Old Sep 06, 2012, 12:35 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Correction
Originally Posted by sammyc View Post
Not really, in theory same prop diameter gives same thrust, irrelevant of pitch.
So more pitch is more top speed, but you need more power to turn the higher pitch prop, and also acceleration is reduced.
Have a play with this:
http://personal.osi.hu/fuzesisz/strc_eng/index.htm
The way size props, is pick the diameter you want (largest that'll fit on your bix/ss), then size the pitch so it is nearly full rated power of motor/esc. So if your ESC can handle 200W, stay below that.
If top speed is lower than desired, then you can drop a prop size and increase pitch to stay under the motor/ESC rating. Just know that in this case, you will be sacrificing thrust with top speed.
Right. It is all GENE's fault. I used his pain killers and that endless barking of his doxies caused the mistake.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 06, 2012, 09:08 AM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
One more Newbie question. ( I hope to maiden tomorrow).
The batteries have a power connector and a small 4 lead connector.
I know that when I charge the batteries I connect the small 4 leads to the charger.
When I have the battery installed in the plane, does it connect to anything?
Shimmy
Shimmy is offline Find More Posts by Shimmy
Old Sep 06, 2012, 09:48 AM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Shimmy
Nope, it just lays there.
Good luck tomorow,
DJ
Sculptor is offline Find More Posts by Sculptor
Old Sep 06, 2012, 10:08 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
Good luck tomorow,
DJ
ive always wondered what them 4 wires are for?
is it to tell "stuff" to the charger?
mudcow007 is offline Find More Posts by mudcow007
Old Sep 06, 2012, 10:55 AM
Shimmy is offline
Joined Jun 2012
I gather that it tells stuff to the charger. I have the Accucel-6 and it knows how many cells the battery has and what the voltage of each cell. How else could it know that from the 2 power leads.
Old Sep 06, 2012, 01:05 PM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
What a strange thread to bring such a discussion - all about balance leads!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Sep 06, 2012, 01:15 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
He doesn't know if the 'balance' leads have a use inside the plane.
DJ
Old Sep 06, 2012, 01:58 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Thats the balance lead and it allows the charger to access all of the cells in your battery separately. Theres one wire for each cell and then a ground wire, so for a 3S battery you have 4 total wires.
epyonxero is offline Find More Posts by epyonxero
Old Sep 06, 2012, 02:19 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Some guys will hook to the balance leads for led lights on the plane
jrjr is offline Find More Posts by jrjr
Old Sep 06, 2012, 02:54 PM
Liverpool, UK
Joined Jul 2006
guys can anyone help me...
just trying to configure a Hobbyking blue 30a ESC (with ubec) an im totally lost.
i have bound my dx6i to my orangerx 7chnl receiver this works as i can move servos etc
with the motor connected to esc i can hear very faint beeps from the motor after 5 seconds or so, these beeps get loud? then change tone
im lost.....
Old Sep 06, 2012, 04:28 PM
jeeper1977 is offline
Find More Posts by jeeper1977
jeeper1977's Avatar
Lake Havasu City AZ
Joined Feb 2009
Originally Posted by Gordks View Post
This page makes it easier to understand. http://personal.osi.hu/fuzesisz/opc_eng/index.html
On that page you start with a given power and it gives a number of diameter and pitch props. In the case of two props with the same diameter, the one with the greatest pitch will certainly give greater speed. The one with the lower pitch, even though it has the same diameter, does give more thrust because the rpms go up as the pitch is reduced and the power goes into thrust rather than speed. Of course this depends a lot on the particular motor used. Some motors might not be able to produce the same power at the lower rpm due to Motor KV, prop sizes used and such.
Gord
Yes, and thank you for the good explaining. My comment was just from experience with props.
jeeper1977 is offline Find More Posts by jeeper1977
Old Sep 06, 2012, 07:05 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
im lost.....
Ernie says:
To start off with make sure your esc to motor connections are good....your esc to receiver connection is in the proper channel and has the correct orientation and you throttle trim is all the way down.
Ernie is a very smart wiener dog.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 06, 2012, 07:51 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by 2500GENE View Post
Ernie says:
He is smart because he is not related to Gene in any way.
Eagle202 is offline Find More Posts by Eagle202
Old Sep 07, 2012, 12:55 PM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
Just Maidened my Bixler Ver? this morning. This plane has clear canopy no pilot, and flaps with 2 screws holding the wings together. Way different than my first one.
Note: if you're going to use flaps, and you are also going to use the supplied "Y" cords, you will have to cut a new pocket for one of the flap servos. I was using a 6ch orange HK receiver, so I Y'd the ailerons on the aileron channel and Y'd the flaps on the Aux1 channel. You need to turn one of the flap servos around or otherwise you wind up with an inboard set of ailerons.
I video'd the maiden this morning, and will post it later once I remember how to edit it. Its a great flyer and super stable. Flaps worked great as well, but I need to mix in much more elevator to neutralize the pitch-up tendancy when they are lowered.
All iin all a good cheap plane. ( I don't know how long the motor, servo's and flight controls will last, but for now they're fine.
Jack
jpgcag is offline Find More Posts by jpgcag
Old Sep 07, 2012, 06:01 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Jack
That's why they tell you to order a servo reverser as well as the extra servos. The alternative is to rewire the inside wires of one of the servos. Four wires to be resoldered. There is a video somewhere showing how it is done.
Mac50L is offline Find More Posts by Mac50L
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
