Old Sep 07, 2012, 06:08 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by Mac50L View Post
That's why they tell you to order a servo reverser as well as the extra servos. The alternative is to rewire the inside wires of one of the servos. Four wires to be resoldered. There is a video somewhere showing how it is done.
+1 DJ and it's easy with this video, don't know where the vid is.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Sep 07, 2012, 07:31 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
This is one of the videos -
How to REVERSE a Servo. (4 min 32 sec)
The other video, the servo had all orange wires and I'd suggested marking one motor and one pot wire so that a wire didn't get soldered back where it came from if you looked away while doing the job and got left and right wires mixed.
Mac50L is offline Find More Posts by Mac50L
Old Sep 07, 2012, 07:42 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
http://www.youtube.com/watch?v=EK_FdRTenl0
Thank for this I couldn't find it for him (too lazy to look for it?)
DJ
Old Sep 07, 2012, 09:42 PM
Mac50L is offline
Joined Oct 2011
There are at least 3 videos showing how to reverse a servo. I can't find the link to the servo with all orange wires.
Here is the link to reversing an HXT500 servo. I'd expect the HXT900 to be the same -
How to Manually Reverse a Servo (3 min 58 sec)
Old Sep 08, 2012, 11:34 AM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
I must have missed the bit about a signal reverser needed. I searched two of the larger suppliers here in the US and didn't turn up anything. HK lists it, but its backordered. I guess I was doomed to cut the pocket in anyway.
Thanks for the info though. Learned something new today.
Jack
jpgcag is offline Find More Posts by jpgcag
Old Sep 08, 2012, 01:01 PM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
Originally Posted by 2500GENE View Post
Ernie says:
To start off with make sure your esc to motor connections are good....your esc to receiver connection is in the proper channel and has the correct orientation and you throttle trim is all the way down.
Ernie is a very smart wiener dog.
thanks ernie!
well i checked all connections etc (all good)
when i power on my esc with throttle off this is what happens
is this normal?
im running a 3s 2200 lipo so im guessing thats why it beeps 3 times
it still wont run the motor
mudcow007 is offline Find More Posts by mudcow007
Old Sep 08, 2012, 03:05 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
Hi,
I tried to maiden my SS yesterday. No go. I had tested the controls at home 5 days earlier. When I had connected the battery then, it beeped and then worked fine. There was a little bit of servo hum for a few moments but then it stopped. The controls just worked.
When I got out to the field and plugged in the battery it beeped 3 times and beeped some more. The place was quiet for a few moments and then seemed to be controlled by something else. The rudder moved back and forth and the throttle would start and stop. It seemed that I could control the plane as well, but it was hard to be sure, since it seemed to have a mind of its own.
I tried first in one field. There was a RC car race track 300 Meters away. I though that might be the issue so I drove about 2-3 Km away from them. This is an agricultural field at the edge of town and I could not see or hear and RC airplanes. After a while I gave up and took the plane home. At home the plane was also "haunted".
I did hand toss the plane to see how it acted. There was not much wind and it took a nose dive. My "removable tail-feathers" mod broke and I need to re-do it better. The hatch popped off so I learned that I need some velcro to hold it on (I expect some hard landings at first).
Any suggestion what I have to learn about to get a good radio connection with the plane? I have a FlySky X-UAV 4 channel Tx (FS-T4B)
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Sep 08, 2012, 05:35 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by mudcow007 View Post
thanks ernie!
is this normal?
The 3 beeps are a cell count...but it's not arming the motor.
Did you set throttle trims all the way down...like into the negative numbers?
I looked for a manual for this esc and could not find one....did they give you a paper with it? I noticed they say...
"Power arming protection (prevents the motor from accidentally running when switched ON) "
and wonder exactly what they mean by that,
Ernie.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 08, 2012, 06:04 PM
Mac50L is offline
Joined Oct 2011
mudcow007, is there a switch on the Tx (left hand side top) which switches off the motor? Used as a safety switch.
You don't say (or I haven't noticed it) what Tx you have. I'm usually flying the Bixler with a HK T6AV2 and use the switch often and often forget and wonder why the motor doesn't start - but then I'm greyer than you....
Old Sep 08, 2012, 06:22 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
He's got a DX6i.
Old Sep 08, 2012, 06:26 PM
Mac50L is offline
Joined Oct 2011
He's got a DX6i.
There is a "Throttle cut" switch/feature on it according to the website. Is that on or off?
Old Sep 08, 2012, 10:02 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Other video
That video (with the orange wires) is Below.
How to reverse a servo (8 min 38 sec)
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 08, 2012, 10:04 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Ernie.
Do not make Ernie mad, either.
AJ
Old Sep 08, 2012, 10:40 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
AJ
AJ, That is "to cool for school" as my daughter would say.
DJ
Old Sep 09, 2012, 04:08 AM
Liverpool, UK
Joined Jul 2006
Ernie.
im using this manual, but cant find "Power arming protection" mentioned anywhere. am i using the correct manual!?!??
When i power on the esc the 3 beeps shown on the video only sound once, when i power on the rx (1st socket in a OrangeRX 7chnl RX).
After the initial 3 beeps if i move the throttle to full an leave it there, nothing happens.
if i trim the throttle down, its exactly the same (3 beeps with no response)
if i reverse the throttle, with the throttle in the down position, the esc enters programming mode
any ideas?
i really appreciate your help!!
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
