Old Jan 16, 2013, 01:24 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Maddmax View Post
Heres a quick video I put together. Be sure to watch the nding!!
Just a couple inches to the right and you would have made it. Still, nice video. How did the left wing do?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jan 16, 2013, 05:21 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
The wing came off cleanly since it was only pinned in from the top. Had to glue it in to make it fly again.
Maddmax is offline Find More Posts by Maddmax
Old Jan 17, 2013, 04:45 AM
Mistimeanors is offline
Find More Posts by Mistimeanors
Australia, ACT, Campbell
Joined Aug 2011
Just wondering when fitting the spar cover should I glue it on or could I just use reinforced tape? My load will be basic FPV, 2200 lipo (ps installed a 4mm CF rod inside the stock 6mm spar). Thanks/
Mistimeanors is offline Find More Posts by Mistimeanors
Old Jan 17, 2013, 05:10 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Glue the spar cover in place - Especially for FPV which will have a large wing load and therefore stress on the spar to push the cover off. It is just too risky to use tape even though there are many very fine choices out there. CA Glue beats them all IMO.
AJ
Old Jan 19, 2013, 02:14 PM
Eagle202 is online now
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
http://www.youtube.com/watch?v=6DBk-5158Oc
Nice goal Max.
Eagle202 is online now Find More Posts by Eagle202
Old Jan 19, 2013, 02:52 PM
JohnVH is online now
Find More Posts by JohnVH
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Finally made it above the clouds with the bix
JohnVH is online now Find More Posts by JohnVH
Old Jan 20, 2013, 01:09 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Anyone flying around the Poughkeepsie NY area on this forum??
I would sure like to be sometimes, it rains too much out here! I spent some time around Poughkeepsie about 30 or 40 years ago working for IBM and really liked the area. I recognized Wappingers Falls right off. I wish I could have made it up to Rhinebeck when things were happening. When I went there it was closed.
Your video makes me think you might have been watching Crazy Horst's videos.
Gord
Gordks is offline Find More Posts by Gordks
Old Jan 20, 2013, 01:56 PM
Maddmax is offline
Joined Jun 2011
No idea who Crazy Horst is????
Old Jan 20, 2013, 02:03 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Max, he is probably the most famous FPV flyer, editor anywhere! I'll try to find you a link to him.
No Risk No Fun- crazy horst (7 min 49 sec)
DJ
Sculptor is offline Find More Posts by Sculptor
Old Jan 21, 2013, 05:52 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
CG on a Bixler 1.1
Hi.
The instructions on the Bixler 1.1 state that the CG is 71mm from the leading edge of the wing.
Does anyone have any other experience?
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Jan 21, 2013, 05:57 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by Shimmy View Post
Hi.
Shimmy
From the first page of this thread:
1. CG for Sky Surfer (all versions V1, V2, and V3) and Bixler should be 60mm from LE of wing. The CG for the Sky Surfer V4 should be 71mm-thanks to Hayabusa for the update from his manual.
2500GENE is offline Find More Posts by 2500GENE
Old Jan 21, 2013, 06:55 PM
Shimmy is offline
Joined Jun 2012
Yes thanks.
I ask because several things have been changed in the Bixler 1.1 and the manual does say very explicitly 71mm. Perhaps the Bixler 1.1 is more similar to the SkySurfer V4 ?
Old Jan 21, 2013, 07:09 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Flight Over Neighborhood (6 min 40 sec)
Watch for the interesting 'landing' at the end hehe.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jan 21, 2013, 10:24 PM
sniemetz is offline
Find More Posts by sniemetz
Joined Dec 2005
I didn't get a response to my radio question so I figured it out myself
got a 7c on eBay for 180us with receiver, works great. chaperones much simpler than dx6i
observations from the frankenplane that started zs bixler 1.1:
had massive nose up issues on half power. when turning in a glide, the tail would sag (no input). and the float the plane seemed draggy.
first in reaped the thing with smooth tape.
then I played with additional ballast and ended up adding 12 oz at cg
the cg
moved the cg front a bit too.
trimmed the wings, stab and rudder.
seems to fly more solid, better penetration, slightly less affected by gusts from side. with a 3s 2200mah I fly for almost 20min, cruise at little less than half throttle with slight breeze.
oh and until I have an fpv setup I am sticking that cheapo Casio up there too.
yesterday went up in a bit of a wind. cg misadjusted (nose heavy) and wind from the side. slap on head. ditched in tall grass after 10 yrs. 2nd try and it was up.
the wind was so strong that on full throttle I could sloooooowly climb and make headway into the wind. turning was interesting, as was seeing how fast the wind took the plane with it.
after 6 min my 9yr old managed to mangle his thumb with his pocket knife. blood was dripping, so that was the end of the outing.
oh the clipped wings make it a little hotter, it rolls much easier. inverted is always a near crash - and then I noticed the stab servo is stripped. I stuck a 3004 on outside the fuse, looks horrible, but works (9g servos on order)
now I am all over this forum for the right fpv gear. I am leaning toward an entry-level 900mhz kit from hobbyking, but with an osd I can keep.
I figure I can later put that rig into another plane or car.
still digesting the cost of goggles, and wondering whether it's smarter to start with a 7in LCD setup
thoughts?
sniemetz is offline Find More Posts by sniemetz
Old Jan 21, 2013, 11:50 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
A couple of thoughts
Originally Posted by sniemetz View Post
<SNIP>
thoughts?
First, you might want to read page #1 - posts #2 and #3 to get whatever info you can use from them.
Second, for FPV, I recommend this thread:
http://www.rcgroups.com/forums/showthread.php?t=1533848
ilovefpv (the thread boss) is very knowledgeable and all the guys there can be very helpful for the SkyS FPV folks. Happy Flying.
AJ
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
