Joined May 2012
I finally got some good stick time with my SS and then popped my GoPro on. Then, I played around with Windows MovieMaker.... Here's the video. I made the super hi-tech gopro mount in 5 min.... Not too bad for my first video......
Now I am not so sure since my SS V2 flew for over a year at 60mm and now it is better at 70mm. While I haven't got a good reason I did make a number of modifications to the fuse. This could have made the CG change but it should not have. I know that doesn't help you but I can only suggest you try balancing at a few different CG measurements and then perform a hand tossed glide to see if your plane performs properly. |
United States, IL, Kankakee
Joined Jan 2011
When do I get to fly the plane. Just got my Bix2 ready to fly (CG is 7/16" back of spec, etc,) I'm as ready as I'm going to get. Tomorrow only gliders can fly until 12:00. I'm going to take my Bix2 to the glider guys, i have a friend (highly respected) that might help me get this into the air. I'm not signed off on, my 'ticket is not punched' I can't fly on the tarmac because I haven't satisfied all doubts that I can fly this thing without hurting someone. I wouldn't have it any other way. DJ |
DJ |
I was told that if the plane nose dived then the balance point or false CG was too far toward the tail making it nose heavy. If the plane suddenly rose then the balance point or false CG was too far toward the nose making it tail heavy. The proper balance point or true CG would make the plane glide further out and slowly down. |
It could be the motor thrust angle is off and every time you power up you have ot correct. Or your control surfaces are way too extreme. Maybe reducing the travel distance or using a lower rate may help reducing control or over control. |
| Thread Tools | |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 6 | May 28, 2013 02:14 AM |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
