Old Oct 08, 2012, 08:58 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
ajbaker is offline Find More Posts by ajbaker
Old Oct 08, 2012, 09:16 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by taz101 View Post
Your better off asking in the BIXLER2 thread.
At least in that thread everyone has one!!
LURCH
+1, It's a whole different plane the B2, with all it's mods. It's not a better plane, it's bigger.
Seems that the market wants this plane to be an FPV platform and the Bigger is about that.
I still like the Blitzrc Sky Surfer V4 better, and the the B1 kit.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Oct 08, 2012, 09:23 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
DJ
And, heck, we may as well mention this one, too -> The Super Sky Surfer. 2400mm (~8 feet) wing span
AJ
Old Oct 08, 2012, 11:36 PM
Zangetsu57 is offline
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
Originally Posted by Scorpio9999 View Post
Paul,
I purchased these clevises.
http://www.hobbyking.com/hobbyking/s...idProduct=8421
Originally I assembled Bixler with default clevises and rods for ailerons. I crushed on third flight (tip stall) and found rod separate from plane with broken clevis. Reason of the crush?
Now my rods looks like this.
Attachment 5212343
Also you can see mod to fix tail. May be you want do this way.
Attachment 5212344
Just drill small default hole with drill bits MANUALLY with step of 0.5 mm to 6 mm.
You can see small piece of tube (taken from pen) hot glued on leading edge. It prevent rudder rod from unneccessary bend. When it's bend rudder works worse.
In fuselage I glued small piese of tube (taken from foam sprey) which hold 6x75 mm nylon bolt in proper position and doesn't allow smash the fuselage when you screw it in.
Attachment 5212345
And finaly custom motor mount made from PVC adapter from 20 to 30 mm.
Attachment 5212347
I like your PVC motor mount! Would you mind explaining exactly what type of adapter it is? I live in the USA and unfortunately PVC is measured in English units. Do you think a 3/4" to 1 1/4" adapter would work?
Zangetsu57 is offline Find More Posts by Zangetsu57
Old Oct 09, 2012, 02:36 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Please read the title of this thread
For a 28mm motor, you can use either a:
3/4" to 1" adapter and grind out the middle with a dremel
OR
1" - 1-1/4" adapter which works out perfectly - no grinding - but, it had a bigger O.D.
Finally, Read page #1 Post #3 of this thread. There are several motor mount methods.
AJ
Old Oct 09, 2012, 04:19 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
morning all
i have just fitted an APC 6x4 prop onto my Bixler, it seems to be alot slower than the standard prop
anyone else noticed this?
the writing on the prop is facing the rudder so im guessing its the correct way around?
mudcow007 is offline Find More Posts by mudcow007
Old Oct 09, 2012, 05:15 AM
pghern is offline
Find More Posts by pghern
Crashing in Melbourne
Australia, VIC, Rowville
Joined Jan 2009
Originally Posted by mudcow007 View Post
morning all
No - big mistake - words on the prop always face to the front.
You were probably only getting 60% thrust.
Turn it round and have some fun
pghern is offline Find More Posts by pghern
Old Oct 09, 2012, 06:01 AM
Liverpool, UK
Joined Jul 2006
fantastico!
a quick spin around an the prop seems waaaay better!!
thanks
Old Oct 09, 2012, 06:55 AM
Scorpio9999 is offline
Find More Posts by Scorpio9999
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
Just divide size in mm on 25.4. You will get inches. Size I mentioned is internal diameter of adapter. Just take sliding caliper with you to shop and find what is better for you. Small external diameter should be as default motor - 26mm ~ 1inch.
Bigger external diameter should be as size of "X" mount plate of YOUR motor. Then you need to cut unneccessary length from bigger side. Be ready that CG will be moved backward. I put almost all washers back in nose as I haven't extra electronics even with 2200mah battery.
P.S. Sorry for my ugly English. I'm Russian.
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Oct 09, 2012, 08:49 AM
Liverpool, UK
Joined Jul 2006
fantastico!
thanks
just an update, my bixler is a whole lot better with the new prop (6x4) the correct way
it seems to basically go verticle at full throttle an will quite gladly fly around on 15 - 25%
im worried that i had to make a channel in my fuselage for the prop though an others didnt
Old Oct 09, 2012, 10:12 AM
nightfox7 is online now
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
On my skyS, I cut about 2-3mm off the tips of the prop to give it enough clearance. Mine is a v4.
I'll post what I have done to it when I get home.
nightfox7 is online now Find More Posts by nightfox7
Old Oct 09, 2012, 10:31 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Name: 7x6e prop copy.jpg
Description:
Hope this is correct please proof this and tell me if this is right.
Athow this right way wrong way prop problem is evident to me now is was not when I started building planes. If all this is right it might help someone.
DJ
Old Oct 09, 2012, 10:36 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Nope. There are many props out there that have the letters/numbers on the back of the props. i.e. putting the letters forward applies to APC props but not to props made by Multiplex. Everyone should disregard any letters or numbers anywhere on the prop and follow the picture below to make sure that the prop is oriented correctly.
AJ
Old Oct 09, 2012, 10:49 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
AJ
Thanks, I changed it.
DJ
Old Oct 09, 2012, 10:50 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Attachment 5218166
DJ
Proof read?
Ok, you spelled "leading" wrong.
2500GENE is offline Find More Posts by 2500GENE
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
