Old Dec 07, 2010, 07:31 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by ajbaker View Post
Ah. Got it. Thanks. I won't confuse them again. Why do you use GOOP? Time control?
Ooops. You are way ahead of me.
AJ
Simple answer as to why I use it. It can be separated with a garden variety kitchen knife without tearing up too much foam. CA usually ends up a cohesive failure of the foam.
Prof100 is offline Find More Posts by Prof100
Old Dec 07, 2010, 07:33 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
GOOP is good.
That is a GREAT reason. I definitely will get some just for that if nothing else.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Dec 07, 2010, 07:35 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
I still use CA but not when I know the seam has to separated to do such things as change out a motor or ESC.
Old Dec 07, 2010, 10:02 PM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
GOOP is a range of adhesives which may not be available to you. Here is the website:
http://www.eclecticproducts.com/ag_adhesives.htm
I OFTEN use hot glue to repair a plane. It is quick and effective other then the weight penalty.
Bill
Also referred to as Shoe Gooo!!! I have a tube of this I use on my shoes, but never thought of using it on my planes. All I know is that has pretty nasty vapors. If you ever use this stuff make sure you have good ventilation. Otherwise, you can get a headache easily from it.
kman24 is online now Find More Posts by kman24
Old Dec 07, 2010, 10:07 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Similar but not quite as strong in terms of vapors that evaporate. I used Shoo Goo on by tennis shoes when I used to play tennis. I also found it worked well to protect the high impact zones of touring car bodies when I used to race RC cars.
Old Dec 08, 2010, 02:30 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Your guidence please.
Can I take one of those 8mm Shaft Adapters from HK and use a 9mm end mill in a drill press to make the hole the size I need it?
AJ
P.S. Or THIS ADAPTER?
Actually, right now, I would give a double cheeseburger for a source where I could buy those for a 9mm end bearing cap. You know what I mean, I hope. Like the two above - only 9mm in dia. - It is getting late and my eyes are done. TIA for any help or advice.
AJ
Old Dec 08, 2010, 06:02 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
AJ
Sure, try opening it up. You just need the clearance to fit the motor. Clamp it in with set screws.
Old Dec 08, 2010, 12:22 PM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
my experience with Amazing Goop
Bill
HERE IS MY EXPERIENCE WITH AMAZING GOOP - I definitely think it's worth having some in your arsenal of tools for hobbyist. It's uses are really amazing and unique.
WHERE TO BUY: Amazing Goop is marketed under lots of different names, but I believe the same formula is used in all the "Goop" products. Because of that, you can get it at several different stores, whichever you frequent the most. I shop at Home Depot often, so I pick up the Plumber's Goop in plumbing isle.
CONSISTENCY: It's consistency when dried is similar to hard rubber, so it has some flexibility, good for places that you want to allow a little movement. It can be put on very thick, similar to what you might do with silicone caulk, and will dry from the outside it.
BONDING: It's bonding power is very good also. If you've had some issues with surfaces not sticking with CA, try this instead. To give an example, I had some sunglasses break at the hinge and I knew CA would just break again, so I used Goop instead and it worked great. The flexibility helped a lot. It does really well on plastic, metal and wood. I haven't tried foam yet.
WEIGHT: It's going to be relatively heavy, maybe similar to hot glue. I've never actually measured it's weight though. So just use it sparingly.
PAINTING: I haven't tried painting it, but it colors nicely with a permanent marker.
MESS: Don't get it on your hands. It's one of those sticky things that doesn't seem to come off your hands unless you clean it with a smelly petroleum-based cleaner. Use it carefully or use latex gloves to be safe. It comes with a little nozzle to help direct it's flow, but it's a little awkward to use. It has a consistency similar to silicone caulk, so you can sculpt it a little before it dries.
DRY TIME: It takes a while. I don't know the exact number of hours. I usually let mine dry overnight, so maybe 6 - 8 hours. The thicker it is, the longer it takes.
TRICKS:
1. If you want to add some body/strength to it, buy some mesh drywall tape (can be found at Home Depot) like this http://www.amazon.com/3M-Scotch-Dryw...1831662&sr=8-7. Wrap the area with the tape then glue over the tape.
2. You can use it to mold parts. Use some blue painters/masking tape around area you want to mold, then insert the glue inside. You can then use the tape on the area where you inserted the glue. Once dry, the painters tape just peels off.
I too have used on repairs for my RC truck.
mike_m2 is offline Find More Posts by mike_m2
Old Dec 08, 2010, 06:45 PM
Bob A is offline
Find More Posts by Bob A
United States, IA, Keosauqua
Joined Sep 2010
I have a couple of questions about the battery charger that came with my RTF SS V1. According to the label on it the charge rate is 0.8 A and the only indicator is a LED that is red when charging, then changes to green when charge is complete.
1.) Does anyone know how the time needed to recharge a battery correlates to the mah that have been used? i.e. if it takes 1/2 hr to recharge a battery does that mean that 400mah have been depleted?
2.) The TX that came with my SS has a port for recharging. Can I use the same lipo charger to recharge Ni-Cad, Lithium, or ?? batteries in the TX?
No instructions came with the charger except a wrong statement that a green light on the charger means its charging the lipo correctly and the lipo is completely charged when the green light goes out.
Bob
Bob A is offline Find More Posts by Bob A
Old Dec 08, 2010, 10:48 PM
kman24's Avatar
Joined Jan 2010
Bob
Hey Bob, as you have discovered, the red LED indicates that it is charging and the green LED means it is done. As for your charging calculation goes, it is correct assuming we live in a perfect world. However, due to efficiency losses in the real world, it you charge for 1/2 hour it would be slightly less (10-20% possibly?).
I can't answer your question about your mystery TX port because I don't have that RTF version. However, I do have a cheapy 2.4 GHz TX that I got with another RTF plane that I have and it is NOT a port for charging the batteries. It is an interface for your computer utilizing an optional USB converter cable. This allows you to use it with your computer if you have a flight simulator software program (such as FMS).
Hope this helps. Also, if you plan on staying in the hobby, I recommend you get a different lipo balance charger. There are a slew of inexpensive chargers out there ($30-$60) that make charging your batteries a much richer experience
Old Dec 08, 2010, 11:08 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Buy a new charger - Really.....
Bob
1. No. Probably not. But, the only way to tell for sure is to get a charger that will report the status of the charge - before, during, and after.
2. NO. You would toast the charger or the battery pack or BOTH. Of course, if you used a LiPo battery pack in your transmitter, then you could use your LiPo charger for both the in-flight pack and the xmitter pack.
For right now, I would recommend THIS charger that can handle anything and everything that you currently have. And, the price is definitely right ($23). It is without a doubt, the most bang for the buck that is available IMO).
AJ
Old Dec 09, 2010, 07:36 AM
mataub is offline
Find More Posts by mataub
mataub's Avatar
UK south
Joined Dec 2007
Sky Surfer in the UK...
I don't know if this is of any use to you but I just phoned a bloke from BRC Hobbies who tells me that he's expecting a delivery of Sky Surfers today. He will phone me back if they arrive. The link is: BRC
I will, of course, post back here if he phones me.
Hope this might be of some use!
Steve.
I've also just rung Sussex Model Centre who haven't got any in but who say they could get one in tomorrow. The link is SMC
You all seem to have such problems getting hold of them so you might want to take a look and get in touch with these places? Assuming it's the right model and I haven't made a mistake etc etc etc.
mataub is offline Find More Posts by mataub
Old Dec 09, 2010, 06:44 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Sources
Steve.
Over there, you have those two sources. We have BEVRC.com and banana hobby.com. and me. Well, BEVRC is a great place to deal with but they are out of them, too. BH has Version 1 in stock but they are horrible to do business with. I hope they improve. But, for right now, they are circling the drain once again. Then, there is me. I am waiting right now for a carton of 12 Sky Surfers to arrive. 17 of them are spoken for already (I need some help with my math or more planes). So, the race is on. BEVRC ordered some, too. I do not plan on going into the hobby business because I am retired and it is FAR too competitive. Ah, well, I am glad that you have a couple of great places to get the SkyS even if they are out of them for now.
AJ
Old Dec 09, 2010, 06:48 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
STick to it.
I went to their site and read all the specs on the 10 glues that they offer. I am guessing that you use "Plumbers" Goop mostly. Do you use/recommend any of the other ones?
I was considering throwing one of these into my basket next time I am at Amazon.com. It that an OK idea? TIA.
AJ
Old Dec 09, 2010, 07:14 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
AJ
I use the original all purpose.
Can't wait to get one of those SS you promised me.
2500GENE is offline Find More Posts by 2500GENE
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
