Old Sep 09, 2012, 04:15 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
I suspect that the low throttle position is not low enough. Try putting throttle trim all the way down and/or go into the servo travel menu and take the throttle further down. Many a time various ESC will not arm because of this. I also do not know of an ESC that does not have this arming protection.
clive45 is offline Find More Posts by clive45
Old Sep 09, 2012, 04:43 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
Its fixed!!
i reset it back to factory defaults 3 times an now it lives
well aslong as its working
thanks for all the suggestion/ help
now i can maiden my bixler now
mudcow007 is offline Find More Posts by mudcow007
Old Sep 09, 2012, 06:01 AM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
Finally got my Bixler playing nice with trees
FPV Bixler Tree Roll. (0 min 31 sec)
Gimmer is offline Find More Posts by Gimmer
Old Sep 09, 2012, 12:31 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
http://www.youtube.com/watch?v=hb4iUWIstk4
Wohoa that's tight. Fence wire below and tree branches above! Is that FPV or just by eye at a distance? If it is the latter, you have amazing eyes.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 09, 2012, 03:58 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by mudcow007 View Post
Its fixed!!
Ernie says "cool beans".
2500GENE is offline Find More Posts by 2500GENE
Old Sep 09, 2012, 03:59 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Gord
That was a luck shot. He went home and changed his shorts soon after.
Old Sep 09, 2012, 05:19 PM
Gimmer is offline
Gimmer's Avatar
Australia, QLD
Joined May 2011
GordThat was a luck shot. He went home and changed his shorts soon after.
I was flying FPV and yes was almost a pants change needed. Lots yahooing and carry on after the bix made it home in one piece though.
Old Sep 09, 2012, 06:59 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Good for you. Nice vid too.
Old Sep 09, 2012, 07:04 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
whow, great recovery. You are one lucky dude :-))
nakelp86 is offline Find More Posts by nakelp86
Old Sep 09, 2012, 07:10 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
What about the tree branch?
Eagle202 is offline Find More Posts by Eagle202
Old Sep 09, 2012, 07:20 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
most likely its still there :-O
Old Sep 09, 2012, 08:20 PM
kkanzelmeyer is offline
Find More Posts by kkanzelmeyer
Joined Sep 2012
Bixler motor mod
After I bought my first Bixler, I let my brother fly it, and he crashed it. The plane landed on it's nose and it was permanently warped. He felt awful, I told him not to feel too bad because he would be buying me another!
With my new Bixler, I wanted to make some mods that might prevent the same kind of damage to the nose. So I bought a sheet of woven fiberglass cloth for $6 and some resin for $13. When my new plane arrive, I coated the inside of the each half of the nose with resin and applied two layers of fiberglass cloth. When it dried, the nose was substantially harder. The added weight was almost negligible!
Also like everyone else with a Bixler, I wanted a better motor. I bought a larger more powerful park series outrunner motor (something like a 430L, 3550KV) and a 50 amp ESC. I browsed dozens of solutions to the removable motor problem and I couldn't find one that I really liked (most require major body mods, tons of time, or special tools) I didn't want the engine hanging out the back like the metal motor mount available for $15 (and I didnt want the extra weight!). Then today a solution finally came to me! I haven't seen this anywhere yet, but if you have let me know.
I used an old plastic film canister for the motor casing =). The top of the canister (grey in the photos) was attached to the motor, and the black canister can fits almost perfectly into the bixler motor bay. You'll need to remove a little of the styrofoam, but not much. It fits really well. I used bonding resin to secure the canister body inside the motor bay. Be sure to drill a hole in the bottom for the motor wires. My motor has motor mount screw holes on the top and bottom of the motor body, so I was able to attach the lid of the canister to the top of the motor.
The result is a super easy, super effective motor mount that allows the user to easily remove the motor. It requires minimal scalpel time with the plane (a big plus in my book), and it requires only a $0.20 film canister!
kkanzelmeyer is offline Find More Posts by kkanzelmeyer
Old Sep 09, 2012, 08:57 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Im pretty sure that motor will cook itself stuck inside with very little airflow
Simon2504 is offline Find More Posts by Simon2504
Old Sep 09, 2012, 09:42 PM
Joined Sep 2012
There is hole at the bottom of the canister where the wires exit and connect to the ESC. That hole will allow air to enter the can. I'll add some additional holes at the top to allow flow through the canister. Good catch.
Old Sep 09, 2012, 11:26 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
heat problem - maybe
The heat from the motor might melt that very small gauge plastic mount. A word of warning.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
