Old Sep 09, 2012, 11:44 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
That is going to be the quickest way to cook the motor, don't forget the rule outlet about 3 times the inlet for reasonable air flow. It might work if you are just using it to get some height and glide around, but I wouldn't use that method for mounting.
clive45 is offline Find More Posts by clive45
Old Sep 10, 2012, 03:19 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
+1. Also, at 3500Kv, I suspect that the motor will turn into an oven in less than 30 seconds and the motor will just fly around freely after the motor melts away the low grade plastic. All in all, I think it is a very bad idea.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 10, 2012, 11:18 AM
krise is offline
Find More Posts by krise
also known as ke123
krise's Avatar
Canada, AB, Edmonton
Joined Dec 2007
<sniff> <sniff> is something burning?
krise is offline Find More Posts by krise
Old Sep 10, 2012, 02:57 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
AJ
If you've got little airflow, it's true that you might overheat things. Good airflow is way up there in importance.
3500KV alone, won't cook things, though. I've been flying my Bixler (actually a SkySurfer, same difference) with a 2835-3900KV motor for more than a year now, and a 40A ESC and 2200mAh 3s battery, and haven't cooked anything yet. In fact, the motor's barely gotten warm.
Only time it gets warm is when I do vertical climbs... because that's almost the only time I fly full throttle with that motor. If you fly full throttle all the time with a motor that powerful, then you should get a Spitfire or some other plane designed for that kind of speed/power. The Bixler is a powered GLIDER, don't forget!
Powerful motors like that are mostly for occasional stunts in a plane like a Bixler. You'll probably do most of your flying a half throttle or less - which gives you decent climbs and even stunting ability with the Bixler. Full throttle are for vertical climbs and occasional wild stunts.
http://www.rcgroups.com/forums/showt...v#post20525265
http://www.rcgroups.com/forums/showt...9#post19830562
http://www.rcgroups.com/forums/showt...3#post19740244
http://www.rcgroups.com/forums/showt...3#post19739017
As I said, if you spend almost all your time at full power with a motor like that in the Bixler, then you're probably flying the wrong plane.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Sep 10, 2012, 03:02 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Have you seen his motor mount LOL BBQ time
Simon2504 is offline Find More Posts by Simon2504
Old Sep 10, 2012, 05:55 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yous is a Great simple visual
hee, hee, hee. +1. I have flown one of my Sys's with thar same 3900Kv with no heat problems. However, it is totally in the open air - not enclosed in a "coffin" (or BBQ as you said).
AJ
Old Sep 10, 2012, 06:07 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
simple motor stuff
3500KV alone, won't cook things, though. .
I am aware of all of that. I have experience with hundreds of motors. In general, high Kv = lots of heat (caused by lots of i, e, p {and/or small r}). Low Kv motors = less heat (even though they too can get overheated for the same reasons). Along with the above is one of the common things that I read about is folks that over prop these small motors which causes burn out, too. IMO, if anyone even looks at using something other than a stock prop, it should be MANDANTORY have a watt meter. Without it, it is like trying to put on matching socks in the dark.
AJ
Old Sep 10, 2012, 06:12 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Is that why I always have odd socks on....must get a daytime job
Old Sep 10, 2012, 06:13 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
... IMO, if anyone even looks at using something other than a stock prop, it should be MANDANTORY have a watt meter. Without it, it is like trying to put on matching socks in the dark.
AJ
Not necessarily, if you are conservative and use a watt/thrust calculator, you can get a prop that uses similar watts to original setup, but aim a tradeoff between thrust or speed.
sammyc is offline Find More Posts by sammyc
Old Sep 10, 2012, 06:17 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
AJ
+1 DJ and don't even fully understand what you said.
Sculptor is offline Find More Posts by Sculptor
Old Sep 10, 2012, 07:58 PM
San Diego, CA
Joined Dec 2006
I'd imagine that's true. And yet, my 2835-3900KVs (in a SkySurfer and an Easystar) have never overheated.
Perhaps if someone puts them in a plane that doesn't need their max power, and provides good airflow through them, and flies them at 2200KV-like power levels most of the time (which still gives 2200KV-like power, good for lots of stunts, climbs etc.), with only a few 3900KV-full-power climbs and stunts thrown in while letting it run cool the rest of the time....
....perhaps that's the best way to treat one of these high-power motors and make it last a long time, and still do all the stunts you want, despite the "in general" predictions?
6x4 Master Airscrew 3-blade, direct drive, no burnouts yet, case gets barely warm.
These motors have "stock" props?
Old Sep 11, 2012, 12:55 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
My new SS paint job :-))needs some final touches
nakelp86 is offline Find More Posts by nakelp86
Old Sep 11, 2012, 01:02 AM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Looks good 86
Old Sep 11, 2012, 07:57 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The plane comes with a "stock" prop.
AJ
Old Sep 11, 2012, 08:12 AM
taz101 is online now
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
BIXLER2 kit available.
Hi guys,
Just letting everyone know that the BIXLER2 KIT is now available in the international warehouse!!
LURCH
taz101 is online now Find More Posts by taz101
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
