Old Dec 05, 2012, 09:22 AM
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
Originally Posted by uavrat View Post
That is the conclusion I am coming to as well. I wanted to run a slow motor/big prop, long flight and a few others are doing that. But it might be that this plane is not the one to go that route.
I should just install the original motor at the original height. Get a baseline function test, then decide. Back to the man cave to reconfigure.....
This motor mount has several positions (3 probably).
Try to make one flight on each position without changing of other components.You will see the big difference. On top position you should add washers under down screws to pitch it down at front and up at back. Virtual line of motor shaft should cross the wing at the same point on each motor position on motor mount. You can mix elevator on throttle but it wouldn't help for long duration flights.
As for camera mount, sorry it's ugly IMHO and make big turbulence behind. Plus opened canopy makes it even worse. Try to redesign this part of aircraft.
Otherwise it's like a brick with a motor.
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Dec 06, 2012, 02:52 AM
GENE's Fantasy Woman
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thanks for the Question
Originally Posted by BrianL View Post
It's getting a bit confusing now with three different sizes of Sky Surfers, more than one version of the original mid sized SkyS, the 800mm/31.5 inch and 1280mm/50.5 inch FMS Easy Trainers (oddly also sold at BH), and the Bixler 2 that's larger than the original Bixler. Plus more places to buy the SkyS now, with Nitroplanes selling the AeroSky Skysurfer, yet (also oddly) also sells an AirWing Wingsurfer (in red, blue or green decals), which is only 1372mm/54" wingspan.
And Hobby Lobby just announced their Sky Surfer to go on sale soon.
Who makes the FMS Easy Trainers and AirWing Wingsurfer and how do they compare to the SykS and Bixler?
Maybe the main details of all these planes can be added to the first post.
Also, BH's page for the SkyS says new version 5 coming soon.
I hve just gotten out of the hospita after a long flu problem. I will try to answer your questions in detail at some later date. Right now, I am just focused on getting better.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Dec 07, 2012, 10:21 AM
Joined Jan 2012
Yesterdays test:
I made three flights yesterday, about 10 minutes each. Moving the battery to slightly different positions to adjust the CG. Overall it still wants to fly best somewhere between 85 and 90mm back from leading edge. I made hand glide tests before powered flights each time, and having it a little nose heavy was the best overall handling. Nothing surprising there.
I changed the angle of the motor to be less pronounced and it did make a difference. It still wants to nose down when I reach 60+% throttle but not nearly as radically as before.
Also, during the flights I was able to trim it out so that it flew straight and narrow, and my trim adjusts were not far off center at all. With not much power at all it will stay at altitude and fly pretty nice. It wants to float, and that is just a difference I need to get used to from my prior planes.
I am going to adjust the motor downward a bit more and see if I can smooth out the nose-dive-upon-throttle-increase.
Tanks again.
uavrat is offline Find More Posts by uavrat
Old Dec 07, 2012, 02:45 PM
Chilliwack, BC Canada
Joined Mar 2010
AJ
Sorry to hear you were under the weather AJ. Hope it clears up soon!
Gord
Gordks is offline Find More Posts by Gordks
Old Dec 07, 2012, 03:42 PM
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
AJ
Bad year for the flu they say.... get well soon!
jrjr is offline Find More Posts by jrjr
Old Dec 08, 2012, 12:35 PM
Joined Jun 2012
UAVRAT,
There is a nice explanation about motor angles for pusher-prop airplanes on the Flitetest web site. http://flitetest.com/articles/Motor_..._pusher_planes
Basically, if you are above the CG, there is a rotational force around the CG making it nose down.
Shimmy is offline Find More Posts by Shimmy
Old Dec 08, 2012, 01:36 PM
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Originally Posted by Shimmy View Post
UAVRAT,
I use a throttle/elevator mix. When over half throttle it gives a touch of up elevator to compensate.
Old Dec 08, 2012, 02:20 PM
Joined Jun 2012
AJ
Rest up and feel better. We need a healthy Fearless Leader.
Old Dec 08, 2012, 02:50 PM
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Which is why you need the thrust line through the horizontal and vertical CoG.
Mac50L is offline Find More Posts by Mac50L
Old Dec 08, 2012, 03:26 PM
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
UAVRAT,
Shimmy, thank you for that information. I like it that the man demonstrated the whole program with his videos.
DJ
Sculptor is online now Find More Posts by Sculptor
Old Dec 08, 2012, 10:36 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ
AJ,
Get well soon.
Bill
Prof100 is online now Find More Posts by Prof100
Old Dec 09, 2012, 08:13 AM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
AJ
Ya gotta take better care of yourself my friend. Don't worry about the thread. More important is for you to get your health back so you can get out and enjoy flying again.
Eagle202 is offline Find More Posts by Eagle202
Old Dec 10, 2012, 12:27 PM
Joined Jan 2012
Bixler Aluminum Mount - Motor angle
Here are some photos of my motor
Suppo 2810/9 1350kv Brushless Motor with 8x6 Eprop
mounted on the Aluminum mount. I used the screws, washers and locktite to achieve a 'flatter' mounting configuration. When I flew on Saturday it did still nose down when throttle was above 60%, but only slightly. Overall handling was much better.
Somewhere else it was suggested to simply add washers behind the 4 point mount attachment but that did not work very well with the angles involved. I may try that again, but for now it is very configurable.
Old Dec 12, 2012, 03:16 PM
Joined Jun 2012
Bixler 1.1 kit
I received my Bixler 1.1 kit today. Well packed and no damage. All in all I like most of the changes.
The two halves fit together very nicely. They have a few small pieces of double sided tape holding it together which works OK. A couple of magnets and/or a little glue and some tape on the seam should be enough.
The short spar with an bigger tube embedded in each wing is nice. They left a long slot in each wing, which I gather is to jam a servo wire into.
The rear servos with a hatch will be a little hard to get at, however if I can split the whole fuse, I have a option for "open fuse surgery".
I want to mount the wings so that there is some give for my "hard landings". I don't like the screws. Perhaps I will use magnets and a toothpick to act as a sheer pin in the screw holes.
There are notches for hinges on all the control surfaces. I wonder if they will sell hinges that will fit in exactly.
So far the only funky thing that I have seen is the mounting spot for the sevos on the wing. They are not shaped for the HXT-900 nor for the servos that came in my old SS-V1. I will have to cut away around it to get the servo mounted in line with the control horn, and also create some space for the folded up wire from the servo itself.
Am I missing something obvious here ?
Old Dec 14, 2012, 03:50 PM
Joined Apr 2012
What is the best and cheapest metal gear servo for the bixler?
timtimtim is offline Find More Posts by timtimtim
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 02:49 AM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 5 Feb 05, 2010 06:57 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
