, 11:01 PM
FredS is offline
Find More Posts by FredS
Not Again !!
FredS's Avatar
Texas
Joined Dec 2006
Very good write up Prof100.. Question though you say can not use internal BEC over 4S ?? ..........................
FredS is offline Find More Posts by FredS
Old Mar 16, 2011, 11:06 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
You can use a switchmode internal BEC ESC with a 4S. Castle (the gold standard) and Hobbywing make them.
Prof100 is online now Find More Posts by Prof100
Old Mar 17, 2011, 04:09 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Am I missing something?
I may be getting in this late. Are you saying that he can't use a linear mode ESC with a 4S (LiPo's assumed)?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 17, 2011, 06:10 AM
Prof100's Avatar
Joined Jul 2007
AJ
AJ,
The linear BEC creates too much heat when when stepping down the voltage from a 4 cell.
Bill
Old Mar 17, 2011, 08:20 AM
FredS is offline
Not Again !!
FredS's Avatar
Texas
Joined Dec 2006
Hmm ? I am flying a plane with 6S Ice 100 and using its BEC for the radio is this wrong ?
Turnigy 4250 650 kv 12x8 apc 1700w @ 65A . I have a castle BEC should I hook it up ?
Sorry for being off topic ..
Old Mar 17, 2011, 08:32 AM
studawg66 is offline
Find More Posts by studawg66
Alabama
Joined Sep 2010
I've also seen some internal SBEC ESC units from Mystery and some identical ones rebranded as Hextronik or HobbyKing, both on HobbyKing's website. I think their first one is a 40A and not sure how many others are available.
studawg66 is offline Find More Posts by studawg66
Old Mar 17, 2011, 09:53 AM
Prof100's Avatar
Joined Jul 2007
The Castle has a switchmode BEC but I don't know what Castle recommends in terms of running it on 6S pack. It all depends on the rating of the BEC. I run a Hobbywing ESC with internal switchmode BEC on a 5S powered Habu. It works fine but does need plenty of air for cooling.
Go to Dimension Engineering and look up their FAQs. They explain the differences in types of BECs quite well.
Old Mar 17, 2011, 11:24 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I want to buy a vowel.
AJ,
The linear BEC creates too much when when stepping down the voltage from a 4 cell.
Bill
creates too much ?????. Heat?
AJ
Old Mar 17, 2011, 11:27 AM
Prof100's Avatar
Joined Jul 2007
AJ
Ooops, speed typing. I usually just leave out the articles.
Old Mar 17, 2011, 11:49 AM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
Tail Heavy? try a 2650mAh battery
Originally Posted by mastmalang70 View Post
have a question , my SS is tail heavy , what is the best way , just to give down trim ,so it fly level or to add weight to nose ??????
battery 220mah 3s ,pushed all the way front ,still tail heavy
what is the easy way to balance the airplane ,is there any DIY balance to do so???????
thanks
Im using telebee gyros for rudder and elevator ,works good
I assume you are meant to say you are using a 2200mAh battery (instead of 220mAh) pushed all the way forward. Instead of adding dead weight to the front to balance it, you can add a heavier battery. I added a 2650mAh 3S on my V1 SkyS. It's all the way forward and it balances better than a Turnigy 2200mAh 3S all the way forward. This won't work for everyone, but if you are having tail heavy problems with a 2200 battery all the way forward, than this can help. BTW, the CG that works on my plane is around 60mm.
Here is the 2650mAh battery I use:
http://www.hobbyking.com/hobbyking/s...dProduct=16687
mike_m2 is offline Find More Posts by mike_m2
Old Mar 17, 2011, 01:29 PM
D0Z3R is offline
Find More Posts by D0Z3R
D0Z3R's Avatar
Columbus, GA
Joined Oct 2010
Got a questions guys. I'm using the TGS 6x4e prop. I'm getting some vibration that's making flight videos look horrible.
Any suggestions on balancing the prop or is their another prop that you guys recommend that balances better?
D0Z3R is offline Find More Posts by D0Z3R
Old Mar 17, 2011, 01:35 PM
D0Z3R is offline
D0Z3R's Avatar
Columbus, GA
Joined Oct 2010
Hmm im flying my SkyS with just a 3c 1300 mah and it's balanced fine. But I always have the keychain camera attached. Im wondering why it's so tail heavy with the 2200mah installed...
Old Mar 17, 2011, 01:39 PM
FredS is offline
Not Again !!
FredS's Avatar
Texas
Joined Dec 2006
Thanks Prof100..
Old Mar 17, 2011, 01:53 PM
MØTT is offline
Joined Sep 2010
Hello Guys.
Im with a doubt.
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
