Old Jul 27, 2012, 01:11 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Originally Posted by headlessagain View Post
Don't forget what a useful resource YouTube is. You will finds lots of instructional RC related videos. Some are general whilst others are very specific e.g. how to program your DX8 for controlling an F27-Q.
They say a picture is worth an thousand words so I guess a well made video is worth 10,000.
Here is a good video explaining ESC's
Andy
Where?
Aeronca
aeronca is offline Find More Posts by aeronca
Old Jul 27, 2012, 03:44 PM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Sorry, you must have viewed just before I edited my post to include the video
Andy
headlessagain is online now Find More Posts by headlessagain
Old Jul 27, 2012, 05:42 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Motor extension leads -
Common are XT-60 (3.5 mm pins) connectors on batteries. My Bixler came with 3.5 mm male pins on the motor. If you are going to make extension leads you will need male and female 3.5 mm pins to try and keep things consistent. To do it you need the male & female pins, heatshrink tubing ~5 mm, soldering iron, solder, hotair gun and obviously, some wire. A short length of mains cable should be suitable, especially as in USA the current carrying requirement is twice that in a lot of the rest of the world (110 v vs 240 v).
As soon as anyone moves away from RTF they need to have a wide range of "skills". Mechanical, electrical, etc. to at least a basic level.
Mac50L is offline Find More Posts by Mac50L
Old Jul 28, 2012, 01:09 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
And here's the video on soldering bullets
How to Solder Bullet Connectors to Brushless Motors and ESC (8 min 15 sec)
Old Jul 28, 2012, 08:06 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Hey Now,
Gyros were what helped me not give up on this flying RC planes thing. I crashed the first 9 times I tried. Power glider 'Sky Surfer' Easiest plane to fly there is. I draped it in gyros to help with the 10 to 15 mph wind I was learning to fly in. The wind in SW Florida blows from Jan to June so I learned to fly in the wind thanks to gyros.
I have a bunch of gyros now 3ea. Esky 704's rate only, Two Detrum 48Y something (I don't like those, they make my servos chatter).
All three of my planes (Two of which I've never flown) will now be equipped with the 'Eagle 3A rate only gyros.
In the new Sky surfer I'm wanting to put it in the canopy. If you would look at these photos and tell me if you think I can do this;
Description: Name: P7283969.JPG
Description: Name: P7283970.JPG
Description:
Thank you,
DJ
Sculptor is offline Find More Posts by Sculptor
Old Jul 28, 2012, 08:52 PM
clive45 is online now
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Try this, it will let you use seperate ail servos as well
http://www.hobbyking.com/hobbyking/s...dproduct=25448
Sculptor if your canopy comes loose you will loose control of the aircraft with that mounted there, fix it to the fuse.
clive45 is online now Find More Posts by clive45
Old Jul 28, 2012, 09:00 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by Sculptor View Post
Hey Now,
Attachment 5043539Attachment 5043540Attachment 5043541
Thank you,
DJ
For the BEST performance the gyros should be close to CG as possible, though I am sure it will work in that location I think you would be better off putting it inside the fuse at about the center of where the wings come together (where I have my FY31AP located), plus having things attached to the canopy like that gets annoying too .
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jul 29, 2012, 06:33 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Hey Now,
Thank you,
DJ
Sculptor
Is that one of those Eagle A3 flight stabilizer? How do you like it?
I was looking at them on eBay and they are about $36 so I wasn't sure if the lower price meant lower performance.
I would like to get one of the Eagle Tree Guardian Stabilizer for $75 but they are out of stock everywhere including directly from Eagle Tree.
Eagle202 is offline Find More Posts by Eagle202
Old Jul 29, 2012, 09:05 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Ho-hum
Limited flyer is offline Find More Posts by Limited flyer
Old Jul 30, 2012, 11:03 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Originally Posted by Eagle202 View Post
Sculptor
Eagle, I'll fly it today and let you know. I sure hope it will work there, it so convenient to be able to pop the top, flip it adjust the three pots.
I bought 3 of these from HK for 20.00 ea.
DJ
Description: Name: 2.jpg
Description: Name: 3.jpg
Description:
Old Jul 30, 2012, 04:27 PM
Shimmy is offline
Find More Posts by Shimmy
Joined Jun 2012
DJ
I was considering getting a gyro to make my maiden flight a littler easier (I need to order a few really small things from HK and this will help fill the box). I was going to get This HK-401B. Is this a good choice or is yours a better solution?
Shimmy is offline Find More Posts by Shimmy
Old Jul 30, 2012, 05:41 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Shimmy I'm not an experienced adviser on this. I will say this I flew three gyros in the V-3 SS. I didn't like the two Detrum 48Y rate/headlock gyros (the one you pointed to is a headlock gyro) you need one for each control surface three in all.
The Detrum 48Y and the one your pointing to have 'gain' wires that have to be connected to your chanel 5 and the other on ch 6 and there on knobs on your tx.
I found adjusting them in flight was not fun, if you turn the knob too far (past 12:00) you just went from 'rate' mode to 'headlock' mode which you don't want on a plane.
Here is were my heads at the moment; I'll have an Eagle 3X (not the 3X pro because I don't want to adjust them from my tx) 3 axis board on all my planes and when I need help from them I'll set them to 'on' and use them.
DJ
Old Jul 31, 2012, 06:10 AM
Shimmy is offline
Joined Jun 2012
DJ
Thanks. I read more and realized that you are correct. These need the gain connected to your Aux channel, which does allow you to turn it on and off. However since I have a 4 channel Tx, I don't think that I can use it. If I am wrong I would appreciate being corrected.
I found the Eagle Micro Aeroplane Flight Controller Board A3 on Ebay. for $37. Is this the same idea as the OrangeRX 3-Axis Flight Stabilizer on HK for $15 ? If so I would probably get that.
Thanks for the advice.
Old Jul 31, 2012, 11:50 AM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
I'm not sure how to link back to another thread. It's "Using gyros on a plane post #2428 by 'Melnic' he is a major figure on gyros. He is saying something about the limitations of the orange 15.00 gyro but I don't understand it. Maybe you can get what you need from there or someone on this thread might explain it.
Sorry I couldn't be more help.
DJ
http://www.rcgroups.com/forums/showt...2#post22306539
Old Jul 31, 2012, 01:03 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
DJ
Attachment 5048022 Attachment 5048023 Attachment 5048024
Sculptor
How did you make out with you test flight with the Eagle A3?
I also so on another thread that there is a Pro version of the A3. Which one do you have?
Vince
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
