Old Jun 18, 2012, 09:07 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
It was a bit windy this morning. There is a water taxi that runs back and forth across the river right next to where I was flying. The plane was drifting towarss them anyways so they agreed to take me out on the next crossing and retrieve it. If it wasn't for them, I'd be screwed. The plane would probably have drifted down to manhattan!!
Maddmax is offline Find More Posts by Maddmax
Old Jun 18, 2012, 09:15 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Shoot. If it got down there you could have walk across with the water being so polluted.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 18, 2012, 09:23 PM
Sculptor is online now
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by Limited flyer View Post
And also if your car/truck/ van is big enough, just glue them.
Plus what he said
And plus,plus, he's right, learn on the first, then build to fly with the second,{not build to crash}
Dud, you didn't say if you have ever flown an Rc plane. Tell us that and we can help you get started by directing you to the proper threads
Dj
Sculptor is online now Find More Posts by Sculptor
Old Jun 18, 2012, 09:25 PM
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Dj
Old Jun 18, 2012, 09:54 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Accuracy vs price
Originally Posted by Ron RC View Post
I use one of these, but only because I already had it in the tool arsenal. Works good on plastic but you have to take your time. It is tapered so you have to work up to your size slowly because one side will be a tad bigger than the other. If you have a Harbor Freight in your town your golden. My store is about 3 miles away from me.
http://www.harborfreight.com/t-handle-reamer-66936.html
Ron
I think almost everyone would prefer accuracy, though. The two reamers in Post # 15907 are vastly superior to any tapered reamer which can never be accurate.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 18, 2012, 09:59 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Dj
This is the forum i post the most on,better get your facts staight before you continue on with this line of questioning.
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 18, 2012, 10:06 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I hope you tipped them well.
AJ
Old Jun 18, 2012, 10:07 PM
Maddmax is offline
Joined Jun 2011
Case of beer!!!
Old Jun 18, 2012, 10:08 PM
Maddmax is offline
Joined Jun 2011
Does anyone have or tried mounting their batteries below the main wing? If so, what are the flight characteristics and do you have any problems with the battery in that location. Getting ready to build my next plane and am considering that location for batts.
Old Jun 19, 2012, 12:34 AM
Limited flyer
Joined Dec 2011
Ya'd make a mess out of the air flow the wing is supposed to get.
To much drag, and ya best be sure to compensate for the other side,I am sure there is a whole slew of other things i can't think of right now.
Old Jun 19, 2012, 02:52 AM
MonkeysPunk is offline
Find More Posts by MonkeysPunk
United Kingdom, Dorset
Joined Feb 2012
Can anyone help me with the best place to mount a spectrum reciver in a bixler ? I keep loosing signal with in inside but can't understand why. Even at close range it's dropping out
MonkeysPunk is offline Find More Posts by MonkeysPunk
Old Jun 19, 2012, 06:23 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
What transmitter? Some are limited range park flyer only but even those should not loose contact at close range.
I would think it is a receiver issue as you shouldn't loose signal as far as you can see. Make sure it passes the range test before flying it! You may have to send it in to Horizon Hobby for repairs.
Try binding to with another transmitter and/or bind the transmitter to another receiver for diagnosis. Could be either one.
jrjr is offline Find More Posts by jrjr
Old Jun 19, 2012, 06:42 AM
Maddmax is offline
Joined Jun 2011
What I meant was has anyone put the battery INSIDE the airplane below the wing????
Old Jun 19, 2012, 07:15 AM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
Sure I have. Why? For correct C.O.G. with my camera gear on the nose.
Just makes it a little difficult to install the battery and retrieve and locking it in with Velcro strap etc.
Grazer is offline Find More Posts by Grazer
Old Jun 19, 2012, 07:31 AM
Maddmax is offline
Joined Jun 2011
So you cut a compartment below the wing for the battery? How does it fly??
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
