Old Jun 13, 2012, 06:21 PM
golf_lake is offline
Find More Posts by golf_lake
Australia, SA, Munno Para
Joined Sep 2011
Originally Posted by cassb View Post
Everything works OK until I turn off the transmitter. When I turn it back on again, it won't reconnect to that receiver any more until I go through the bind process again.
One weird thing about the Tx ... the green light on the back where the bind button is on the DX7 -- when I turn on the Tx, that light flashes for about 3 seconds then goes off. Isn't it supposed to be on solid?
After you have bound the RX = light on solid
Turn radio and RX off, yes then both need to be turned off
remove bind plug
turn radio on
turn RX on
it should work for that
golf_lake is offline Find More Posts by golf_lake
Old Jun 13, 2012, 06:46 PM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
golf_lake,
I think his problem has been resolved, unless you are talking about something different.
Have a read back through the last dozen posts or couple of pages.
It was kinda off topic and all over the place there for a while. So I'm confused too!!
B!LL!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Jun 13, 2012, 06:57 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Well, I figured it out! The button is partially pressed when I tightened down the top two screws on the back. So, it's all good now. I loosened those two screws and we're back in business! Whew!
I had removed the back cover to check out the insides and the tension adjustments. I guess you can't tighten those two top screws all the way in or it compresses the back enough to push in that button. Lesson learned.
Thanks all,
Bryan
I've had mine apart to eliminate the ratchet on the throttle. That's a simple procedure.... take one screw out and flip the metal piece that makes the ratchet effect and put the screw back in. Now you have a nice smooth throttle stick which I prefer. I tightened the screws back up on the case and it works fine, so you may have something a bit out of alignment.
jrjr is offline Find More Posts by jrjr
Old Jun 13, 2012, 07:05 PM
Joined Sep 2011
Originally Posted by Fugitive_Bill View Post
golf_lake,
B!LL!
Thanks after looking a second time I see it was caused by not putting his TX back together correctly.
I just thought I would mention the need to turn every thing thing off after binding as I was caught by that and hadent seen anyone one else say it
Old Jun 13, 2012, 10:14 PM
cassb is offline
Find More Posts by cassb
United States, NY, Victor
Joined Apr 2005
Yes, thank you for responding. It's working correctly now.
Now, next thing I need to find is how to connect this DX7 to my computer so I can run it with a flight sim!
cassb is offline Find More Posts by cassb
Old Jun 13, 2012, 10:30 PM
Joined Sep 2011
you need a simulator cable that plugs into the buddy box hole and then plugs into your computer via USB.
if you google you will find heaps of cables available to use with free sims like FMS
Old Jun 13, 2012, 11:54 PM
Joined Sep 2011
Just wondering if anyone has checked current draw on the stock prop and the apc 6x4
I just got a set of digi scales and compared thrust between the 2 props and the 6x4 gives an extra 60g of thrust
the scales only measure down to 5g steps but still ok for comparing motors, props and batteries
3s 2200 ma pack just of charge stock prop 485gm
rest time was as long as it took to swap props and without top up apc 6x4 545gm
around 12% more thrust
Old Jun 14, 2012, 12:00 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Just wondering if anyone has checked current draw on the stock prop and the apc 6x4 <snip>
Yes.
2300mah LiPo
APC 6x4e
18.15Ap
11.27Vm
205.8Wp
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 14, 2012, 12:13 AM
Joined Sep 2011
Originally Posted by ajbaker View Post
Yes.
2300mah LiPo
APC 6x4e
18.15Ap
11.27Vm
205.8Wp
AJ
thanks AJ do you have the numbers for the stock prop as well please?
Old Jun 14, 2012, 10:34 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Yes.
1300mah LiPo
5x5e
14.38Ap
10.87Vm
157.7Wp
AJ
Old Jun 14, 2012, 05:54 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Turn radio and RX off,.... turn radio on....turn RX on
An Rx is a radio, or maybe we called them a wireless as we used the English terminology. "Its on the radio." as in there is a programme on the wireless. "I heard it on the radio." etc.
It might be better to use Tx and Rx and then we'd know that the transmitter and the receiver were being talked about.
Now, which is turned off first - Rx or Tx after binding? (Or do I have to go out to the workshop to check my notes.)
Mac50L is offline Find More Posts by Mac50L
Old Jun 14, 2012, 06:20 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
When one refers to a radio, they are referring to the Transmitter or TX. WHen they talk about the reciever, it's the RX.
But, Rx can also mean a drug store or pharmacy and Tx is the abbreviation for the State of Texas. So if you got aspirin in Dallas you could say you went shopping at a Rx in Tx.
Tnx for listening.
oh, also....I use a Hitec radio and it doesn't play any music.
2500GENE is offline Find More Posts by 2500GENE
Old Jun 14, 2012, 06:37 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Tnx for listening.
My Devo 8 does :P And here is one to add to the word riddle...
Not only do I fly with my TX controlling the RX, but my plane also has a TX communicating with an RX with me on the ground!
Oh and just because you don't see it mentioned much... I did 4.7km yesterday ground range using my Devo 8 on 2.4Ghz WITH 1.3Ghz for video and no filters :P.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jun 14, 2012, 07:13 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
4.7km....2.9 miles. Nice.
aj loves Devo. "Wip It" was his favorite.
Old Jun 14, 2012, 07:23 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Rx. But, I sure agree with all the other answers.
AJ
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
