Old Jul 13, 2012, 06:49 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by sammyc View Post
Hey for your next build, may I suggest bracing the tail with some extra CF, it seems to have a lot of tail wag happening.
Nope it was stiff , just bumpy ride lots of gusts and thermails.
nakelp86 is offline Find More Posts by nakelp86
Old Jul 13, 2012, 06:52 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Originally Posted by 2500GENE View Post
What's a SF?
Wrong thread?
And thx Gene for pitching in the blog :-)
I guess you back in FL, anyway you wouldnt notice any difference here ( oh well no palms ) LOL
Old Jul 13, 2012, 07:14 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
What's a SF?
Wrong thread?
Maybe he meant SS for SkySurfer?
Eagle202 is offline Find More Posts by Eagle202
Old Jul 14, 2012, 01:43 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Description: 'Houston we got a problem' So finally beat my Blitzrc SS into and unflyable state and ordered an airframe from HK, a Bixler. Unpacked it and found the back edge of the wings are warped, bent down. Should I try and fix this or send it back?
DJ
Sculptor is offline Find More Posts by Sculptor
Old Jul 14, 2012, 03:12 PM
jimbo1101 is offline
Find More Posts by jimbo1101
Joined Jun 2012
Comparable plane to bixler
That I can buy that uses the servos, battery, motor and esc, transmitter and receiver? Would like to be able to use all my spare parts from my bixler in another foam plane but one with landing gear ( don't want to put landing gear on my bixler). Any ideas? Front engine ok also. Just want to keep using the parts I have
Thanks in advance to all that reply.
Jimbo in Jacksonville Florida
jimbo1101 is offline Find More Posts by jimbo1101
Old Jul 14, 2012, 03:45 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Originally Posted by Sculptor View Post
Attachment 5008787'Houston we got a problem' So finally beat my Blitzrc SS into and unflyable state and ordered an airframe from HK, a Bixler. Unpacked it and found the back edge of the wings are warped, bent down. Should I try and fix this or send it back?
DJ
Find out if they will send you a new set of wings if you send them back the warped ones.
If they want the entire package you could either send it or try to straighten it out using warm water first.
Another option would be to just get another set of wings to go with the new airframe.
Old Jul 14, 2012, 04:02 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
DJ
DJ,
Fix is simple. Use hot (not boiling) water on the warped area and shape it flat again.
Bill
Prof100 is online now Find More Posts by Prof100
Old Jul 14, 2012, 04:12 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
I laid the wing on a flat surface and set a 3# hammer on it for 30 min. went to get my heat gun to warm it and to my amazement it was already straight. Thanks Eagle, I be happy
DJ
BTW, Shows me to NEVER EVER put a foam plane in a bind it will damn sure take a set.
Old Jul 14, 2012, 05:47 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Welcome to the Thread!!!
THIS should prove very nice for you.
AJ
ajbaker is offline Find More Posts by ajbaker
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
DJ
Just keep checking before each flight if get hot weather they may warp again
Old Jul 14, 2012, 06:44 PM
Joined Jun 2012
Thanks for the prompt reply AJ BUT
AJ
don't want a floater. Would perfer a plane with landing gear. Doesn't have to be retractable but ok if it is. Am I asking to much?
Thanks in advance
Jimbo
Old Jul 14, 2012, 08:52 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Thanks in advance
Jimbo
Just put your own LG on :P
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jul 14, 2012, 09:20 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Originally Posted by Prof100 View Post
DJ,
Bill
I'm going to do just that. For the sake of set-up can't I press it as I've got it now and lay a wet reg over it and use a heat gun? I've got a lazer thermometer to keep from cooking it.
Would that work
Thanks Bill,
DJ
Old Jul 14, 2012, 09:34 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thanks in advance
Jimbo
Duh.... You wrote that in your post and I forgot it. My bad. I apologize. I hope the next suggestion makes up for my previous blunder. My suggestion (but, no foam) is for you to buy a Slow Stick. It requires all of the stuff that you already have. Parts are readily available, too. There, I hope I got it right this time.
AJ.
P.S. It would not be right to elaborate on other planes because I am really too far Off Topic now. I hope that plane works for you.
Old Jul 14, 2012, 09:39 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thanks in advance
Jimbo
Or get the Fun Cub
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
