United States, NY, Wappingers Falls
Joined Jun 2011
New Crash Video
Take a look at my latest video. I'll post details after we get some comments.
Plane had Dragonlink and Replay XD1080 camera on-board.
The uncontrolled loops were great...getting closer and closer to the drink. Sounds like your throttle got stuck a bit.. |
I would hope that if he still had throttle control he would have shut it down and let it level out. I think he has "stabilization" on board but if that failed or caused bad control the plane was doomed.
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Reamers - I use a standard tapered reamer without any steps and work slowly cutting and check fitting as I go. A drill can go off centre where as the reamer cuts a centred hole due to its multitude of cutting blades.
The hole will now be tapered but as long as it isn't too big (no slop), the propeller with sit flat on the hub and drive nut as they have reasonably large surfaces. If the propeller is too thin a washer might be needed. I was given a grey APC 6 x 4 and it worked well until I tried an inverted landing... Now using a black HK 6 x 4 - not sure if it gives quite as much performance but it seems to be a little quieter. 6 x 5 props with the next HK order (here soon). Wing spar replacement - 3 months of vicious flying plus the inevitable crash and it is still as good as new. Can't see any reason to change it. Servos are original too. Major change (I do keep harping on about it) nylon hinges on everything that moves. |
Yeah. If he still had control that is what it sounded like.
I have tried that before and lost to the ground every time. The best steps to take is to throttle down and let go of the sticks. If it is high enough it should level right out. Then take control back with just enough power to keep the nose up. |
Joined Jun 2011
I did try and power out of it. I lost sight of it banking right behind a try. No stabilization. I gave it throtlle and up elevator hoping it would come back above the tree line. By the time I got to the trees, I just saw the big splash!!!. Good news is the camera still works and the Dragonlink is sitting in a bowl of rice for a few days.
The plane looked unstable from the beginning. Was it wind or something else? Oh. Did you jump in and swim to it or did you use a boat? |
United States, WI, Fond du Lac
Joined Sep 2008
Tip 1. I've found it gets squirrelly at high speed and doesn't self correct. Better to power down until you regain control. Tip 2. Less aileron, more rudder for turning=smoother video. Tip 3. Soak circuit boards (Rec, ESC, etc) in "Corrosion-X" to waterproof them. Thanks for posting the video, pretty cool! |
![]() Plus what he said And plus,plus, he's right, learn on the first, then build to fly with the second,{not build to crash} |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
