Old May 19, 2010, 05:54 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I got more than 20 minute flights with the GH combo and a 2200lipo
never managed to drain it it's just too long..
pavcon is offline Find More Posts by pavcon
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by antennahead View Post
I wouldn't call flying in straight lines "crazy maneuvers" there geneius.
Gotta get you back for calling me antennaears...........
How about if it's like 80mph, Antennalips?
2500GENE is offline Find More Posts by 2500GENE
Old May 19, 2010, 06:13 PM
iheartrc is offline
Find More Posts by iheartrc
pt st lucie
Joined Apr 2010
Just wanted to give ya'll an update! I received my SS today and everything looks good! Nothing is missing or damaged as expected. Now it's time for me to get to work so I can get to playin'! I'll let you know how it goes!
iheartrc is offline Find More Posts by iheartrc
Old May 19, 2010, 07:57 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Originally Posted by jpgcag View Post
I just had the same thing happen to me today except it was three gentle loops at altitude. The first loop was fine, the second I noticed that the wings looked a tad folded, and the third was like a dog's ears out the car window. They were just about touching. I chopped power and everything went sorta back in place. I finished my 10 minute flight and after I landed I noticed the wings were loose. I pulled them apart enough to see that the spar had spilt. I think I'm going to go the Gene route and put in an 8mm carbon rod.
Bummer only three flights on it!
Jack
Jack,
I only had about 6 flights on mine.
The instructions do say to glue them in.
I prefer not to glue mine in at this time so I will be looking at putting a bigger rod in mine.
Keep us posted on the process you use to open the tunnel to 8mm.
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old May 19, 2010, 07:59 PM
flyvertigo
Orlando FL
Joined Aug 2009
Originally Posted by 2500GENE View Post
.240 is still 1/4 inch or 6mm. I'd use a 8mm solid like the EZ Star. I haven't broken that yet with some crazy maneuvers....yet.
Got any ideas on how to open the tunnel to 8mm without messing up the plane too much?
Jim
Old May 19, 2010, 08:18 PM
NoM'rcrashPlease is offline
Find More Posts by NoM'rcrashPlease
"Walk of shame" Master!!!
NoM'rcrashPlease's Avatar
West Chicago Il
Joined Jul 2004
I meant to say that the "hobbyking" motor was on backorder, but it seems like I will go with the grayson hobby, will post as soon as I get it...thanx guys
Vic.
NoM'rcrashPlease is offline Find More Posts by NoM'rcrashPlease
Old May 19, 2010, 10:23 PM
West Chicago Il
Joined Jul 2004
Just order the Micro jet motor V3 from grayson hobby.........can't wait
Old May 20, 2010, 02:33 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Did you get the RTF? With the BL upgrade? If you got the RTF, see if you can figure out a way to take out the washers (6) glued in the front without cutting a hole in the bottom of the fuselage. What I thought might work is putting a short length of .078 (or so) piano wire through the nose of the plane and tap them out. The glue they used did not stick very good in mine. I wish I would have tried this method. But, if you do come up with some way to remove them (with a tool of some kind or ????) please let us know. It just seems to me that there should be an easier way. The cut in the bottom of the fuse repairs easily and you can't even tell where it was cut. But, I am hoping for a better way for everyone else.
AJ
P.S. Any oil coming your way via the loop current?
ajbaker is offline Find More Posts by ajbaker
Old May 20, 2010, 02:55 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Couple of questions
That's a nice motor but use a 6x4E not a 7". It'll have plenty of power.
Aj's motor is nice also with the lower kv and your 1800 battery. More efficient.
I also use this
http://www.hobbycity.com/hobbycity/s...idProduct=5655
on a wild hawk. Good thrust and long flights.
Q
Yeah, I have that motor on one of my EZ*'s. It works well. I would really like your opinion on the following tests:
1. Have you tried to do a no-power outside loop with your SkyS (i.e. dive to high enough speed and loop it)? It is easy for me in the SkyS and I cannot get the EZ* to do it.
2. After flying both, do you see/feel any differences in how they fly?
3. Have you tried comparing them with the exact motor, ESC, LiPo in both. I haven't. But, IMHO, they seem to fly nearly exactly the same (with ailerons disabled on the Skys). I say nearly because I think the glide on the SkyS is slightly better.
4. Have you tried sustained inverted flying? IMO they are identical in this regard.
5. I still have the stock motor on my original RR SkyS (remember.....I ordered an ARF and got an RR-Lucky I guess). In your opinion, what motor would I use from the following for an equivalent motor or slightly more power)?
HK
2409-12
TR28-26 1650 (the one above)
2835-2200 or 2700 (a couple of our favorites)
RCTimer:
2826-6
2212-6
2208-12
I will hope to end up trying all of them if possible. But, I would like to know what you think?
Oh, to be fair, I should probably make both planes weigh exactly the same to do a good flight comparison. Right now they weigh:
SkyS - 20.3 oz.
EZ* - 23.9oz.
AJ
Old May 20, 2010, 04:52 PM
flyvertigo
Orlando FL
Joined Aug 2009
Which transmitter do you have?
My coworker and I bought the RTF brushless.
He got his a week before me.
We had no problems putting his together.
Mine had a different transmitter and receiver.
His was already bound.
Which one do you have?
Old May 20, 2010, 05:13 PM
flyvertigo
Orlando FL
Joined Aug 2009
AJ
AJ
I think I figured a way to remove the washers without cutting into the fuse.
Run a wire or string around the washers through the cockpit. Mix up a batch of foam soup (heat up a big pot of water).
Pour some hot water into the nose of the plane while keeping a constant pull on the washers.
As soon as the hot glue melts the washers will come right out.
The hot water doesn't harm the foam much. a little bubbling of the the foam on the inside won't be noticed.
I found out the glue melts when I was doing a little nose massage trying to stretch it back out
Jim
Old May 20, 2010, 06:17 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by flyvertigo View Post
AJ
Jim
Pure genius. Well done. Thank you. I hope many others benefit from your suggestion, too.
AJ
Old May 20, 2010, 06:19 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I don't think you are asking me. I bought 2-arf's (one of them was an RR) and parts for a 3rd (no wings though).
AJ
Old May 20, 2010, 07:37 PM
antennahead is offline
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
If it's not on video. it didn't happen speedygene
antennahead is offline Find More Posts by antennahead
Old May 20, 2010, 07:47 PM
flyvertigo
Orlando FL
Joined Aug 2009
AJ
Ah shucks
I think its more luck than anything. The harder I work the luckier I get.
Jim
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
