Old Oct 05, 2012, 05:06 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by 2500GENE View Post
Wow. I guess I over did mine a bit.
And I thought you were a Giant fan.
Eagle202 is offline Find More Posts by Eagle202
Old Oct 05, 2012, 05:16 PM
ppridday is offline
Find More Posts by ppridday
Breaker of Things
ppridday's Avatar
United States, MN, Detroit Lakes
Joined Mar 2005
OK, I got the new control horns and will put them on all surfaces, but in the meantime broke one of the clevises for an aileron. Was it ever determined which would be the best replacement clevises (clevi? ) for the Bixler for the aileron surfaces? I know in the thread there are posts about the rudder/ele...
Paul
ppridday is offline Find More Posts by ppridday
Old Oct 05, 2012, 05:30 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by Andreasdiaz View Post
I recommend you to undo it, because it will be a nightmare in flight, plus it can break the boom in the worst case scenario
You're just saying that because you're not a Cowboys fan.
Hell no. Eagles all the way.: I was in Southern NJ, 10 miles from Philadelphia. We bleed green around here.
2500GENE is offline Find More Posts by 2500GENE
Old Oct 05, 2012, 06:01 PM
ppridday is offline
Breaker of Things
ppridday's Avatar
Joined Mar 2005
Packer Green???
Paul
Old Oct 05, 2012, 06:12 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Originally Posted by ppridday View Post
Packer Green???
Paul
Ha. Love Arron Rogers though.
I read some where he has a Bixler. (to stay on topic so aj don't burn us.)
Old Oct 05, 2012, 06:35 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
So when are you going to paint you Bixer Eagles Green?
At least I can't complain about the name of your favorite.
Old Oct 05, 2012, 10:14 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Limited Duties
. Ah, heck. It's Ok. A few of yousse guys understand the posts deal. I only have a problem when 1-3 guys go Off Topic for an entire page or two. Besides, I ain't a George Orwell. I am just the lowly librarian I appreciate everyone here (except one).
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 05, 2012, 10:17 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Green Plane
+1. I would like to see His efforts, too.
AJ
Old Oct 06, 2012, 06:56 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Originally Posted by ajbaker View Post
+1. I would like to see your efforts, too.
AJ
Me too. My priority has been new job. RC Flying has taken back seat for now.
I am interested in seeing videos of your new jumbo SS. How goes the build and is there anything to look out for in the way of modifications to the design?
Old Oct 06, 2012, 07:24 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The SSS and ....
FWIW, It is called an SSS (Super Sky Surfer). As for mods, you might want to read the thread about it while it is still small.. I will PM you on another subject that I uh.. uh...
AJ
Old Oct 06, 2012, 07:32 AM
aargee is offline
Find More Posts by aargee
Joined Feb 2011
Originally Posted by jrjr View Post
I would get it as close as you can. Sometimes just the density of the foam differs from one wing to the other which makes it weigh more than the other.Try taping a penny to the end of one wing and see if it balances. If its way too much maybe just a straight pin or 2 pushed into the end of the wing will do. Perhaps a 6p nail and keep cutting it shorter till it balances. Get it balanced and your maiden flight will go much easier for you.
Thanks jrjr and Scorpio9999 - I'll try unbalanced first but it turns out to be one nose washer on the wing if I need it!
aargee is offline Find More Posts by aargee
Old Oct 06, 2012, 11:29 AM
ppridday is offline
Breaker of Things
ppridday's Avatar
Joined Mar 2005
As I will be putting my Bixler together for the first time and I am sure will want to open it up to rearrange frequently to fix and fiddle; I was thinking of only gluing the halves at certain areas. Kind of like stitch welding if you will. Has anyone done this before as opposed to fully gluing the two halves together? Any reason not to try this?
Paul
Old Oct 06, 2012, 11:33 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Paul
It should work out just fine. You might want to try taping the halves together, first.
AJ
Old Oct 06, 2012, 12:17 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
AJ
You call 66 pages and almost 1000 posts small. Of course I can skip over Acorn's posts.That should save some time.
The SSS looks pretty cool. Nice and steady for multiple cameras. Almost like one of those Providians that Scott and Bop fly in Iowa. Unfortunately I really don't need another plane. I already have 3 and a couple of park flyers that I have no time to put into the air now. Having something that big would also mean a bigger vehicle to cart them all around.
I'll just focus on my little SS for now and my ZII (but that is for another thread )
Vince
Old Oct 06, 2012, 01:12 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Paul
On my fist EZ* I used Glue Dots every 2 inches or so and then taped the seams with clear packing tape. Easy to open up and make changes.
http://shop.hobbylobby.com/search/?k...h=AND&F_Sort=2
Lasted 4 years without a problem....until that gator ate it and I had to get a new one. Heard they taste like chicken.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
