Old Mar 04, 2013, 12:58 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Heres my newest video/update on the lit 1.1 i got. Just need to install the 1.3 800mW vtx on the wing and some decent weather.. then its time for a maiden.
Bixler FPV Build update 5 (Pre maiden) (9 min 0 sec)
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Mar 05, 2013, 08:18 PM
807gt is offline
Find More Posts by 807gt
Joined Nov 2011
My recend order of 1 HK-T6A V2 TX and 2 matching receivers + other things has arrived. I can bind those 2 receivers easely to my Bixler 1 TX, but none of the new HK-TR6A v2 will bind to the HK-T6A V2 TX, no matter how often I try .Do I have to program the TX first via a computer , or is there any other trick required ? I hope someone can help me . Best regards, Gerhard,807gt.
807gt is offline Find More Posts by 807gt
Old Mar 05, 2013, 09:06 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Originally Posted by 807gt View Post
My recent order of 1 HK-T6A V2 TX and 2 matching receivers ....Do I have to program the TX first via a computer.
I've never had problems other than those of my own making meaning forgetting to remove the binding loop after binding. So no, you shouldn't have to connect to a computer. I never have connected to a computer to the Tx.
Also, to reverse channels, I fitted switches the same as the T4A V2. There are slots under the front panel label the same place as the 4 ch.
Mac50L is offline Find More Posts by Mac50L
Old Mar 05, 2013, 10:31 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
More info please
Please post a picture of all 4(?) receivers. You might have two different versions of receivers. Do you have a satellite receiver on any of them?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 05, 2013, 11:00 PM
Amfamora is offline
Find More Posts by Amfamora
Multicopter Crash Tester
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
Maiden with Liquid Image Ego onboard....
Bixler Maiden - Liquid Image Ego (2 min 23 sec)
Amfamora is offline Find More Posts by Amfamora
Old Mar 05, 2013, 11:41 PM
807gt is offline
Joined Nov 2011
Well, I am a bit surprised to get such a fast response.I am not very computer litterate and dont realy know ,how to post pictures.Nobody has shown me, how to do it.Sorry.I will have to wait till one of my sons or sons in law will come by. There is no satelite receiver. I hope, the tx is ok and need not be sent back to HK. I have taken the pictures, now I will have to wait for some help.Be patient please,best regards, Gerhard 807gt.
Old Mar 06, 2013, 02:09 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
No problem. We will be patient.
AJ
Old Mar 06, 2013, 09:59 AM
Scorpio9999 is offline
Find More Posts by Scorpio9999
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
New video
Experimental recording of Bixler r/c plane flight on Mystery MDR-800HD car camcoder.
Bixler Flight #16 GND (4 min 12 sec)
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Mar 06, 2013, 10:20 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Hey guys, while I am waiting for my Bix 1.1 kit to arrive I was thinking of fabbing up a glider type centerline landing gear. I would like to know the approximate inside and outside width of the fuselage on the bottom right below the cockpit opening. Doesn't have to be exact. Thanks.
u2builder is offline Find More Posts by u2builder
Old Mar 06, 2013, 06:00 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
http://youtu.be/eh4vwvOWvns
Congratulations on a nice safe Maiden. Yours lasted much longer than mine as well as staying in one piece. Mine decided to land in a tree.
Eagle202 is offline Find More Posts by Eagle202
Old Mar 06, 2013, 06:05 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Yeah, 5 times....just last week.
2500GENE is offline Find More Posts by 2500GENE
Old Mar 06, 2013, 06:21 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Nice to see you are awake for once. 3 of those times were trees in your yard. Glad I didn't fall into your pool.
Old Mar 06, 2013, 07:06 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
I keep doing planes but I'm not flying planes my responsibilities will allow at the moment.
Went back to the flight simulator and started doing exercises of an entirely different type using these three planes which actually have, a Cessna 182, heavy 5 pound scale plane that was my trainer there got me my license. To handle it correctly it requires rudder be used in the turns just like the real one. My sky surfer in my P 50 1D.
Here is my new exercise;
1. Using ClearView I find it airfield with trees on both sides.
2. I take the plane off climb out to listen treetop high.
3. I stay below the tree line and put the plane into a bank.
4. To make the bank tight I use all flight surfaces including rudder.
5. I keep flying patterns at lower and lower altitudes
6. I finish with high-speed touch and go landings.
It's training me fly my patterns flat and under the circumstances I'm required to fly all controls to do this well.
I present this is a new flyer is a way of using our flight simulators the Titan upper flying skills. It's working for me.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Mar 06, 2013, 11:25 PM
Amfamora is offline
Amfamora's Avatar
Joined Apr 2012
Cheers The first crash happened unfortunately cause I gave it throttle (mode 2) then used left hand on the elevator stick and chucked it with the right hand..... as I threw it bumped the throttle to low as I quickly moved my left hand back lost all thrust..... nose dive lol.
Old Mar 07, 2013, 04:45 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Fix it and fly
I think it is safe to say that most of us have done something like that. The good news is that the SkyS is usually an easy repair. Just use a little CA on the breaks and you are flying again.
AJ
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
