Old Jan 13, 2013, 08:33 PM
JohnVH is online now
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
I put all my servo's in the tail on my V1.1
JohnVH is online now Find More Posts by JohnVH
Old Jan 13, 2013, 11:18 PM
Zangetsu57 is offline
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
I reinforced the spar on my Bixler, but the wings still flex quite a bit in flight. Is this a concern? I'll primarily be using the plane for FPV purposes. I've considered adding a second spar that is longer, behind the factory spar's location, but it seems like it would be a pain in the butt to install.
Zangetsu57 is offline Find More Posts by Zangetsu57
Old Jan 13, 2013, 11:38 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The easy way
Just put a 4mm CF tube inside the 6mm spar. That will give you considerably more strength. If you have already done that, you can still put a 2mm CF tube inside the 4mm tube. Also, it is easy to "drill" out the spar hole to 8mm using a piece of sandpaper wrapped around a 5/16" x 3' wooden dowel. I have done all of the above to 3 planes. It works out great.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jan 13, 2013, 11:43 PM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
My 1.1 came with a little solid spar. Not sure what it was, fiberglass? I flew it in the wind with it, but replaced it with a same dia carbon spar that went into the wings as far as it would go, it's a lot longer. Then I shoved a small carbon spar in that one. Wing are super stuff. That's really the only mod a bixler v1.1 needs.
But knowing I'd be putting a bunch of weight in the nose, I put the servos in the tail.
Old Jan 13, 2013, 11:59 PM
Joined Sep 2010
AJ
Thanks for the replies. I've already put a 4mm solid CF rod in the stock spar. There was a bit of empty space so used a lot of gorilla glue when installing. The problem is the spar doesn't span the length of the wings, so I can easily see the wingtips "flutter" in moderate wind and moderately fast elevation changes (but not pulling crazy high-g maneuvers). Maybe I'll upgrade to a 8mm CF tube, as the spar does still flex.
Old Jan 14, 2013, 12:01 AM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
FPV Flying in the rain, shooting for the clouds with DragonLink V2 (2 min 27 sec)
Solid
FPV Formation! So much fun! Flown with Dragonlink! (2 min 30 sec)
Old Jan 14, 2013, 12:43 AM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
Originally Posted by Sculptor View Post
Shimmy, would it work to put them back right way round and sham one of them up higher than the other maybe? There's another type of control horn attachment that I like a lot better than the twisties I just installed two of those other combat plane is lying on the kitchen table right now. I'll did the label out of the trash and take a picture this thing. It is so much easier to use than unclip in the twisties and trying to guess how many turns it'll take to get them right.
DJ
Thanks. I have linkage stoppers that look like these... only too small. The wire won't fit in the hole. I have to see if I can get them locally. When I bought a carbon spar locally I paid something like 8x what they cost on HK. I was hoping to fly this weekend.
If I can not get them, I may cut the control rod at the appropriate length and glue the clevis on. That won't give me any way to adjust the length manually.
Shimmy is offline Find More Posts by Shimmy
Old Jan 14, 2013, 12:46 AM
Shimmy is offline
Joined Jun 2012
Originally Posted by JohnVH View Post
Can you tell me how you solved the servo arm issue? Did you flip it like I did ? If so, how did you connect to the control horns?
Old Jan 15, 2013, 03:39 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Call me tonight 21:00-ish. I might have "proper" E/Z connectors for you, or adjustable clevises
Up&Away is offline Find More Posts by Up&Away
Old Jan 15, 2013, 10:16 AM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
servo arm issue?
http://www.rcgroups.com/forums/showthread.php?t=1790076
Old Jan 15, 2013, 12:57 PM
Shimmy is offline
Joined Jun 2012
Thanks. When you said "In the tail" I thought that you meant inside the fuse under the hatch. Your pictures made it clear.
Old Jan 15, 2013, 01:00 PM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
I knew I was going to add a bunch of weight to the nose with fpv gear, so right out of the gate I put the servos in the back, they probably could be farther back yet. My RX is in the hatch where the servo's are supposed to go
Old Jan 16, 2013, 09:50 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Servos in the tail
Here's how I did my tail servos. They fit perfectly and actually touch each other inside for a strong bond.
Maddmax is offline Find More Posts by Maddmax
Maddmax is offline
Joined Jun 2011
Heres a quick video I put together. Be sure to watch the ending!!
Flying Around The Valley (3 min 9 sec)
Old Jan 16, 2013, 09:51 AM
Maddmax is offline
Joined Jun 2011
Anyone flying around the Poughkeepsie NY area on this forum??
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
