Old Nov 17, 2010, 06:30 PM
kevinhines is offline
Find More Posts by kevinhines
Robot, RC Pilot & Builder :-)
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
AJ and everyone,
Great thread!
You have a wealth of info here, and it's very organized ...Thanks.
I hope you guys find a SkyS supplier who does a good job... and when you do, please let me know ... I may have to buy one.
Thanks!
Kevin
kevinhines is offline Find More Posts by kevinhines
Old Nov 17, 2010, 06:39 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Two thread librarians.
Originally Posted by kevinhines View Post
AJ and everyone,
Great thread!
Thanks!
Kevin
Thanks for the props, kevin. It is really good to see you over here if only for one post. The site is modeled after the fantastic job that you did on the EZ* thread. I am just a plagiarizer. Keep up the swell work you do over there.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Nov 17, 2010, 06:40 PM
Eagle-Eye is offline
Find More Posts by Eagle-Eye
Closed Account
Joined Mar 2005
BEVRC - SkySurfer V2 Mod con't
Just added 900mhz 500 mw tx, antenna etc.
While the "grey umbrella" is up here in Eugene, I have plenty of building & modification time.
If I need to order another SkySurfer I will make sure it's a V2. I really like the compartment area. Ez to place electronics and wiring. I have more cable than necessary for my gopro video out, but I may need that longer cable later if I transfer to a larger plane. Close up pic
Eagle-Eye is offline Find More Posts by Eagle-Eye
Old Nov 17, 2010, 06:52 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Couple of things.
If I need to order another SkySurfer I will make sure it's a V2. I really like the compartment area. Ez to place electronics and wiring. I have more cable than necessary for my gopro video out, but I may need that longer cable later if I transfer to a larger plane. Close up pic http://www.aerial-eye.com/photos/1094985871_PZfyZ-L.jpg
First, the bad news. BEVRC is (was) the only source for a SkyS V2. BH only has V1 AFAIK. Let me know if that has changed. I know what your mean about demanding a V2. I don't have one. But, the differences are all very nice and the plastic canopy is the cherry on top.
Second, is it necessary to have that large (to me) coil of wire in the plane at all? It sure looks heavy to me. What is it?
AJ
Old Nov 17, 2010, 06:59 PM
Closed Account
Joined Mar 2005
That's a special order GoPro video out cable. With the software upgrade for the HD GoPro, the little camera has "Live Video" out. I just plug that cable into tx and I can now record the flight in HD captured in the camera and fly with (FPV). This eliminates a second camera feed. I admit that it is very long, but I will see if I can get the C.G. correct and if I can not need to cut. Like I mentioned it may be transferred some day to another plane and I might need the extra lenght. Lennie
Old Nov 17, 2010, 07:09 PM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Eagle-Eye: how are you going to attach the fuse halves together? Just wondering because if you use glue you may have a heck of a time getting the FPV equipment out.
road_rascal is offline Find More Posts by road_rascal
Old Nov 17, 2010, 07:17 PM
Closed Account
Joined Mar 2005
Road Rascal
One reason I take pictures of the interior is to know where to cut a side access hatch. I did that on my SkySurfer 1 and it seems to let me get to what I need. I use Gorilla white glue at space points along the fuse body and then cover seem along weak points like motor mounts and bottom. Seems to work real well for me so far.
Old Nov 17, 2010, 07:49 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Bet it flys better with a motor and esc.
Looks great.
Here's something you may be interested in for rx and tx antennas.
Home made or build to order. IBCrazy is a master of antennas.
http://www.rcgroups.com/forums/showthread.php?t=1159968
Just found a bumper sticker for aj's car.
http://cgi.ebay.com/ebaymotors/ID-RA...Q5fAccessories
2500GENE is offline Find More Posts by 2500GENE
Old Nov 17, 2010, 08:27 PM
Alpha35 is offline
Find More Posts by Alpha35
Joined Feb 2008
Too much!
GeneH
Alpha35 is offline Find More Posts by Alpha35
Old Nov 17, 2010, 09:29 PM
Closed Account
Joined Mar 2005
2500GENE
you're right . . . I'll try this . . . 2836-22 Inrunner Brushless Motor, Power up 32 Amp ESC, http://upshotz.smugmug.com/photos/1161879034_BeQLq-S.jpg[/img][/url]"][/URL]Thanks for the IBCRAZY link, I could use some help in that dept. As for the bumper Sticker, . . . I WANT ONE!
Lennie
Old Nov 17, 2010, 09:55 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I found another supplier in Singapore -- http://www.aerosmith-hobby.com/FoamPlanes.html
RTF and ARF.
Check it out AJ.
Prof100 is offline Find More Posts by Prof100
Old Nov 18, 2010, 02:22 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
That's the most expensive so far Prof.
60usd for ARF
I wonder how they send it though and I requested shipping costs to Cyprus..
normally it should be less..
Let's see
pavcon is offline Find More Posts by pavcon
Old Nov 18, 2010, 02:25 AM
pavcon is offline
Joined Jan 2010
Originally Posted by moon12 View Post
You can upload it to Vimeo or U-tube then post the link here, thats what I had to do. Usually I edit it in Windows Movie Maker first. I'm sure most of us would like to see your flight.
harry
I will try to convert it to something smaller...
i got no probs with video editing but my upload it's SLOW.. unfortunately internet here is not exactly fast..
2Mbits and it will get upgraded to 4Mbits download with upload speeds beeing as low as 384Kbits but it will double soon..
to get descent internet connection here (12Mbits it's about 49euros/month)
anw going to vegas movie maker
Old Nov 18, 2010, 10:56 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Anyone flatten those wing tips yet? What's the best way of doing it?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Nov 18, 2010, 01:49 PM
mastmalang70 is offline
Find More Posts by mastmalang70
Joined Nov 2009
mastmalang70 is offline Find More Posts by mastmalang70
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
