Old May 20, 2010, 07:51 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by antennahead View Post
If it's not on video. it didn't happen speedygene
No vid....only this.
2500GENE is offline Find More Posts by 2500GENE
Old May 20, 2010, 07:59 PM
Saralyn C. is offline
Find More Posts by Saralyn C.
BH CSR
Saralyn C.'s Avatar
Joined Mar 2010
Nice pic!
Saralyn C. is offline Find More Posts by Saralyn C.
Old May 20, 2010, 08:01 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Originally Posted by ajbaker View Post
Yeah, I have that motor on one of my EZ*'s. It works well. I would really like your opinion on the following tests:
1. Have you tried to do a no-power outside loop with your SkyS (i.e. dive to high enough speed and loop it)? It is easy for me in the SkyS and I cannot get the EZ* to do it.
2. After flying both, do you see/feel any differences in how they fly?
3. Have you tried comparing them with the exact motor, ESC, LiPo in both. I haven't. But, IMHO, they seem to fly nearly exactly the same (with ailerons disabled on the Skys). I say nearly because I think the glide on the SkyS is slightly better.
4. Have you tried sustained inverted flying? IMO they are identical in this regard.
5. I still have the stock motor on my original RR SkyS (remember.....I ordered an ARF and got an RR-Lucky I guess). In your opinion, what motor would I use from the following for an equivalent motor or slightly more power)?
HK
2409-12
TR28-26 1650 (the one above)
2835-2200 or 2700 (a couple of our favorites)
RCTimer:
2826-6
2212-6
2208-12
I will hope to end up trying all of them if possible. But, I would like to know what you think?
Oh, to be fair, I should probably make both planes weigh exactly the same to do a good flight comparison. Right now they weigh:
SkyS - 20.3 oz.
EZ* - 23.9oz.
AJ
That's quite a list. It will be a while for me to have time to get to all that.
Got too many irons in the fire right now and not getting anything completed.
Besides, I count on you for motor data.
Q
Old May 20, 2010, 08:13 PM
antennahead is offline
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
after a few more flights, and others experience with flexing/breaking wing spars, and my own obsevations with wing flex at higher throttle levels, I think I'm going to add some flat carbon strips into the wings to stiffen them up a bit. other than that, I have been really enjoying flying my skys. she just keeps floating and floating.
antennahead is offline Find More Posts by antennahead
Old May 20, 2010, 08:37 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Funny you should say that. I'm sitting here messing with my wings and started measuring out for some CF ribbon I have.
Also check your spar covers. Mine are only glued on one long side and not the other. You can bend it some and open the gap. That needs some glue attention also.
Q
Old May 20, 2010, 08:52 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Watt meter
Just got in the Turnigy watt meter and hooked it up to the SkyS.
Batteries Twin 2200mah 3S 20c Flightmax
Stock brushless motor
Stock ESC
TGS 6x4E prop
WOT= 14 amps 160 watts
Am I pushing the stock ESC too hard?
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old May 20, 2010, 09:01 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Stock ESC
Jim
Nope, stock esc is listed as a 20 amp.
The only problem that esc may have on this plane is the BEC portion which powers the 4 servos and rx.
Old May 21, 2010, 01:04 AM
Joined May 2007
Q
thanks for the tip!! I never really took a close look at them.
Old May 21, 2010, 04:07 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
ESC Mod
The ESC in this plane runs too hot IMO. So, I moved it to the outside of the plane. On my next arf, I will probably run it on top of the plane in a nicely cut pocket for it. For this plane, it was the quickest way to do it. I will add this post to Page #1 also. If someone else does it another way, I will add theirs, too.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 21, 2010, 04:41 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
nice and quick mod Thumbs UP!
pavcon is offline Find More Posts by pavcon
Old May 21, 2010, 05:27 PM
flyvertigo
Orlando FL
Joined Aug 2009
AJ
I have to agree...way too hot. An idea is to carve in air intakes and exhaust ports.
I think I saw RCpowers do that.
Jim
Old May 21, 2010, 05:47 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Cooling the ESC
Jim
Yes. I think so. I did it too, on one of my EZ*'s. Actually, it would work equally as well on a SkyS. I will probably use this on one of my other SkyS ARF's.
AJ
Old May 21, 2010, 05:50 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thanks for the kind words.
AJ
Old May 21, 2010, 06:36 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
AJ
On my Wild Hawk I put it on the side for cooling and simpler to swap motors.
Old May 21, 2010, 06:38 PM
pavcon is offline
Joined Jan 2010
and that's what I call creativity..
well..
When i get mine when the new shipment arrrives I'm gonna put the ESC close to the hatch.. I intent to cut a hole on the hatch and two holes one on each side at the back..
but the ESC I got already got some cooling mesaures and I stressed it at 25amps+ while it's just 18amps. it holds well with some good aircoolling .. I just can't wait for the arf version..
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
