Old Nov 12, 2012, 08:52 PM
GLOW POWER is offline
Find More Posts by GLOW POWER
Joined Oct 2012
Does the ARF bixler come with the gold connectors for both the motor and ESC?
Thanks.
GLOW POWER is offline Find More Posts by GLOW POWER
Old Nov 13, 2012, 02:50 AM
Zangetsu57 is online now
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
Originally Posted by HiFlyer371 View Post
Stopped by my local hobby shop today to get an aluminum landing gear for my Bixler when I found these. It's a Parkzone Extra 300 wire landing gear with wheels, $1.99. The wheel pants are also for the Extra and were $3.99. Pants were orange before painting. The landing gear were added to this plane as an after thought. I have a Sky Surfer V4 in transit and will install a landing gear block as part of the assembly.
How does this landing gear work in grass? Would you recommend it?
Zangetsu57 is online now Find More Posts by Zangetsu57
Old Nov 13, 2012, 06:55 AM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Bixler fun
Beating the carp out of my Bixler starting at 1:20.
RC Plane Take Off Crash (3 min 14 sec)
flyvertigo is offline Find More Posts by flyvertigo
Old Nov 13, 2012, 01:26 PM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
Originally Posted by BCSaltchucker View Post
Crashproofing the Nose of the Skysurfer/Bixler
I did a similar thing...although it was after I smashed off the nose of my Sky Surfer. Inserted several long bamboo skewers into the foam for support. It takes hits much better than before, no longer bending at the thin cockpit section.
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Old Nov 15, 2012, 04:10 AM
Joined Oct 2012
Well I finally built and maidened my bixler today and I am impressed with its glide and speed. My ESC is warm to the touch after I unplug, Is this a problem?
I was getting 25 mins from a battery (1300mah) I replaced the elevator and rudder servos with some better ones and I replaced the Pushrods/clevises on the Ailerons and the horns or the Rudder/elevator. My ESC is a Turnigy PLUSH 30amp and the motor is stock. The motor/prop combo does take a little while to reach full RPM (2-3seconds) after full throttle has been applied, Can I alter this Via ESC programing?
Thanks.
Old Nov 15, 2012, 10:20 AM
Billtheboss is offline
Find More Posts by Billtheboss
United States, TX, Comal
Joined Dec 2011
Has anyone tried putting floats on their Bixler? I have a Bixler 2 on the way and I live by a lake and thought it would be cool if it works. Anybody?
Billtheboss is offline Find More Posts by Billtheboss
Old Nov 15, 2012, 03:08 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
I saw floats for the Sky Surfer being sold in China on the TaoBao (Chinese eBay) site.
Found them.
http://item.taobao.com/item.htm?spm=...id=18496580583
Shimmy is offline Find More Posts by Shimmy
Old Nov 15, 2012, 04:02 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Found them.
Wow...now that's a real 查看购物须知明确售后权益 of a deal.
2500GENE is offline Find More Posts by 2500GENE
Old Nov 15, 2012, 04:32 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
It sure as 物须知明 is!
A SS kit to include wheeled landing gear and floats for 198.00CNY ($31.74) can't be beat. Whatcha wanna bet that kits sold to customers in Shanghai have instructions printed in Engrish and not 查看购物须知明.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Nov 15, 2012, 09:44 PM
zyredtea is offline
Find More Posts by zyredtea
Joined Oct 2009
How to install FPV to skysurfer
I am just waiting for the skrsurfer from f-hobby ,http://www.f-hobby.com/index.php?gOo...6&productname=,i saw someone can install FPV ,can you teach me how to install ,thank you.
zyredtea is offline Find More Posts by zyredtea
Old Nov 16, 2012, 01:49 AM
taz101 is offline
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
You might be better off asking here:-http://www.rcgroups.com/forums/showthread.php?t=1533848
LURCH
taz101 is offline Find More Posts by taz101
Old Nov 16, 2012, 08:07 AM
mick3485 is offline
Find More Posts by mick3485
Joined Oct 2011
low throws
I have a frustrating problem with the elevator and rudder throws
can't get more thn 20 angle on the control surfaces
servo throws are ok the linkages are on the first hole on servos and last on control horns and the rod is ok...how the heak???
mick3485 is offline Find More Posts by mick3485
Old Nov 16, 2012, 08:33 AM
pghern is offline
Find More Posts by pghern
Crashing in Melbourne
Australia, VIC, Rowville
Joined Jan 2009
Do you mean the hole closest the center screw on the servo?
With that set-up I can easily understand why you have limited surface movement.
Try middle hole on the servo and middle hole on the control horn.
If that's still not enough, move to the outer most hole on the servo.
pghern is offline Find More Posts by pghern
Old Nov 16, 2012, 08:48 AM
mick3485 is offline
Joined Oct 2011
no i was intendig the last from the servo center...i can't understand...hope it is enought
Old Nov 16, 2012, 08:58 AM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
To get the most throws out of your control surfaces, think of the leverage and movement of the horns/arms. To get optimal throws, you want your control rod to be on the hole furthest away from the servo on the servo arm, and the hole closest to the hinge line on the control horn. This will give you the most possible throw. But, this does put more stress on your servos and you do not get as much torque.
Here's a video to help:
Flite Test - Control Linkages - FAST TIP (2 min 9 sec)
nightfox7 is offline Find More Posts by nightfox7
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
