Joined Jan 2012
OK, was able to take two flights today at lunch.
Elevator: set to neutral when controls at center. Same for ailerons. There is some wiggle in the elevator itself. It is aileron-taped in place. Again i tried moving that CG forward a bit from 90mm, with a glide test it still noses in with a hard turn to the left. CG set same around 90mm. Launch about the same, 40% throttle, a not too hard toss and it glides down (but not nosing in) and then I increase power slowly and it starts to climb. Once I get it all up and flying around at a comfortable altitude, to make it trim I have to slow the throttle down to about 40% and trim the elevator down quite a bit. There it flies level. If I leave the elevator at neutral it wants to nose up all the time, and I am constantly on the down-elevator stick. Power up above 50% throttle and she starts nosing down. If I use 50+% power then I really have to keep the elevator up to make it stay neutral or climb. Which feels very wrong. It floats amazingly well, but is just hinky launching and then trimming out. |
Joined Apr 2006
It's the height of that motor that's causing you most of the problems with the pitch down on throttle up. It's like a lever...the longer it is the more torque is being applied to the CG. You might have some other fine tuning yet to do but that motor either has to come down to the original height or the thrust angle has to be adjusted.
Joined Jan 2012
That is the conclusion I am coming to as well. I wanted to run a slow motor/big prop, long flight and a few others are doing that. But it might be that this plane is not the one to go that route.
I should just install the original motor at the original height. Get a baseline function test, then decide. Back to the man cave to reconfigure..... |
United States, IN, Greenwood
Joined Jan 2012
I agree with the others that the motor height is the main problem. With the standard thrust angle the greater the distance from the lateral axis the more downward force will be applied because of the increased torque resulting in pitch. That is why this increases under power, the torque offsets your trim adjustments as power increases. As Brner indicates, there are two solutions. Move the motor to the original position or decrease the thrust angle, that is tilt the motor slightly back, That will reduce the downward component of the force. Of course it will take trial and error to find the sweet spot.
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
