Old Feb 17, 2013, 04:21 PM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by Amfamora View Post
Not especially, many have done it in the past on fpv builds and I guess only a true test will be getting it in the air
There is no flex or any less rigidity than the old build so should be all good.....
Ok. I just know that the side walls where the canopy is attached are weak points and can compress during a nose in hit. I have used Popsicle sticks to reinforce those walls so I though your opening may also require some additional stiffening in case the removable piece fell out on impact.
Just my 2 cents.
Eagle202 is offline Find More Posts by Eagle202
Old Feb 17, 2013, 06:42 PM
Bixler Boy V1
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
I have popsicle sticks spanning the old servo holes and re-glued some foam in there as well, hopefully its enough to take the impact of a nose hit and protect the opening where the flap is in the fuse. I also cut the flap on a bevel to help as well...
Amfamora is offline Find More Posts by Amfamora
Old Feb 17, 2013, 06:52 PM
Eagle202's Avatar
Joined Aug 2011
I saw the pop sticks in the canopy area but not the side opening. Sounds like you got it covered.
Old Feb 17, 2013, 06:56 PM
Bixler Boy V1
Amfamora's Avatar
Joined Apr 2012
*Fingers crossed*
Old Feb 19, 2013, 09:02 AM
kmc
Rookie
kmc's Avatar
United States, ID, Meridian
Joined Mar 2011
Trying to get my plane back in the sky after a year of being down. My motor is angled about 10 degrees to the side and I think that is really throwing off the flight of the plane. What is the best way to fix this. I've read the motor mount mods, but I don't really want to separate the whole plane. Any suggestions?
kmc is offline Find More Posts by kmc
Old Feb 20, 2013, 09:44 PM
GENE's Fantasy Woman
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
That is probably right thrust
It does not need fixed if it is angled to right ([ccw from top] when viewed from the back), just go fly it. That angle is built into the plane by design.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Feb 21, 2013, 06:32 AM
Joined Feb 2013
AJ
I got my skys today and I also notice my motor shaft is angled to the right when viewed from the back.
This is normal? May I know why? I am not very good with it. Total noob here.
junjian is offline Find More Posts by junjian
Old Feb 21, 2013, 07:32 AM
Bixler Boy V1
Amfamora's Avatar
Joined Apr 2012
Its to counter the torque of the motor as it spins. Without it the plane will roll everytime you give it a decent amount of throttle.
Old Feb 21, 2013, 08:17 AM
Joined Feb 2013
Oh, lucky I check at this thread. I almost wanted to bent it straight. LOL. Time to go fix up my SkyS!
Old Feb 21, 2013, 08:49 AM
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Yup. The offsets counteract the motor's torque so don't try to straighten it!
Go fly that bugger!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Feb 21, 2013, 09:36 AM
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
It's to counter P-factor, not torque.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 21, 2013, 03:29 PM
kmc
Rookie
kmc's Avatar
Joined Mar 2011
I feel like I am always having to trim because of this. Like the wind created by the prop pushes on one side of the tail and I have to manually counteract it.
Old Feb 21, 2013, 05:03 PM
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
The angle does look like it's a bit much. I went over all file attachments in this thread 10 pages, a great many motor modifications and half of them or more have the shaft straight. Others are angled to the right viewing plane from the rear.
Then I went back on my Bixler ll thread and look at all of those attachments. On the Bixler two the plastic can that the motor mounts to has no means to be angle. The can is symmetrical there is no way to put an angle on it unless you shimed it.
When I was first learning to fly which I still am my flight instructor told me on takeoff to hold some rudder right because it will want to twist to the left that sounds like torque to me. I later asked him why and he said P factor, understand what torque is but he didn't explain what P factor is.
I fly sky surfer V2, it's not stock, it's very powerful, and the motor is dead not straight.
As I said I saw some angle in some of the photos on the attachments in this thread I saw just as many with new motor setups that were dead not straight.
Name: OFF Topic.jpg
Description:
DJ
I stole that while looking through the attachments it was just too cool for school!
Sculptor is online now Find More Posts by Sculptor
Old Feb 21, 2013, 05:04 PM
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Ted
Before you said the P factor only needed to be considered during bar hopping???
2500GENE is offline Find More Posts by 2500GENE
Old Feb 21, 2013, 05:45 PM
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Eugene I thought P factor was what happens when my plane is upside down and I don't know it. It's hard on shorts and tennis shoes.
DJ
you're in the Cape right?
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 02:49 AM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 5 Feb 05, 2010 06:57 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
