Old Jul 25, 2012, 02:31 PM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
[QUOTE Where is the Bixler?
QUOTE]
Been there done that. Heres a short clip of one of my crashes.
EZ Flight with alternate ending (2 min 29 sec)
The was 4 years ago and so far I haven't gone in again.
Jack
jpgcag is offline Find More Posts by jpgcag
Old Jul 25, 2012, 04:33 PM
TCJ4 is offline
Find More Posts by TCJ4
United States, NY, Fairport
Joined Jul 2011
Help newbie in distress!! I have my skysurfer mods completed was wondering when I place the plane on CG it is still tail heavy even with the battery. No FPV or camera yet to new for that. I am sure I need to add weight but just want to make sure. I removed the washers in the nose but think I may need to add some back before the maiden.
TCJ4 is offline Find More Posts by TCJ4
Old Jul 25, 2012, 05:07 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
What size battery? Where is it positioned?
Prof100 is offline Find More Posts by Prof100
Old Jul 25, 2012, 05:11 PM
TCJ4 is offline
Joined Jul 2011
The battery is a 3c 1600 and is positioned in the nose
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
First question I suppose is to describe what your "mods" were. When I built my first Bixler I glued the recommended 3mm carbon tube under the aft fuselage and used a more powerful and heavier inrunner motor which made my build tail heavy and required me to replace about half of the washers in the nose to make CG. In my opinion, neither mod was necessary and I won't do them on my next build. That said, if you have built yours tail heavy for whatever reason or not, if it needs weight forward to make CG you are going to have to do so. If a larger battery won't get you there then some ballast has to be replaced.
By the way, the CG is wherever it balances without regard to where it is supposed to balance. Ya gotta do whatcha hafta do to move it and make it balance where it is supposed to balance. Said just to eliminate confusion.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Jul 25, 2012, 06:07 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
IF your setting up your Bix for FPV it's going to be tail heavy without the gear :P If I stripped off all of my FPV gear and LG, OMG my plane would be super tail heavy :P.
I use a 2700mah 3S and a 500mah 3S right up to the very front of the nose, even with a 2200mah my plane would be too tail heavy, I would have to use a 1300mah as my secondary to balance it properly.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jul 25, 2012, 08:17 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Use a 2200 3S or tape a couple of quarters to the nose.
Old Jul 25, 2012, 08:45 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
I use 2200 mAh battery and no weights. No carbon rod in the fuselage. CoG at ~65 mm from wing leading edge.
Mac50L is offline Find More Posts by Mac50L
Old Jul 25, 2012, 09:44 PM
TCJ4 is offline
Joined Jul 2011
The mods I made were taped the fuselage after placing carbon spar along bottom. Taped the nose and removed the washers from the nose. Inserted carbon spar inside the carbon tube for wings. Taped the edges of the wings. I placed earth magnets in the wings and also used hooks for rubber bands to secure the wings. Replaced the prop as suggested. So I will replace some of the washers to level it out and try a maiden and hope for the best. I have been building a few planes but just starting so am learning as I go with all the help from the internet. Thanks for the comments they are all much appreciated.
Old Jul 25, 2012, 09:47 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Not sure where you are getting all the tail weight. Mine has carbon rod underneath, removed the washers in the nose and use a 2200ma 3S battery about 1/2' from fully forward. C of G 65mm flies great. I would think that with FPV gear you would need to add tail weight.
clive45 is offline Find More Posts by clive45
Old Jul 25, 2012, 09:50 PM
G550Ted is offline
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
You seem to know what is needed to get it right. Sometimes though less is better. Build to fly not crash and it most likely will crash less. Good luck and tell us how your maiden goes.
Ted
Old Jul 26, 2012, 12:23 AM
Pavel_D is offline
Find More Posts by Pavel_D
Russian Federation, Kaluzhskaya oblast, Kaluga
Joined Apr 2012
Originally Posted by Eagle202 View Post
Pavel
Interesting design. Since I could not read the words under the pictures what did you use to attach the screws and tiny legs to the ring with. Some type of glue?
Vince
Vince, submitted to the frame area with a copper coating. These sites, with solder acid were soldered 4 nuts and 4 amp. In the photo album, this process is illustrated in detail.
Pavel_D is offline Find More Posts by Pavel_D
Old Jul 26, 2012, 01:08 AM
Elo WW is online now
Find More Posts by Elo WW
Deutschland, RP, Hillscheid
Joined Nov 2010
I have been there once. Got out a little too far and when I came back I thought I had clearance but it hit a tree.
Mine at least came down by itself with minimal damage. Mostly my pride was hurt from all the laughs from family spectators.
Did yours come down ok?
It did not come down until now. I'm waiting for some wind.
Elo WW is online now Find More Posts by Elo WW
Old Jul 26, 2012, 09:04 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Hopefully it doesn't get damaged when it hits the ground or wet if it rains.
Eagle202 is offline Find More Posts by Eagle202
Old Jul 26, 2012, 12:54 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
You can balance it at 65mm and it will fly just fine. For both of mine, I use a 72mm CG and I have no problems at all. After flying both of them many hundreds of flights, the recommended 60mm is just too nose heavy for this plane.
AJ
ajbaker is offline Find More Posts by ajbaker
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
