Old Aug 25, 2012, 02:40 AM
Wiciman is offline
Find More Posts by Wiciman
Joined Jul 2012
New low KV motor setup
I am trying to equip my SS for longer flight times.
I have bought the following items to accomplish this:
1. Hobbywing Pentium 40A ESC
2. Motor: XYH35-30 1100kv 15A Brushless Outrunner (http://www.giantshark.co.uk/xyh3530-...-p-402740.html). I also have the 1400kv version to use if the 1100 should fail.
3. 8x4 Prop / 8x6 Prop / 7x6 Prop
4. Gens Ace 3300 25C 3S Lipo Battery (I also have a couple of 2200 mah to use if too heavy)
What do you guys think of this setup?
What Prop do you suggest?
I am going to have to solder extension cords for the motor leads using 3,5mm bullet connectors, any comments on that (except for keeping them as short as possible I guess).
I use the CNC motor mount. Is this the correct mounting of the motor?
Description:
Apart from checking the COG after everything has been installed, is there anything else I should do?
Wiciman is offline Find More Posts by Wiciman
Old Aug 25, 2012, 03:36 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
That setup will just barely deliver enough thrust to get it flying. Unless you have good deal of flying experience, I would suggest that you do not try that setup. It will be woefully underpowered even if it does fly. sorry for the bad news.
Why did you not use the stock setup? Did you order an ARF?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Aug 25, 2012, 03:40 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Removed
GTiDonavan is offline Find More Posts by GTiDonavan
Old Aug 25, 2012, 06:22 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Attachment 5107487
I think that set up would do just fine with the 7x6 prop and 3 cell.. Quieter too.
2500GENE is offline Find More Posts by 2500GENE
Old Aug 25, 2012, 08:50 AM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Those of you who are flying the Bix V2 can you tell me how it flys? Compared to the V1.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Aug 25, 2012, 09:53 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
DJ
Exactly the same is my experience.
AJ
Old Aug 25, 2012, 09:57 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
servo reversing
Here is an excellent video on reversing a servo (analog) without using any external wires. I don't know if this procedure is OK with the specktrum tx's or not. Since it is just a direction change, I suspect the spektrum would not even know the servo was changed.
How to reverse a servo (8 min 38 sec)
AJ
Old Aug 25, 2012, 10:20 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
http://youtu.be/4n1ec2w21pA
AJ
Thanks AJ, I'm going to do just that. It will give me something to do while the Hurricane tries to blow me off this wildcats ass.
DJ
Old Aug 25, 2012, 02:36 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
AJ
It not only works that servo no longer chatters. That was my first experience soldering on a board.
Thanks again AJ.
DJ
Old Aug 25, 2012, 04:56 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Having viewed the video, 2 comments -
I'd suggest a dab with a felt tip pen on one of the 2 wires just to make sure you don't resolder back the way it was if you look away with all wires of the same colour.
He mentions and I'd agree, a HK servo tester ~$5, is so handy. You can centre the servo for putting on the arm, cycle the arms continuously and move the arms for checking, all without needing to fire up the Tx.
Mac50L is offline Find More Posts by Mac50L
Old Aug 26, 2012, 10:57 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
HK Bixler GoPro HERO2 Ambleside park (6 min 19 sec)
Westwood is offline Find More Posts by Westwood
Old Aug 27, 2012, 07:50 AM
Wiciman is offline
Joined Jul 2012
Thanx, that was generally what I wanted to hear... :-) Can I get a third opinion regarding the comment from previous poster that this setup would be way too underpowered?
Old Aug 27, 2012, 08:15 AM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
I would run it on 4S with an 8x6 3 blade prop :-)
Simon2504 is offline Find More Posts by Simon2504
Old Aug 27, 2012, 08:41 AM
cassb is offline
Find More Posts by cassb
United States, NY, Victor
Joined Apr 2005
Which screws do I need?
I'm putting together a new Sky Surfer with a new fuselage, wings and tail. The old one crashed, but I still have the motor, ESC, etc. I bought these control horns at HK:
http://www.hobbyking.com/hobbyking/s...idProduct=8419
I didn't order any screws with them -- what size do I need for these? I'll get them from a local shop. Also, I got the pinned hinges as well:
http://www.hobbyking.com/hobbyking/s...idProduct=8282
Same screws for this, or different?
Thanks!
Bryan
cassb is offline Find More Posts by cassb
Old Aug 27, 2012, 11:15 AM
jeeper1977 is offline
Find More Posts by jeeper1977
jeeper1977's Avatar
Lake Havasu City AZ
Joined Feb 2009
I run a 8x6 on a 1200kv motor on 3s 2200mah and goes quite well. So a 1100kv motor should be close in performance.
jeeper1977 is offline Find More Posts by jeeper1977
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
