Old Jan 01, 2011, 06:10 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by garymcc View Post
One more question on the spar mod: Is the weak spar issue across the board with respect to vendors? I.e. are all SkyS, regardless of where purchased, equipped with weak spars?
It's just a design flaw. Maybe, if a better quality of CF was used it may have been a non-issue. The simplest solution would be been to design it with a larger diameter tube and a thicker wall tube.
Prof100 is offline Find More Posts by Prof100
Old Jan 01, 2011, 09:26 PM
Commander Crash is offline
Find More Posts by Commander Crash
San Jose,California
Joined Nov 2010
battery
thank you for the info about the battery that helps me understand it alot better.My sky surfer does come with the brushless motor. the 30 amp esc is just something that i have extra so i thought i would use it. I am currently using 1300 batteries,they work pretty good.
Commander Crash is offline Find More Posts by Commander Crash
Old Jan 01, 2011, 11:47 PM
ChanceCarroll is offline
Find More Posts by ChanceCarroll
wait what goes here.....
USA, NC, Brunswick
Joined Dec 2010
So how important is the canopy to flight characteristics? I lost mine over a swamp
Also, I'm having serious fun and have yet to hit anything but the ground, although dodging a tree line caused me to nose in earlier; it hit hard enough to hear the thump 400ft away so it's off to glue it back together...
Thankfully my more recent crashes have been because I was flying when I shouldn't have and not complete of skill! I'm trying to make the most use of my days off....
ChanceCarroll is offline Find More Posts by ChanceCarroll
Old Jan 01, 2011, 11:53 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
The FPV guys fly with a friggin camera in the bay. It will fly fine without it. I think BH sells spares, just be patient. Their parts dept. is slow to ship. I think they batch and ship everything at the end of the week.
Old Jan 02, 2011, 02:27 AM
Weekend Flyer is offline
Find More Posts by Weekend Flyer
i Like RC
Weekend Flyer's Avatar
Manitoba, Canada
Joined Oct 2010
Servo Replacement and Motor Mount
I received my brushless SS from BH. I'm a newbie to RC Planes so some help from the Pros out there would be appreciated.
One of my aileron servos continuously makes noise when I plug in the battery. I don't think I trust it. I'm thinking of replacing all 4 servos with some SG90 or MG90 that I found on eBay. I also found some MG90S servos but I'm not sure how they differ from MG90. Any suggestions what servos I should buy? I don't need top of the line but I want something that works and fits into the SS easily.
The ailerons are very stiff. I have worked them up and down by hand but I still think they are too stiff to fly the plane properly. Do most people find it necessary to re-hinge them with tape or new hinges or am I being overly concerned?
I also split the fuselage in half and took out the washers. Now I'm thinking of taking out the motor and making a universal motor mount as shown on one of the posts using some tubing. It would be great to be able to swap motors later on without having to open the fuse again. Do most people do this or do you just split the fuse open whenever you need to replace the motor? I think the hardest part of this modification is removing the motor without breaking the foam. The glue is very strong and there is lots of it. Any suggestions how to remove the motor? It's glued in there really good.
Should I use Gorilla glue to put the fuse back together or is there something better?
Any suggestions from the pros would be greatly appreciated.
Weekend Flyer is offline Find More Posts by Weekend Flyer
Old Jan 02, 2011, 09:18 AM
garymcc is offline
Find More Posts by garymcc
West Texas USA
Joined Mar 2008
Aileron replacement.
On these park flyers I have successfully used the following servos:
Tower SG90, HXT900, Turnigy TGY-1800A. All are 9g servos.
I exercised the ailerons by hand before installing the servos. Mine work fine, so far, with the stock hinges.
I assembled my SkyS v2 with medium CA. If I ever need to separate the fuselage halves this may be a mistake. If you plan on separating the fuselage halves later I don't know what to recommend.
garymcc is offline Find More Posts by garymcc
Old Jan 02, 2011, 10:08 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
As Gary said:
1. Any 9 gram servo will work. HXT 900 from Hobby city are an excellent value.
2. Excercise the ailerons with the linkages off. If still not happy, cut and re-hinge with packaging tape such as 3M Storage tape.
3. Separate the fuselage with a simple kitchen knife (non serrated) should be your goal. A glue that will separate the two halves is what you want (see item 4.)
4. Re-glue the fuselage with Plumbers Goop. It can be separated with kitchen knife with minimal cohesive failure of the foam.
Old Jan 02, 2011, 06:47 PM
USA, NC, Brunswick
Joined Dec 2010
lol I came so close to posting about my motor turning the wrong way before I thought to check to if I accidentally bought a reverse rotation prop! doh!
I 'm exited about the increased thrust of the APC 6x4, just wished it went the right way sigh, back to the hobby shop!
On another note, if I could replace any two control horns, which ones should it be? It seems to me the ailerons have the most play, but I wonder anyone has had specific problems with other horns first?
Chance
Old Jan 02, 2011, 06:58 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Chance
Did you get a APC 6x4E or APC 6x4EP?
If you have a E prop the motor should turn clockwise when viewed from the rear.
If you have a EP prop then the motor should turn counter clockwise as viewed from the rear.
Convex side of prop goes to the front.
To reverse a brushless motor swap any 2 of the 3 motor leads.
To reverse the brushed version just swap the 2 motor lead wires.
Replace all your control horns with DuBro horns.
2500GENE is offline Find More Posts by 2500GENE
Old Jan 02, 2011, 08:51 PM
USA, NC, Brunswick
Joined Dec 2010
It was an EP, I just grabbed the wrong one. I'm going to put the stock prop back on until my hobby king order gets here with my new motor.
Any advice about painting the sky surfer?
Old Jan 02, 2011, 09:14 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Flying Hi
Don't paint it! ANY additional weight is not good. For this plane, I suggest that you do not add any additional weight (repeat). Take some videos for all of us to enjoy. If anyone has seen an SS will; I always us any.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jan 02, 2011, 09:29 PM
USA, NC, Brunswick
Joined Dec 2010
AJ
what?
Also, I'm not wanting to paint the whole thing, but my stickers came all bunched up and creased and have already ( < 15 flights) started to peel up on the leading edges. I wanted to take the stickers off because they don't look nice and paint the wingtips and under the fuselage to make it easier to see; I don't intend to paint the whole plane (especially not now)
Old Jan 02, 2011, 09:34 PM
USA, NC, Brunswick
Joined Dec 2010
Maybe something like what Chris has done with his skywalker here
Old Jan 02, 2011, 11:49 PM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
I'm finding hot glue works well for EPO foam pieces you need to be able re-separate in the future. To remove it, you just have to be able to reheat the glue in the seam. So how do you reheat it? I've found a separating trick you can do with a metal putty knife and a soldering gun/iron. Just heat the metal putty knife blade edge with the soldering gun, then slowly push the putty knife in the seam. It melts the hot glue seam like butter. Here is the Harbor Freight soldering gun I use, which heats up very quickly.
Also have used this trick to remove hot glued velcro, gyros and plastic pieces.
mike_m2 is offline Find More Posts by mike_m2
Old Jan 02, 2011, 11:57 PM
mike_m2 is offline
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
Chance
On my SkyS, I still have the stock control horns on the ailerons after a dozen or so flights. The ones on the rudder and elevator ripped out of their holes on the first couple flights, so I would replace them first. That's just what I've seen. Others may experienced something different.
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
