Agreed. I experienced firist by adding lights, flaps, etc., until the nimble Skysurfer turned into a 32 oz. porker. Bill |
Model types
AJ |
Joined Apr 2010
Haven't put the last "corsets" or fuselage carbon tubes in yet, but it weights 22 oz all up right now. It will gain two or three ounces, no doubt, but it still has way to much power for me as a pretty basic beginner. I have to launch at 1/2 to 2/3 throttle or she zips right up into a stall; I'm getting pretty good at recovery!
Clay |
Joined Apr 2010
Clay |
Parma, Ohio
Joined May 2010
prof100
What did you use to glue the CF rod to the rear bottom of the fuse? I want to try to keep the fuse able to separate if necessary. I think it was Gene (or you) who is a big advocate of Goop for the fuse so it will separate and thats what I used, but I don't want to CA it in if I can help it.
Ron |
On a Skysurfer 1 with the servo control rods on the outside you can use CA on the bottom with the CF tube reinforcement tube because you can still part the motor area to remove and replace the motor. If it is a Skysurfer 2 (inboard servos) then use the goop because you may need access to the inside of the fuselage. Bill |
Parma, Ohio
Joined May 2010
Ron |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
