Old Nov 07, 2012, 08:37 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by Shimmy View Post
I will be putting a Turnigy D2826-6 in my new Bixler1 kit. I have read here that some people reverse the motor mounting so that the motor is completely outside the foam of the plane.
Is this necessary? Is it recommended?
Shimmy
I've got that motor on mine flipped around on the original motor mount can.
Then I burned a slot thru the housing below the motor and slid an 8" 'zip tie' thru and sinched the whole thing up. Rock solid and if I have to get it out I just snip the zip tie. Don't glue that mount in and don't use an 'inrunner'.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Nov 07, 2012, 11:30 PM
koumou is offline
Find More Posts by koumou
Koumou
Joined Jan 2005
Description:
Description:
Description:
Name: temp plate.jpg
Description:
My motor gave up lately so I replaced it with a BC-2826/6 2200Kv. I used the motor mount that came with my Bixler to make a new one as shown in the pics. I used thin CA to hold it together and the the two sticks going through are kebab sticks.
koumou is offline Find More Posts by koumou
Old Nov 08, 2012, 09:15 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
DJ
Sculptor,
Could you post a picture of that. I think I understand, but a pictures worth a thousand words.
This outrunner mount should put the prop further from the fuse. Do you use a bigger prop ?
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Nov 09, 2012, 12:03 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Shimmy
It is probably better to have the motor outside so that it gets airflow for cooling.
BGR is offline Find More Posts by BGR
Old Nov 09, 2012, 10:44 AM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
Easier from a maintenance point of view too.
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Sculptor,
Shimmy
Hi Shimmy, here are some pics. The knife I heat up with a tourch and plung thru foam. The prop is a 'Master Airscrew' 3 blade 7 X 5.
The set up is rock solid.
DJ
Name: Hot knife.jpg
Description: Name: 3 blade prop.jpg.jpg
Description: Name: Motor strap.jpg
Description:
Old Nov 09, 2012, 07:46 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by koumou View Post
Attachment 5289363
Attachment 5289364
Attachment 5289365
Attachment 5289366
A wonderfully simple and effective solution! It is amazing what you can do without a machine shop and aluminum if you just spend a little time thinking about it. I might have put a couple of small pieces of dowel in compression in the gap to give it four points of support, but I suppose the foam itself tends to keep it from vibrating at right angles to the two dowels anyway. I would likely been well into the land of the unnecessary.
Gord
Gordks is offline Find More Posts by Gordks
Old Nov 09, 2012, 07:53 PM
Gordks is offline
Joined Mar 2010
DJ
Attachment 5292001 Attachment 5292002 Attachment 5292003
That is another of those wonderful ideas that costs almost nothing at all, does the job extremely well, and that I probably would have successfully avoided ever having thought of. Love it!
Gord
Old Nov 10, 2012, 05:16 PM
Shimmy is offline
Joined Jun 2012
DJ
Thanks. This is much clearer to me now. I had it twisted in my head.
So the zip tie goes through the foam and through the reversed motor mount ?
I see that you use a 7 inch prop. That answers my second question.
I ordered the Bixler Kit. I hope that it comes with the motor mount.
Shimmy
Old Nov 10, 2012, 05:52 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Shimmy
No Shimmy, the zip goes thru the foam under the motor and tightens up the foam against the mount. The V2 comes with this can but the basic Bix has a stack of plywood pieces as a mount. I would glue those all thgather (ALL, if you don't use them all the screws will go into the windings, did that). But I'd still not glue it in.
DJ
Old Nov 10, 2012, 08:06 PM
Zangetsu57 is online now
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
For the folks that keep their fuselage halves unglued for access, how do you attach the horizontal and vertical stabilizers? I thought about doing Lafayette's mod (http://www.rcgroups.com/forums/member.php?u=288699), but am worried that it wouldn't be very secure unless the fuselage halves are glued.
A bit of background: I'm using strong rate-earth magnets to keep the fuselage together (with tape along the seams). They click very nicely! I just hope the magnetic fields don't impact the performance of the electronics, namely the 2.4 GHz Rx for control.
Zangetsu57 is online now Find More Posts by Zangetsu57
Old Nov 11, 2012, 04:14 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Crashproofing the Nose of the Skysurfer/Bixler: I am sure this has been done by dozens of folks before, but just though I would refresh the idea with some improvements.
I wanted to solve 2 of the major shortcomings of the Easy star type planes we all love to fly: improve access to the hatch area and preventing destruction of the front fuse walls during nose-in crashes
I cut the hatch towards the nose a few more inches. Then I Gorilla Glued some ply walls to the sides. The poly GGlue expanded and fills around the foam and ply making it very stout. I then made a new hatch cover with plywood, which adds a third side to the plywood box. Retained with a bit of chopstick going into a hole in the nose cone, then velcro strap to the outside of the fuse in back. Also convenient for all my FPV electronics.
Now I have had some real nasty crashes lately. Yesterday overshot the landing zone and went headlong into a fence. With Zero damage! No compaction of the foam sides, as we usually see.
Note: the sides were already bent a bit from pre-reinforcement crashes
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Nov 12, 2012, 02:51 AM
GLOW POWER is offline
Find More Posts by GLOW POWER
Joined Oct 2012
I wouldn't consider a front fuz that cannot take a huge crash a 'Major Shortcoming'. This is the problem with foamies, (particularly the Bixler/ez star) they all take so much abuse that people lose respect for them. I fly balsa models that are considerably harder and more challenging to fly than my hawksky but somehow I still crash my hawksky way more than my balsa glow planes.
GLOW POWER is offline Find More Posts by GLOW POWER
Old Nov 12, 2012, 12:57 PM
Joined Sep 2010
Originally Posted by greedyg76 View Post
Lower temp = less amps = more flight time
How did you get such a nice clean cut?
Old Nov 12, 2012, 01:31 PM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
I woulds suggest by using brand new Exacto clone knives rather than (even slightly) used ones. As those things are DAMNED sharp when new.
On quite a few occasions I've only just brushed my skin with with a new one and it's drawn blood.
Buy 100's of blades and replace very often - as they are 'cheap as chips' as that 'English Gentleman' (Scott?) on the Hobby King videos refers to EVERY item he 'reviews' for them!!
I only use the cheap plastic knives with the snap-off blades for not so delicate work.
-B!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
