Old Jun 19, 2012, 07:52 AM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
No, I slide the battery in via canopy hatch. As I posted, it is a little difficult to get the battery in and out, but that's what I did to achieve CG.
As far as flight characteristic, it is just as good as when I had the battery upfront with no camera on the nose.
Grazer is offline Find More Posts by Grazer
Old Jun 19, 2012, 07:59 AM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
My turn to ask a question.......
I need some advice from somebody that has done this please.
Building a second Bixler and wish to use a quality brushless outrunner with an aluminium motor mount.
Looking for some extra power, battery efficiency and open to using props that are 6" to 8".
If I can reduce noise from the stock ARF kit, that would be a bonus.
So, looking for proven motor, prop adaptor and prop please.
Thanks in advance.
Old Jun 19, 2012, 08:05 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I use Microdan motors with the aluminum mounts on my spare planes. My FPV plane uses a 2535kv motor 7x5 prop and my other plane uses 2505kv motor 6x4 prop just for having fun. Both motors are outrunners.
Maddmax is offline Find More Posts by Maddmax
Old Jun 19, 2012, 08:28 AM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
Thanks Maddmax. What flight times do you get with the 2535kv and 7x5. Of course I need to now with what battery too please.
Old Jun 19, 2012, 10:34 AM
Tallyho85 is offline
Find More Posts by Tallyho85
United Kingdom, London
Joined Aug 2010
Need some help from you guys regarding which ESC to use with my Bixler.
Bought a 20A from HK along with this plane and thought I'd be allright, but I was wrong. Turned out that they didn't include the connectors with ESC so I have to buy them seperately. Since I didn't want to wait another month for some connectors I reckoned that I could use the 18A ESC from my P-51D Mustang BL (ParkZone) and let it rest for a couple weeks while I give the Bixler a go with my Gopro.
But now I'm a bit worried, since I'm a total newb when it comes to the technicalities of the whole prop/esc/motor science I'm afraid that I'll torch my ESC and crash
So:
TGS Sport 6x4E Precision propeller
1300mah 3S 25~50C
18A ESC
Stock motor (2620 Brushless outrunner)
Will it work?
Tallyho85 is offline Find More Posts by Tallyho85
Last edited by Tallyho85; Jun 19, 2012 at 01:39 PM. Reason: Wrote 20A ESC instead of 18A
Old Jun 19, 2012, 12:28 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
So:
1300mah 3S 25~50C
20A ESC
Will it work?
Short answer - Yes.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 19, 2012, 01:43 PM
Joined Aug 2010
Originally Posted by ajbaker View Post
Short answer - Yes.
AJ
I happened to write 20A instead of 18A in my conclusion, will you still give me the same answer?
Old Jun 19, 2012, 02:17 PM
Maddmax is offline
Joined Jun 2011
Grazer, I use 2200mah batteries and full throttle flying yields about 10 minutes. I also use a 35amp ESC.
Old Jun 19, 2012, 05:53 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
As that is a good motor I don't think running a 2535kv with that prop is going to be any quieter and probably nosier then stock.
Something around 1100-1200kv and a 7x6 would drop the noise quite a bit, be efficient and be able to move right along just fine. Mount it in a way to use a 8 inch prop and you could try different props of 7-8 inch range to find the best for your flying style.
The new EZ Star II's powers system uses a 1100kv with a 7x6 folder.
2500GENE is offline Find More Posts by 2500GENE
Old Jun 19, 2012, 06:24 PM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
Thank you.
Thanks for the input. I think that is where I was heading. I hope to retain battery efficiency however.
Old Jun 19, 2012, 07:06 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by MonkeysPunk View Post
Can anyone help me with the best place to mount a spectrum reciver in a bixler ? I keep loosing signal with in inside but can't understand why. Even at close range it's dropping out
I use one of the Orange R610 spectrum receivers in my Skysurfer. It is Velcro to the inside wall just below the cockpit canopy. I sometimes have issues getting my 2200mah battery in and out but the Rx can easily be removed and replaced.
So far I haven't noticed any lost signal with that placement.
Did you do a range test on it?
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Jun 19, 2012, 07:21 PM
golf_lake is offline
Find More Posts by golf_lake
Australia, SA, Munno Para
Joined Sep 2011
Vince
Why not place the RX a little further back.
constantly pulling and twisting the servo wires will break them sooner or latter and it may not end well.
I have my esc and rx, one on each side just behind the opening and they are never in the way for the 2200ma battery fitting or removal
golf_lake is offline Find More Posts by golf_lake
Old Jun 19, 2012, 07:26 PM
Joined Sep 2011
If you look back a few days AJ gave a figure of 17amps for a 6x4 prop.
I assume thats static on the ground and the amps will drop as the prop is unloaded in the air.
I am using a 25amp redbrick esc
why not just order a couple of packs of connectors and wait a couple of weeks?
do you have a any friends you can borrow some from ?
Old Jun 19, 2012, 07:52 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I was thinking of moving it back behind the opening for better battery access. I tried that once but the servo wires seem to interfere with the servo linkage for the rudder and elevator. This version of the SS has the servos and control rods inside the fuse which makes it a little crowded sometimes.
Old Jun 19, 2012, 10:28 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
The Sky sufer concept and the experience of flying it has me feeling like I made the right choice as the point of departure into flying.
20 hrs on the SS in the sim and then I took it out of the box, put it tighter and crashed it 13 times and fixed it and now I fly it any time I want.
Had my 'dream plane' bought, 60 days later, a 40" Beachcraft Staggerwing, and fell in love with the concept 'Scale Flying'.
After my training with the Sky Sufer I realized that all that I read said 'Don't go from your SS to a biplane' was correct, I finally did get it. I bought a 63" Cessna 182.
This will be my second level trainer. Then I will Fly the Beechcrart Model 17.
DJ
Sculptor is offline Find More Posts by Sculptor
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
