Old Aug 20, 2012, 05:56 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Originally Posted by Eagle202 View Post
Believe it not I crashed it on a Thursday, repaired it the next day and tested on day after. Looks a little worn but it wasn't hard to put back together.
Here are some pix after the crash, during repairs and then after repairs.
Crash!!!! That's not a CRASH!!! That's just a little cosmetic damage !!!
I was too ashamed to photograph my damage - broken aft fuselage, broken wing, totally split and broken nose, servos push wires bend and dangling. I noticed the battery had maybe slipped 3 mm forward along the Velcro but was still attached and safe. The ground was wet and there was quite a dent in it.
Mac50L is offline Find More Posts by Mac50L
Old Aug 20, 2012, 06:03 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
She fly's pretty good. Just haven't posted the video yet.
Eagle, not only a great job repairing it but no 'Moment of Mourning'.
'Fly it, Crash it, Fix it, Fly it! You-da-man. Nice example for people like me.
"People like you?" whAAt, whAAt.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Aug 20, 2012, 06:48 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I have seen more damaging crashes but that was my worst. Did you turn up the volume in the video. It sounded pretty bad on impact. It looked very bad when I first went over to pick up the pieces. The ground was damp which actually may have helped the nose from compressing. The plastic cover on the canopy was off. One wing did come off the spar. The motor leads were pulled out of the ESC and there were a few pieces of foam that I rescued.
I thought about moving all of the electronics over to my spare body but the chose to first try to repair it. Surprisingly it only took the better part of the day to get it back together. Isn't CA just great glue.
I was really surprised it fly straight and actually glided again. The SS is one tough Bird.
Eagle202 is offline Find More Posts by Eagle202
Old Aug 20, 2012, 06:53 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
DJ
Thanks Sculptor. There were a couple of minutes that caused me to get mad that I crashed it but then no one was hurt so why get upset. I guess I just stopped being so sensitive to causing damage to it.
I know it can be repaired even after a crash like that so I don't feel so nervous about flying it like I did the in the beginning.
Old Aug 20, 2012, 07:01 PM
Mac50L is offline
Joined Oct 2011
They do. It is hard to walk over to it with eyes closed too.!!!
Mine always pops off on a hard landing. It means "You could have done a better landing."
Yes and that happened too. I've noted that I'd better glue (reglue?) the wing spar cover foam. That is loose and it will be a reason for wings flapping like a seagull.
My ESC just pulled the Velcro off the foam.
I even spotted one of the canopy metal bits that the magnets hold it on by scattered in the debris.
I'm using Gorilla polyurethane for my fix. Slower but it does work.
Old Aug 20, 2012, 11:48 PM
807gt is offline
Find More Posts by 807gt
Joined Nov 2011
Hot ESC?
Originally Posted by ajbaker View Post
The ESC in this plane runs too hot IMO. So, I moved it to the outside of the plane. On my next arf, I will probably run it on top of the plane in a nicely cut pocket for it. For this plane, it was the quickest way to do it. I will add this post to Page #1 also. If someone else does it another way, I will add theirs, too.
AJ
Hot ESC? Cut a slot into the heatshrink near the ingoing supply wires and push a u-shaped aluminium strip in .Must be flat no dents,to draw the heat away .You may use heatconducting compound.Works for me.807gt
807gt is offline Find More Posts by 807gt
Old Aug 21, 2012, 12:48 AM
Mac50L is offline
Joined Oct 2011
Just back from an hour of flying, well the lad was because my Bixler is at the stage of the nose going back on - tomorrow. I toured a little T-28 around but the main thing was the lad trying out his flaperons, OK, and doing a bit of bomb dropping. The mechanism simply Velcros on under the wing so can move from plane to plane.
Remind me not to compete with him, not quite in the 18" square box but I feel, far closer than I'll get. A good little exercise for depth, position perception (my excuse for doing it).
The bomb is a toilet roll inner, Weetbix carton cardboard fins, 4 paper clips for weight and a bit of softish foam in the nose. 8 grm. and for comparison a shuttlecock is up to 5.5.grm.
Old Aug 21, 2012, 01:20 AM
yakav is offline
Find More Posts by yakav
Russian Federation, St Petersburg
Joined Jul 2012
Hi guys, Bixler continues to fly without a motor.
Bixler на Планерной горке тоже летает (4 min 5 sec)
yakav is offline Find More Posts by yakav
Old Aug 21, 2012, 01:29 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Hello
Cansomebody with a Bixler 2 please measure the width and height of the wing for me.
At the centre part that fits in the fuselage. from front to rear.
GTiDonavan is offline Find More Posts by GTiDonavan
Old Aug 21, 2012, 02:08 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Very nice yakav. I was watching your airplane and then got interested in the city.
BGR is offline Find More Posts by BGR
Old Aug 21, 2012, 06:19 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
http://www.youtube.com/watch?v=Bw76T...layer_embedded
Great job flying slope with the Bix. That is a really nice place to fly. Looks like a bunker with that air pipe coming out of the top.
Do you know how much wind was blowing that day?
Vince
Old Aug 21, 2012, 07:04 AM
yakav is offline
Joined Jul 2012
4-5 m/s
Old Aug 21, 2012, 07:08 AM
yakav is offline
Joined Jul 2012
Tried to shoot video in the slope soaring
Bixler & GoPro slope part 1 (5 min 50 sec)
Old Aug 21, 2012, 07:59 AM
yakav is offline
Joined Jul 2012
Did upgrade Ruder
Old Aug 21, 2012, 11:18 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Originally Posted by GTiDonavan View Post
Hello
From the top of the 'step-up' shoulder that goes into the fuse to bottom of wing is 27mm. Width is 50.2 mm at the fuse.
DJ
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
