Old Nov 23, 2012, 08:48 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I just wanted to post my final 'FPV' flight video of my Bixler! Though she is being retired as an FPV bird she will still be flown either as a quick grabber when wanted, or for experimenting with equipment! Enjoy the final FPV flight video:
Final FPV Flight of the Bixler (13 min 5 sec)
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Nov 23, 2012, 09:04 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by 2500GENE View Post
Trouble-maker.
Thats me.
Eagle202 is offline Find More Posts by Eagle202
Old Nov 24, 2012, 10:55 AM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
Originally Posted by Eagle202 View Post
I wasn't trying to put down your flying abilities.
Not offended... if anything you over-estimate my abilities.
I am waiting for my replacement plane to arrive. I managed to loose my first one in the wind. I am going to try and be smarter this time.
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Nov 25, 2012, 03:15 AM
Zangetsu57 is offline
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
When the elevator servo is actuated on my Bixler, the push rods cause the tail to wag slightly left and right. Is this normal? I've already reinforced the tail with a 4mm CF rod on the inside, and there is a 3mm CF rod along the fuselage bottom (in the groove).
EDIT: I managed to reduce the wag with further reinforcement.
Zangetsu57 is offline Find More Posts by Zangetsu57
Old Nov 25, 2012, 07:46 PM
Joined Sep 2010
Originally Posted by Prof100 View Post
Stuart,
I like the NACA ducts but I just want to try something different this time. I have NACA ducts on my EDFs too (see Squall picture with Naca duct). There is another reason I went with the 3/4" round air inlet. If I decide to do any nightflying mods the 3/4" hole is a perfect place for a nice big bright LED headlight if I decide to add one later.
Bill
Where can I purchase ducts like these? I'm not having any luck finding them on Ebay. Maybe I'm just using the wrong search terms.
Old Nov 25, 2012, 08:48 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
http://parkflyerplastics.com/cart/in...roducts_id=278
jrjr is offline Find More Posts by jrjr
Old Nov 25, 2012, 09:16 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Or, get a plastic spoon and cut the spoon tip off and bingo! Air intake/duct
nightfox7 is offline Find More Posts by nightfox7
Old Nov 25, 2012, 11:03 PM
Joined Sep 2010
Perfect, thanks!
I thought about going this route, but given that the above kit enables the air ducts to look sweet at only $4, I can't pass it up .
Old Nov 25, 2012, 11:35 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
The tip off? I take the handle end off. See my blog, a picture there. Note in and out scoops on both sides. The outlet is over the servo hole.
Mac50L is offline Find More Posts by Mac50L
Old Nov 25, 2012, 11:46 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Perfect, thanks!
I agree, they do look cooler
Cut the tip off to use the tip; effectively cutting the handle off we're talking about the same things
Old Nov 25, 2012, 11:49 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
ParkflyerPlastics.com
Prof100 is offline Find More Posts by Prof100
Old Nov 26, 2012, 01:45 AM
antennahead is offline
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
I want to know how you like the flaps, I have my radio set up to make my ailerons function as flaps, but I don't notice any difference at all except for reduced aileron effectiveness.I have thought of adding flaps as you have, but the reason I would like to do so, is to slave the ailerons and flaps together through radio programing so that When soaring up High and with the nose pointed into the wind, I could slightly lower both ailerons and flaps to see if I could gain a little more lift, kinda like and undercambered airfoil.
Originally Posted by Scorpio9999 View Post
I've been some time outside of this forum.
During my absense here I made several mods to my Bixler.
First is FLAPS. Nothing special. Span and length are equal to ailerons. Pinned hinges and another HTX900 servos. I reversed one servo by myself without any additional modules (weight). If someone needs photos or have questions, just ask.
antennahead is offline Find More Posts by antennahead
Old Nov 27, 2012, 09:37 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Mini Sky Surfer
Should we include the mini in this thread or start its own thread?
http://www.bananahobby.com/mini-sky-...1806-prd1.html
BlitzRCWorks Mini Sky Surfer Flight Review in HD! (7 min 38 sec)
flyvertigo is offline Find More Posts by flyvertigo
Old Nov 27, 2012, 10:24 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
http://www.youtube.com/watch?v=jBZoYe2lkvE
I don't see any issue with talking about the mini. Just as long as you keep your posting short.
Old Nov 28, 2012, 01:05 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
The reinforcement you already had would make vertical motion just about impossible, but would not help too much for horizontal motion. A couple of pieces of carbon fiber, one on each side, would take care of that. And it would not have to be anything heavy either. Some of that very thin CF rod used on indoor flyers would be more than enough. But I would first check to see that your end points are not set so that it is trying to force the elevator beyond it's physical limits. Also make sure the elevator hinges are binding up. Not sure why they might, but if the elevator is resisting the servo it might cause the rear of the fuse to move.
Gord
Gordks is offline Find More Posts by Gordks
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
