The Bix 2
![]() AJ Oh, BTW, I ordered 6 LiPo's, too. That means boats only and no airplanes for transportation. I hope to have everything ($479 of stuff) by Christmas of 2013. ![]()
The report button has nothing to do with sharing information.. you use that if there is something offensive or otherwise inappropriate in the post.. i'm not sure i know what you mean here..
You can click on the post number, say yours is #17072, and it shows the single post. Then you could copy the URL and share it like this: http://www.rcgroups.com/forums/showp...ostcount=17072 |
Thanks again, DJ |
You can use your 25A ESC, IF...... you use a 5x5E prop or 6x3E prop. If you use anything larger, you might have a flamer. Ask me how I know. AJ |
AJIf you provide a report of all 100 of your motors I believe you will hit a goal of a thread that has the most pages. ![]() ![]() All kidding aside. Having you and others provide first hand experience with hardware is a great way to find the right part without draining your wallet. Keep up the great work. ![]() Vince |
Thank you for calling the troops to help me thru doing this, DJ |
FWIW. As a guideline, I always use an ESC rated at 10A larger than the largest current that the system (read mostly motor) is going to use. Many, (way too many) folks get themselves into big trouble by using an ESC that is too small for their system. It is easy to dupe oneself into believing it is ok because.... after all.... the motor sounds just fine. I distinctly remembered the day that plane (parts shown earlier) caught fire (literally) in the air. It was as quiet as any electric plane. It just a scant few seconds of smoke that I saw, then, fire, then, only one servo was salvaged from the entire plane. And, your might ask, whose fault was that.....??? Well, mine. I was using a 25A ESC and the system was pulling 32A. That is actually all fine and well as long as I stayed below 2/3 throttle. But, at WOT, after 30-40 seconds, the fire started and the plane was totally toast (except one servo). From that day forward, I never and I mean NEVER use an ESC that is less than 10A over the max. Kissing $100+ goodbye kinda puts a sour taste in my mouth along with the humiliation that I know better that to let something like that happen. Ok.... That's it. I am getting off my soapbox now. Thanks for the props. ![]() AJ |
Well gents I got my MicroDan today and things start getting to pi*^%*ing me off LOL
The pro hole is too large to fit the shaft the insert ring hole is too large for the shaft I managed to find another 3mm safety prop mount but the prop get too wobbly on it :-( ( as a note, prop came in perfectly balanced) so now I have to order prop adapter for 3 mm shaft, another delay :-( |
Your a Prince AJ, DJ |
Information
![]() AJ |
Joined Sep 2010
I'm ordering a bixler and am reading that I should replace the control horns with Dubro 1/2A #107. Can someone confirm that this is a good horn to use? Are there "snap on" alternatives such as the ones provided with the Axn Clouds, so screws aren't needed?
Also, which size clevis should I get, and can they be placed on the original control rods that ship with the bixler kit? Finally, I have a RCtimer 2826-6 2200kv motor that I intend to use. What would be a good motor mount? Thanks! |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
