Old Jul 21, 2012, 06:45 PM
Gotwings is offline
Find More Posts by Gotwings
Joined Jan 2012
Thrust Angle Issues
Originally Posted by Weekend Flyer View Post
I have a bixler with a 6x4 prop and 2700 kv in runner. It was working perfectly at all speeds until I crashed and broke the back end off. It was a nice clean break at the rear of the fuselage so very easy to perfectly align everything and glue it. The problem now is that it flies nice at very low speeds but if I put the the throttle to about a quarter or higher it dive bombs like a rock. I have to give it LOTS of up elevator to keep it level. All the control surfaces are nicely lined up and I even tried making it tail heavy but the problem still persists. The motor angle is perfect like it was before the crash (the prop is only 1/4 inch away from the fuselage).
Any ideas what is causing this?
I had similar problems using the external mounted motor block with the Turnigy 3542/4 motor. The physics must change somewhat from the stock and the angle needs adjustment. The thrust on the nose was so great, I couldn't even taxi with some makeshift wheels. I had to use longer screws (3X10mm) and a couple of washers to correct the thrust (shaft was near parallel to body). Prior to crash (for other reasons), this worked well... short video demonstrating the thrust issues here.
cheers
GW
Gotwings is offline Find More Posts by Gotwings
Old Jul 21, 2012, 08:19 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
I went back to page one and tried to find what I needed but I'm not finding it. Oh I'm sure it's there I'm just not finding it. So at the risk of being redundant here it is.
Wanting to fly with the gliders on sat. mornings but it would take me forever to get up there.
I think someone spoke of a motor that would take my SS straight up, not sure if thats true. Can you tell me what I would need to do that?
DJ
Sculptor is offline Find More Posts by Sculptor
Old Jul 21, 2012, 08:41 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Originally Posted by timtimtim View Post
im blind thanks.. maby im totally blind but i cant find Clevis for bixler just horns and hinges, any one know if HK have some Clevis for the bixler?
I presume to fit the pushrod from the servo to the horn?
I use link-stoppers for that - HK OR016-00501 - Linkage Stopper D1.8mm (10pcs) $2.59.
Put a dab of contact adhesive or Loctite on the nut to stop it coming undone. The link-stopper should be free to swivel on the horn.
Mac50L is offline Find More Posts by Mac50L
Old Jul 21, 2012, 08:57 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
StarHopper44 is offline Find More Posts by StarHopper44
Old Jul 21, 2012, 09:46 PM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
DJ
if its the same as a bixler a 2212-6 wIll go pretty good. http://www.rctimer.com/index.php?gOo...wt&goodsid=116
wilem is offline Find More Posts by wilem
Old Jul 21, 2012, 10:51 PM
taz101 is offline
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
Originally Posted by wilem View Post
"terrible" not quite sure why you would say this,, the fun cub has a ton of room, can carry a small car, and all of the gear mounts on or near the cg. not to mention it actually flies very well which is something i cant say for the bixler. also, it can land very short from steep angles with the flap option installed, the only weak link i can see in the cub is the landing gear is flimsy.(when carrying 3s 5000 and gear) additionally, the camera can be mounted on the bottom for much better viewing IMHO. I can look at the sky from the ground.
He did not say the fun cub is a terrible choice as a plane. If you read back a couple of pages before to the original question. Some one asked for a suitable plane to put all the electronics out of the Bixler and straight into another plane. Then someone else suggested the fun cub, but what I got from AJ's reply was that it is almost double the weight of the Bixler so the motor would not be big enough or even the prop! Hence 'terrible' choice to put the electronics into!!
LURCH
taz101 is offline Find More Posts by taz101
Old Jul 21, 2012, 11:41 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
It's the thrust angle that's changing when powered up or changed permanently. I nosed in mine with Microdan and the foam mount and motor broke off. Gluing it back on was not enough of a repair because the foam, although glued back together, was flexing when the motor powered up. It was like a tenderized piece of meat. So, I injected it with hot glued to stiffen it up and wrapped it with 3M Extreme tape. It solved the problem.
Prof100 is offline Find More Posts by Prof100
Old Jul 22, 2012, 12:39 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
People who judge without reading the history.
See Post 16311. Then, go read all the history.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jul 22, 2012, 12:46 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Skewers to the rescue.
I am sure you know about it. But, did you consider putting meat skewers through the foam to un-tenderize it? I have done that a few times and it seems like I learned that trick from you.
AJ
Old Jul 22, 2012, 12:50 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
Meat skewers were next on my list of things to do if hot glue and 3M tape did not work.
Old Jul 22, 2012, 12:52 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
DJ
Use THIS motor with a 7x4e prop if you want model rocketry. Prof100 and I have both used this motor with a few different props. Fun stuff. Pricey and worth every penny.
AJ
Old Jul 22, 2012, 01:45 AM
AVIATION_RULZ is offline
Find More Posts by AVIATION_RULZ
Canada, BC, Surrey
Joined Feb 2011
Hey guys,
I love my Bixler but need a solution to what I'm sure is a common problem. I've had a few crashes with this plane and the nose seems to be the weakest link (for me at least). Is there any way I can strengthen the front third of the plane? Has anyone tried something like this?? I was thinking of maybe some fiberglass weave??
Any help would be appreciated
Thnx
AVIATION_RULZ is offline Find More Posts by AVIATION_RULZ
Old Jul 22, 2012, 03:42 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by AVIATION_RULZ View Post
Hey guys,
Thnx
Sure, you can glass it. You can even barrel wrap it with 3M Extreme tape. The key though, is to quit crashing. Build a plane to fly, not to crash.
Old Jul 22, 2012, 03:50 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
How do you keep crashing it.......... just about flies itself, it will fly slow enough for you to catch it. If you are having trouble flying the Bixler then something is wrong.
clive45 is offline Find More Posts by clive45
Old Jul 22, 2012, 11:36 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I can share some sympathy with Aviation_Rulz.
In my earlier learning curve of flying my crashes were usually the result of a low level tip stall followed by a failed attempt to make it pull up under full power.
That didn't work and it usually proceeded to lawn dart into the ground.
I have not had that much fun for over 30 flights now since I know better not to power out of a dive that low to the ground.
Eagle202 is offline Find More Posts by Eagle202
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
