Old Sep 23, 2012, 08:52 PM
Thirston is offline
Find More Posts by Thirston
United States, NC, Charlotte
Joined Jul 2012
I've had my Bixler v.1 for a couple of weeks now just sitting in the box. I had bought the PNP Kit from HK USA warehouse and ran into the problem with short motor wires barely extending from the top of the fuse into the rear canopy area. Rather than make extensions I just cut out the area behind the cockpit to make access.
Got her in the air this morning with a Turnigy 3S 2200 20-30C and she flew like a dream.
This evening I tried out a Nano-Tech 3S 1300 25-50C and is was porpoising like crazy.
The 2200 battery weighs 6.7oz (190g) and the 1300 battery only weighs 4.0 oz (110g). I guess I need to find a way to add a few ounces to the front of the plane when flying the 1300 batteries. Any recommendations?
I also wound up with a broken control horn on the rudder. I had read about the weak hardware but figured I'd try out the plane stock... bad idea. I should have upgraded the horns beforehand. Now I have to figure out how to get the Gorilla Glue to release the stock horns so I can upgrade them.
I have 2 meters of LED strips I can't wait to get on this plane. It'll be great to be able to fly a little after dusk.
I think I'll add some colored packing tape as well. The white wing bottoms make for a little confusion when there's some distance between me and the plane.
Thirston is offline Find More Posts by Thirston
Old Sep 23, 2012, 09:15 PM
BGR is online now
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Originally Posted by polyfractal View Post
So I maidened my Sky Surfer this weekend. Managed to smash it into pieces yesterday, taped and glued it back together and took it out for another spin today. Today's flight was a lot better...a lot fewer crashes.
However, my plane tends to bank to the right by itself. I checked and all the control surfaces are even when the power is on and everything is trimmed neutral. Once in the air though, i had to trim the ailerons heavily to one side to compensate for the natural banking. Any ideas what's going on? I'm still reading through this massive thread, so apologies if this is a commonly addressed problem.
This roll behavior is something that i had to deal with on my AXN. The AXN is similar to the SS or Bixler. The cause as far as I can determine is a combination of 2 things, motor/prop torque and the prop wash hitting the tail surfaces on one side more than on the other. The motor is pointing right at the tail so this made sense to me.
My solution was to program a throttle to rudder mix that moves the rudder slightly to the left in proportion to the throttle setting.
BGR is online now Find More Posts by BGR
Old Sep 23, 2012, 09:25 PM
BGR is online now
BGR
BGR
Foam Junkie
Joined Dec 2003
2.7 ounces of bird shot in a little bag. Seal well, you don't want that bird shot rolling around inside the fuse.
Old Sep 23, 2012, 11:35 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Originally Posted by nightfox7 View Post
Hey i will be receiving a SS from a friend soon (its V2 or above from my understanding) and i have been looking through the mod page. I can handle pretty much all of them, i am just confused on fuse reinforcement for the V2 or above. I want to make a small FPV backpack to go on it sometime, so i assume i want to do some sort of reinforcement, but i would also like to keep it light so i can do a little sloping if i get the chance. I have experience flying so thats not a problem. Just looking for input Also, any other mods that are recommended other than the wing spar/fuse reinforcement and something to hold the wings together?
-Seth
Anyone?
nightfox7 is offline Find More Posts by nightfox7
Old Sep 24, 2012, 01:52 AM
Zangetsu57 is online now
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
How well does the RCtimer 2212-6 2200kv work for the Bixler? I originally purchased one as an upgrade to my Axn, but I might purchase a Bixler kit for FPV. Does the 2212-6 provide enough thrust, or are there better alternatives?
Zangetsu57 is online now Find More Posts by Zangetsu57
Old Sep 24, 2012, 02:56 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
You took the washers out? Glue them together and add a bit of Velcro to them and the top of the battery. Add them when needed.
I peeled the rudder one off (easy) to fit on to the aileron when I lost the aileron one. I made a replacement horn for the rudder.
I've painted the under wing tips orange and "Invasion Stripes" (as on WWII allied aircraft) on top of the wings. Makes spacial identification much easier.
Mac50L is offline Find More Posts by Mac50L
Old Sep 25, 2012, 03:30 AM
elskan is offline
Find More Posts by elskan
Joined Sep 2012
hi.i am totally noob on this hobby.i have ordered D2826-6 2200kv Outrunner Motor and TURNIGY Plush 30amp Speed Controller from hk.now i need a lipo.can you please tell me is this lipo suitable for my bixler and what is the best lipo i can use on this system?
http://www.hobbyking.com/hobbyking/s..._3S1P_40C.html
elskan is offline Find More Posts by elskan
Old Sep 25, 2012, 10:23 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Good choice. I sometimes use an 1800mah 3S1P 25C for my planes. Either one will work fine. Even a 2000mah 3S1P would be just as good.
AJ
P.S. I normally use a 1300mah 3S1P with a gyro. But, I would not recommend that until you get a lot of flying experience.
ajbaker is offline Find More Posts by ajbaker
Old Sep 25, 2012, 10:46 AM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
AJ
I have this same motor setting on my desk and am trying to figure out how to install it in my new Bix 2. Any ideas and if this has been covered forgive me.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Sep 25, 2012, 12:34 PM
elskan is offline
Joined Sep 2012
AJ
Thank you so much i av just ordered lipo.i hope i can make my bixler flyable asap
Old Sep 25, 2012, 06:29 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
-Seth
Seth, did you mean you DON'T need mods for holding the wings together? If so, my apologies - please ignore this post!
For my SkySurfer and Easystar, I used a light weight spring from Home Depot.
Basically, there's a spring sticking out under each wing, that hooks on a hook glued to a plywood square on the bottom of the wing.
The advantage (aside from lighter weight) is that, if I hook a wingtip on something while landing (or crashing), the wing will flex back in its socket, I hope, instead of breaking off or tearing up something inside the fuselage.
I did this on my older SkySurfer and Easystar planes. Have had several hairy encounters with rigid objects, but no broken wings, except when I dove the Easystar straight into the ground from 75 feet up, oops. Even springs have their limits.
For details, see:
http://www.rcgroups.com/forums/showt...0#post18638270
and
http://www.rcgroups.com/forums/showt...5#post20659067
Little-Acorn is offline Find More Posts by Little-Acorn
Old Sep 25, 2012, 09:39 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
For details, see:
and
Yes i meant i dont need mods for the wings as i have what i'm going to do figured out pretty much
but thank you for the reply, i do like what you have done!
Old Sep 26, 2012, 12:47 AM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
DJ
Hi DJ
I installed this motor and put up a couple of photos on the bixler 2 thread. Basically you remove motor mount reverse it and reinstall. Would link it but on the phone. Will send a link when I get home if you haven't found it.
Cheers
Gim
Gimmer is offline Find More Posts by Gimmer
Old Sep 26, 2012, 01:14 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Some thoughts on the Bix2
DJ
Darn it. I pretty much have to give you the same non-answer that I gave you once before (I think). Since I don't own a Bix2, any information that I gave you would be just an experiencial guess based on the Sky Surfers that I own. If you are referring to the D2826-6 2200Kv from HK (I own 2 of them), I know it works great on a Bix1 or SkyS v1-v4. FWIW, since I started this thread, I feel obligated to buy a couple (2 is better) so I can answer some questions from you and others. Right now, I just ordered one (about 15 minutes ago). So, if someone else has some experience to share, it would be appreciated. For you and the rest of us that are interested. Meanwhile, if you are patient, I will share the information on any/all motors that I use in that plane. If not, I am sure you have read the same basic opinion that most of the owners have -> It is underpowered with the current motor. I am sure that the advertised weight probably does not include the weight of the lipo or other stuff. Maybe some kind soul will post the "real" AUW of their Bix2 plane. I hope all these bits of info are somehow useful to you.
AJ
Old Sep 26, 2012, 02:43 AM
Gimmer is offline
Gimmer's Avatar
Australia, QLD
Joined May 2011
Originally Posted by Gimmer View Post
Hi DJ
Cheers
Gim
Here is the link:
http://www.rcgroups.com/forums/showp...&postcount=132
I used a hair dryer to soften the glue and slowly prised plastic mount back and forth. Mine came out nice and easy but some others seem to be glued in well. The 2826/6 2200kv with a 7x4 turned Bix 2 into a rocket. I wasn't happy with the BIx 2 (ordered another Bix 1) The Bix 2 will be gifted to my father as his first RC plane.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
