Old Dec 29, 2012, 12:06 PM
JohnVH is online now
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
do not use the X, mount the motor directly to the motor mount on the bixler.
Find the holes that line up and locktite the screws and screw it on there.
JohnVH is online now Find More Posts by JohnVH
Old Dec 29, 2012, 12:52 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
Thanks. I did not think to look in the bag of hardware. In it I found 4 screws and washers that will reach all the way through the wooden mount.
(newbie )
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Dec 29, 2012, 01:58 PM
Fugitive_Bill is online now
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
In the stock V1 Bixler I found I had to remove 2 of the wooden mounting 'spacers/plates to allow the supplied bolts to get enough turns into the motor case.
As stock the bolts only make about one turn into the motor.
Luckily I did not find the hard way (in the air) that they they did get enough 'bite' and did not have Loctite,
but simply vibrated loose during bench run ups when they let go.
(I posted pictures of the mod on this thread somewhere, but at 1169 pages, I'm not gunna go back searching for that post - me being lazy and all!) -
-B!LL!
Fugitive_Bill is online now Find More Posts by Fugitive_Bill
Old Dec 29, 2012, 02:15 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
-B!LL!
That's the spirit!
2500GENE is offline Find More Posts by 2500GENE
Old Dec 29, 2012, 04:02 PM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
thats odd, I have a bixler 1, and my bolts were plenty long into the motor, I was almost worried about them being too long.
Old Dec 29, 2012, 05:43 PM
Shimmy is offline
Joined Jun 2012
I have the Bixler 1.1 (I ordered the 1.0 however HK upgraded me without asking) The 4 screws are long enough to get several turns in to the motor perhaps because the Popsicle stick motor mount is only 1 layer thick.
Funny thing. I could not get the screws to line up with the motors holes so I flipped the mount the other way and it lined up easily.
The 2826-6 motor fits in without having to cut the foam.
Old Dec 29, 2012, 05:48 PM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
same motor I have, its FAST!
speed run at 3:43
Christmas eve FPV flying with DragonLink (6 min 5 sec)
Old Dec 30, 2012, 04:59 PM
Shimmy is offline
Joined Jun 2012
Hi,
The holes on the servo arms of the HXT-900 are too small for the push rods. What is the best way to enlarge them. I was thinking of a hot pin. Is there a better way ?
Shimmy
Old Dec 30, 2012, 05:09 PM
ppridday is online now
Find More Posts by ppridday
Breaker of Things
ppridday's Avatar
United States, MN, Detroit Lakes
Joined Mar 2005
Just use a small dia drill bit.
Paul
ppridday is online now Find More Posts by ppridday
Old Dec 30, 2012, 08:09 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
I got my Sky Surfer project done. The ole' girl came out pretty nice!
I've posted the build on the "The 1400mm Sky Surfer: My Build!" pg. of my blog if you want to check it out.
Gary
Sandancer is offline Find More Posts by Sandancer
Old Dec 31, 2012, 03:38 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Hi,
Shimmy
Five seconds with a hobby knife should, just stick the tip in the hole and twist a few times.
Limited flyer is offline Find More Posts by Limited flyer
Old Dec 31, 2012, 04:01 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Hi,
Shimmy
I use a cig lighter and heat the end of the push rod then shove it into the arm hole. Pull it out right away and let it cool. The re-insert and work into position.
so to recap:
You put the push rod in,
You pull the push rod out,
And you twist it all about,
Optional:
You do the hokey pokey
and you turn yourself around
That what it's all about.
Old Dec 31, 2012, 04:10 PM
Breaker of Things
ppridday's Avatar
Joined Mar 2005
Sweet...
Paul
Old Dec 31, 2012, 04:35 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
so to recap:
Optional:
Eugene, that was the most imaginative and poetic description of how to burn a hole in a piece of plastic that I've ever heard.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Dec 31, 2012, 06:46 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
DJ
Life is too short and we only have one crack at it. Might as well enjoy it and have fun when ever we can..
Happy New Year to all.
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
