Old Dec 29, 2010, 10:04 PM
ChanceCarroll is offline
Find More Posts by ChanceCarroll
wait what goes here.....
USA, NC, Brunswick
Joined Dec 2010
Originally Posted by Prof100 View Post
Yes, to both. The motor is a typical upgrade. The collet is must have and they are an industry standard for attaching props.
Does you plane have the stock brushless or brushed motor?
The brushed motor, or else I would just leave it stock, I'm trying to resist the temptation to keep doing mods until I become more proficient with it.
ChanceCarroll is offline Find More Posts by ChanceCarroll
Old Dec 29, 2010, 10:07 PM
studawg66 is offline
Find More Posts by studawg66
Alabama
Joined Sep 2010
Originally Posted by ChanceCarroll View Post
You're right on the heat sink, I don't know what I was thinking....
AJ recommended this one: http://www.hobbyking.com/hobbycity/s...idProduct=5203 in post #1405 but $20 on the motor will mean one less battery I can buy untill I get paid again, I guess I could make a UMM and start cheap then swap them out till I find one I like.
OR...
You could start a swarm sale and if some others join in you can get it for $10.48 !! I would gladly join it just to help you with the numbers. Heck, I might even talk myself into buying JUST ONE MORE.
studawg66 is offline Find More Posts by studawg66
Old Dec 29, 2010, 10:08 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I'm going with this motor to start with, thanks for all the help!
It will work great. You could probably get away with running 20C 3S 2200 packs which are about $10 at Hobbyking.
Prof100 is offline Find More Posts by Prof100
Old Dec 29, 2010, 10:18 PM
USA, NC, Brunswick
Joined Dec 2010
Originally Posted by studawg66 View Post
OR...
lol I know that temptation! tell you what, I'll make a universal motor mount of some sort so I can swap motors, and then we can start a swarm later I'm going with the recommended outrunner because it comes with everything and I had a good personal recommendation I'd like to also try that inrunner later on.
Thats what I am hoping to run! They have the Zippy 3S1P for $7.99. I was planning on charging them with the stock charger (slooooow but it says 3S compatible) until I get paid.
Old Dec 29, 2010, 10:42 PM
garymcc is offline
Find More Posts by garymcc
West Texas USA
Joined Mar 2008
Motor.
I used this Turnigy 1900kv on my Clouds Fly and flying wing and it worked fairly well on both with a 6x5E prop.
garymcc is offline Find More Posts by garymcc
Old Dec 29, 2010, 10:56 PM
USA, NC, Brunswick
Joined Dec 2010
You had to post right as I was about to order didn't you! I kid, I kid!
I don't under stand why that one is cheaper? it seems to have about the same specs but turn faster and pull 4 more amps...
humm, now I have to go compare some more....
EDIT:
I see, it's for a 2S system! ok, sticking with the first one!
Old Dec 29, 2010, 11:09 PM
garymcc is offline
West Texas USA
Joined Mar 2008
EDIT:
I used it with 3S and a 18A ESC for nearly 100 flights. The 1650kv will probably turn in nearly the same performance. If you over-prop it you will probably fry it as well as any other motor you over-prop.
Good question as to why it is so cheap. Maybe I got lucky.
Old Dec 31, 2010, 07:22 AM
yannc is offline
Find More Posts by yannc
Joined Jul 2008
Received my ARF from BRC hobbies (UK vendor). Definitely a V2, clear canopy (pilot included), inside control rods and I couldn't see washers in the front. Mine came glued already, I would have preferred to do this myself. Actually, beside the kit and the motor, nothing else is provided (not even the glue!).
Now I need my HK order so I can start building the thing. ..
yannc is offline Find More Posts by yannc
Old Dec 31, 2010, 08:53 AM
USA, NC, Brunswick
Joined Dec 2010
A note to any fellow beginners out there, you might as well reinforce the wing spar right off the bat; I broke mine pulling out of a dive too quickly on the maiden two days ago. I had convinced myself it wasn't necessary because I wasn't trying to do anything aerobatic, however "trying" was the operative word :P
Also, take the wings off and check after every day of flying! I didn't notice mine was broken until today!
Quick question, it looks like the horizontal stabilizer is slightly crooked, one tip is a cm or two higher than the other; whats the best way to fix it? pull it out and re-glue it?
It's possible there was a slightly hard landing somewhere in the last couple of flights (most of them)
Thanks!
Old Dec 31, 2010, 09:43 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Thanks!
Chance,
Yes, the stock spar is too weak. Thanks for sharing your advice.
Horizontal stab is crooked? Did you build it that way or did it warp? EPO foam is great for crash resistance but the drawback is that it will warp if stored with weight on a component (e.g., wing or stab). I first noticed this with a EPO jet that had to be trimmed every time I flew it because the EPO would warp slightly. If the horizontal stab simply took a set a little heat can be applied to bend it back to normal. If you glued it in that way some surgery may be in order.
To prevent warping I retrofitted a piece of 3 mm CF on the bottom side. See picture below.
Old Dec 31, 2010, 10:25 AM
USA, NC, Brunswick
Joined Dec 2010
It probably warped, I had it in my car and did not realize some weight was on the stabilizer. I'm going to pick up some more carbon fiber right now, then I can fly some more
Old Dec 31, 2010, 02:05 PM
garymcc is offline
West Texas USA
Joined Mar 2008
Are the spar covers glued into the wings? If so, I assume there is an aileron servo extension built into each wing.
If the brushless motor is already glued in I hope the motor wires are long enough to get to an ESC. My motor wires were short.
I hope you got the steel pushrods with the kit.
Old Dec 31, 2010, 02:10 PM
yannc is offline
Joined Jul 2008
The spar covers are not glued so that's a good thing. The motor is already glued in. The motor wires must be about 3 cm long with bullet connectors on them...I'll definitely need an extension from the ESC and I have ordered the necessary parts on HK for this.
Old Dec 31, 2010, 02:25 PM
garymcc is offline
West Texas USA
Joined Mar 2008
FWIW: I used medium CA for the entire build. I used no epoxy on my SkyS v2.
I used hot glue to fix the servos in place. Good luck.
I think I used some Gorilla Glue to fix the motor into the fuselage.
Old Dec 31, 2010, 04:39 PM
USA, NC, Brunswick
Joined Dec 2010
Replaced the wingspar and greatness ensued! This plane is so much fun!
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
