Old Jun 19, 2012, 10:34 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Tallyho85 View Post
I happened to write 20A instead of 18A in my conclusion, will you still give me the same answer?
Yes.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 20, 2012, 01:08 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by Sculptor View Post
The Sky sufer concept and the experience of flying it has me feeling like I made the right choice as the point of departure into flying.
20 hrs on the SS in the sim and then I took it out of the box, put it tighter and crashed it 13 times and fixed it and now I fly it any time I want.
Had my 'dream plane' bought, 60 days later, a 40" Beachcraft Staggerwing, and fell in love with the concept 'Scale Flying'.
After my training with the Sky Sufer I realized that all that I read said 'Don't go from your SS to a biplane' was correct, I finally did get it. I bought a 63" Cessna 182.
This will be my second level trainer. Then I will Fly the Beechcrart Model 17.
DJ
Which sim software did you buy for your Skysurfer. The package I got from Bananahobby did not have the SS in it. Now I can't seem to run the BlitZRc software at all because something is messed up with the graphics and I get only partial pictures. It's like the software doesn't work with my video card anymore.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 20, 2012, 01:54 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Clearview has the SS. Its cheap enough, and really not bad for a cheap sim. I used for a couple years till I got Phoenix. Still go in occasionally since Phoenix doesn't have the stryker in it.
jrjr is offline Find More Posts by jrjr
Old Jun 20, 2012, 02:17 PM
cassb is offline
Find More Posts by cassb
United States, NY, Victor
Joined Apr 2005
DJ
Sounds like a great plan, DJ. I am just about where you are now... although I have never used a sim (but I do have the sim cable on order to try it with my DX7). I have crashed the SkyS many times and it's still flying great with lots of epoxy and tape on it now.
I too am thinking of the 'next step up' for me... and my plan was actually to try a helicopter next. Maybe a fixed-pitch one to start with. The coaxial ones are too easy.
cassb is offline Find More Posts by cassb
Old Jun 20, 2012, 02:37 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Clearview has the SS in it.
DJ
Sculptor is offline Find More Posts by Sculptor
Old Jun 20, 2012, 03:08 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
helicopters are a lot of fun! The sim is a great Idea. Might I suggest; Fly the plane in the sim as if crashing it would cause you to wait a month for parts from China. Do everything you can to keep the plane from going down. Don't fly it like you stold it. Fly like it's the only plan you will ever have.
Helis are harder to fly than planes, 4 Chanel that is. I fly the Double Horse 9116 two of them
DJ
Old Jun 20, 2012, 04:00 PM
NoBama2012 is offline
Find More Posts by NoBama2012
Joined Jun 2012
from Banahobby.com
new here, been lurking for a while. Just wanted to give a quick post about my first experience buying my sky surfer from Banahobby. Service was very quick, everything delivered within 4 days of order....NICE. The "RTF" I got seems to be V4, screws for the wings but I don't know how on earth the plane would be ready in an hour, I'd say it was more of a ARF. The control horns alone took over an hour to screw into place plus the little clamps to connect the horns to the rod were about to drive me insane, but its all done, waiting for my next day off for first flight.
NoBama2012 is offline Find More Posts by NoBama2012
Old Jun 20, 2012, 04:23 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
jrjr
Thanks. I guess I can download the trial and see if it works with my 6 channel controller that came from BlitzRC
The trial software works just fine with my existing sim controller. Cool. Thanks guys.
Last edited by Eagle202; Jun 20, 2012 at 04:51 PM. Reason: added trail test results
Old Jun 20, 2012, 04:37 PM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
jrjr
This is the one I use with Clearview with Win 7. Works good.
http://www.hobbypartz.com/60p-dyu-1002.html
I do have adapter cables to use a regular transmitter too but I like this better. No batteries required in the controller with this.
Phoenix comes with a proprietary cable for use with only Phoenix. It's how they control piracy.
Old Jun 20, 2012, 04:43 PM
Richard.S is offline
Find More Posts by Richard.S
Joined May 2012
Just built my first kit plane which turned out to be a Bixler!
Added the following
6x3mm Carbon Spar for wings
30amp HK Deluxe Esc
Removed nose weights to allow the use of 2200 LiPo's
Hinges to all surfaces apart from rudder
Flaps (programmed 3 stage)
AXN Replacement 2200kv Motor
Small Parts RC Aluminium Motor Mount
3mm carbon rod to underside of fuselage
HobbyKing 10gr & Hextronix HXT900 servos
6x4 APC prop
If I'd do anything different it would be to not add flaps after I had built the plane - should have installed them on during the original build!
Richard.S is offline Find More Posts by Richard.S
Old Jun 20, 2012, 05:46 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
After my not so great flights on Saturday I decided to make some changes to my SS.
I had been using the manual's recommendation for the CG to be at 60mm. After I had made modifications to use an APC 6x4E prop and 2200mah battery. It kept nose diving no matter what I did to it.
With the help of another RC flyer we rearranged components and added some weight in the tail to balance it at a CG of 70mm. I wasn't sure what I would get but was pleasantly surprised with results.
Here is the test flight at 70mm.
Vince
SkySurfer CG 70mm flight test (3 min 54 sec)
Old Jun 20, 2012, 08:01 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
DJ
I don't have clear view, but sculptor, at least you could tell him where to find it,other then simply saying it is there.
Give the guy some heads up man.
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 20, 2012, 08:06 PM
Limited flyer
Joined Dec 2011
Never mind all of that, i am shure the first assemble for most took longer than it should have, just follow flight tips from this big giant thread{welcome to the thread by the way}, now go out and fly and have fun.
Old Jun 20, 2012, 08:18 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I found the Clear View software and down loaded the trial. It works just fine with my existing 6 channel simulator radio.
Sometimes I don't really need to have a link. I can usually find it with just a little data using the web. It is easier than most people think.
Thanks for the information.
Old Jun 20, 2012, 09:06 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Clearview as a link is about 4 post up JrJr posted it. if you fail to find it type "Clearview" into Google, it's in the first three.
If you want to use the people on this board as advisor's and fellow fliers you must not be presumptuous.
You need to change your tone if you expect much help here.
DJ
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
