Joined Nov 2011
Bixler Standard Motor Query
Hi there! About a year ago I bought an rtf Bixler. Apart from a loose canopy magnet and a loose control horn , it worked very well . However the brushless motor makes a fair bit of noise compaired to the Skysurfer 780 which comes with a brushed motor . Question : Are brushless motors always much noisier than brushed motors, or is this only the case with the standard Bixler motor? Thank you,Gerhard 807gt.
Joined Nov 2011
Hello everybody! I have recently bought a Skysurfer 780 from HK . It arived safely and complete . Among other things , the package contained a cute little balanced charger ."Nine Eagles NE-C912". Input is 12 volts , output current 600 mA , suitable for 2 cell lipos . Checking HK's chargers for sale, I could not find it. Does anybody know the part number , as I would like to buy 2 of them? Thanks in advance, Gerhard 807gt
Noise
AJ |
Charger 4 U
AJ |
Motor stuff
AJ |
Chilliwack, BC Canada
Joined Mar 2010
I've got one, it works great, but it is more complicated to use and requires more wires to connect the battery so if you don't need the extra capabilities you are probably better off with AJ's suggestion. ![]() Gord |
Joined Oct 2012
I think I got that right if not please correct me
"What the World needs is a new simplicity not a new complexity" - Albert Einstein DJ |
Many years flying in flight simulators I went thru painting, scenery and aircraft modelling, tuning of aerodynamics and writing gauges. I got some knowledge from that hobby. COL (center of lift) is fixed for particular airfoil and you cannot change it's location without replacing the wings. But you can change location of center of gravity by moving of weight distribution in aircraft. This is why in real aviation they calculate the map of passenger and baggage distribution between cabin and cargo sections and in R/C aviation we moving batteries or adding a ballast. So, the second statement could be as right as wrong. This is why in docs or forums for Bixler or SkySurfer CoG published as 61mm. Just to be sure that this aircraft will remain as glider. |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
