Old Aug 27, 2012, 04:33 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by Mac50L View Post
Having viewed the video, 2 comments -
I'd suggest a dab with a felt tip pen on one of the 2 wires just to make sure you don't resolder back the way it was if you look away with all wires of the same colour.
He mentions and I'd agree, a HK servo tester ~$5, is so handy. You can centre the servo for putting on the arm, cycle the arms continuously and move the arms for checking, all without needing to fire up the Tx.
Thank you, Good info especialy marking the wires.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Aug 27, 2012, 05:05 PM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
Hi,
Just thought I would share a couple of vids shot from the Bix v1 and v2 on the weekend. I am down a pan and tilt servo from the crash but that was all the damage. The punishment the Bixler can take is just amazing.
Weekend FPV (5 min 27 sec)
Turfie Mash (5 min 22 sec)
Cheers,
Gim
Gimmer is offline Find More Posts by Gimmer
Old Aug 27, 2012, 08:01 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Originally Posted by cassb View Post
I'm putting together a new Sky Surfer with a new fuselage, wings and tail. The old one crashed, but I still have the motor, ESC, etc. I bought these control horns at HK:
http://www.hobbyking.com/hobbyking/s...idProduct=8419
I didn't order any screws with them -- what size do I need for these? I'll get them from a local shop. Also, I got the pinned hinges as well:
http://www.hobbyking.com/hobbyking/s...idProduct=8282
Same screws for this, or different?
Thanks!
Bryan
The hinges do not need screws, rough up the plastic and epoxy them in.
I think the Control horns you bought are not for foam airplanes. They would work if you glued some plywood to the foam for screws to grab but you really need ones like these. http://www.hobbyking.com/hobbyking/s...2_10sets_.html . Pay attention to the hole size, your push rods should fit without much slop.
BGR is offline Find More Posts by BGR
Old Aug 27, 2012, 08:52 PM
cassb is offline
Find More Posts by cassb
United States, NY, Victor
Joined Apr 2005
Now he tells me! Well, I have to make what I bought work -- I'm not waiting 2 more weeks to get new horns. I got some screws tonight that will work. There is a plastic piece for the other side of the wing that the screws go into. The foam is sandwiched in between them. I think it should work OK.
Thanks!
Bryan
cassb is offline Find More Posts by cassb
Old Aug 27, 2012, 10:27 PM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
Thanks!
Bryan
I didn't see the plastic piece, yes they will work.
Old Aug 29, 2012, 05:31 AM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
AirWing Wingsurfer
Looks like Nitroplanes is getting into the game with this.
http://www.nitroplanes.com/36a05-win...e-rtf-24g.html
flyvertigo is offline Find More Posts by flyvertigo
Old Aug 29, 2012, 07:48 PM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
Looks just like a Bixler, hmmm rebranded?
Old Aug 29, 2012, 08:12 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Of course.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Aug 29, 2012, 08:23 PM
flyvertigo
Orlando FL
Joined Aug 2009
95" Bixler
I'm waiting for the Super Bixler.
Anybody hear anything?
Old Aug 29, 2012, 08:29 PM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Too many critical mods needed to make this airframe airworthy in my opinion.
lets see>
Hinges
Control Horns
Spar
Motor/prop
ESC placement
Wing join
Spar cover
Tape it up
Anything else?
capt is offline Find More Posts by capt
Old Aug 29, 2012, 08:40 PM
idletime is online now
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
lets see>
Hinges
Control Horns
Spar
Motor/prop
ESC placement
Wing join
Spar cover
Tape it up
Anything else?
Ever since I discovered these hinges, I install on all planes. Never will I use/rely on the foam hinge anymore.
http://www.hobbyking.com/hobbyking/s...idProduct=8435
idletime is online now Find More Posts by idletime
Old Aug 29, 2012, 08:57 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
lets see>
Hinges
Control Horns
Spar
Motor/prop
ESC placement
Wing join
Spar cover
Tape it up
Anything else?
That is a pretty long list of things that I didn't have any problem with at all. But I started with the Sky Surfer kit and built it myself. If this was a Bixler RTF I can understand where there might be problems. I have never seen a hinge tear off like that, but on my MiniMoa at least one of the ailerons had started to unzip from an end, right out of the box. I painted on some canopy glue and have never had a problem with them since, and have flown it plenty. Canopy glue is very strong and flexible.
Gord
Gordks is offline Find More Posts by Gordks
Old Aug 29, 2012, 09:32 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Had no problems with mine except the motor sounded S--T from the get go so I upgraded the motor and mount. Tape is standard on foam belly landers especially if the ground is rough.
I always inspect the hinges every flight and have not had problems but if they show any tearing they all get replaced. Standard with all foam aircraft with skin hinges.
Just fly it................
clive45 is offline Find More Posts by clive45
Old Aug 29, 2012, 10:39 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Or simple high grade packing tape. They use the 3M storage tape on 175 mph Rite Wings.
Prof100 is online now Find More Posts by Prof100
Old Aug 29, 2012, 10:49 PM
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
There is Moving & Storage and there is Storage tape for Boats....which on are you referring to? Do you have a link?
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
