Old Jun 12, 2012, 08:33 AM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
Originally Posted by pmullen503 View Post
More AOA would help but the wheel also looks too far forward. If you can, remount the wheel closer to the CG and lower the wheel (have more wheel protruding).
If you are flying off grass, raising the fuselage will allow it to gain speed quicker as it won't be plowing through the grass. Ideally you'd like enough ground clearance that the tail could lift off the ground and allow the elevator to rotate the plane into the correct AOA to lift smoothly off. I suspect in the current configuration it would eventually leap into the air if it was going fast enough.
it has to be able to rotate, meaning the front wheel should be bigger or placed lower, just fw of the Cof G
i did this and because the thrust angle points down the tail feathers do very little as do the ailerons ..taxiing was near impossible. and takeing off wasnt much better. it will ground loop more times than not.
wilem is offline Find More Posts by wilem
Old Jun 12, 2012, 08:37 AM
wilem is offline
wilem's Avatar
Joined Jul 2009
Originally Posted by AVIATION_RULZ View Post
Hey Everyone,
I'm wanting to modify my bixler a little bit but before I do wanted to get some feedback from you guy's in case there's something I'm missing or overlooking. Basically, I want to install 2 motors (1 on each wing) and convert my bixler from a pusher prop to a multi-motor.... kinda like the twinstar. I know rcpowers did something like this with his HawkSky but can't seem to find the video to get more details on it. I was thinking that if I have 2 motors (Turnigy 2826-2200kv), than I can also have 2 battery's in there.... one to supply each motor.
Anyways, what do you guy's think?
Thanks fellas!
two 2826s where you going to, the moon?
...should be a strong one.
Old Jun 12, 2012, 09:59 AM
cassb is offline
Find More Posts by cassb
United States, NY, Victor
Joined Apr 2005
Originally Posted by ajbaker View Post
1. Sort of. See attached. A Picture is worth.....
2. Only if the air blows the wrong way. If the wiring is correct, the air will blow rearwards whether the prop is on backwards or not.
AJ
OK thanks. So I am guessing that this non-pusher prop will need the motor to spin the other way from how it's set up. Is there a way to do this so that you can change the rotation direction in the field? Or am I looking at cutting and soldering the wires permanently?
Bryan
cassb is offline Find More Posts by cassb
Old Jun 12, 2012, 11:52 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Bryan
You should be able to reverse motor direction through the esc if you know how to program it through the radio, or your computer{don't know what kind of radio you got} . This is why i never solder my esc directly to the motor, life is a bit easier when you don't.
Try and look for programing directions for your esc, if you can't find them, their are a few people here that can help you.
Hope this info is SOME use to you.
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 12, 2012, 12:12 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
cassb,
Just wanted to add a couple further points to describe normal prop setup.
As a general rule, the numbers on the prop point to the front.
The prop spins clockwise looking from the rear.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jun 12, 2012, 01:52 PM
Limited flyer
Joined Dec 2011
Gotta a question. I have a 3 cell 3200 with 30c dis charge. i know it will it in the nose and and i find cg without a problem,BUT, is stock motor enough to haul that big batt around and if so, does it require a running hand launch.?
Have this bat from a left over project and want to use it.
I here some are using big batts, but with more motor then sock
Old Jun 12, 2012, 02:04 PM
wilem is offline
wilem's Avatar
Joined Jul 2009
i am pretty sure it will carry it with no problem.
Old Jun 12, 2012, 02:05 PM
wilem is offline
wilem's Avatar
Joined Jul 2009
Bryan
swap any two motor leads, cutting soldering is the only way. i dont think that you can do that in the radio.
Old Jun 12, 2012, 02:26 PM
Limited flyer
Joined Dec 2011
Don't think he can do what in the radio?
Old Jun 12, 2012, 02:30 PM
AVIATION_RULZ is offline
Find More Posts by AVIATION_RULZ
Canada, BC, Surrey
Joined Feb 2011
Twins are cool!
A couple suggestions: a pair of 2826's is way more power (and weight when you consider the extra battery) than you need. A pair of Turnigy 2209/28 1050kv with 9x6 or 10x5 props is what I've used in 3 twins I've built. It's a nice set up. Draws only 25A, over 50 oz combined thrust and runs well on a single 2200mAh battery. Quiet too.
Use a single battery, or a Y connector for two batteries. No reason to separate the batteries and if you do, they'll have to be perfectly matched.
I'd make the wing one piece and bolt it to the fuselage. You'll also need landing gear or prop savers.
Should be a neat project.
Thank you for the motor options and the feedback Just a quick question. How do I hook up 2 ESC's to 1 Rx? Haven't ever flown twin motors before.
AVIATION_RULZ is offline Find More Posts by AVIATION_RULZ
Old Jun 12, 2012, 03:03 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
No problem at all as long as you get the CG right.
epyonxero is offline Find More Posts by epyonxero
Old Jun 12, 2012, 03:17 PM
pmullen503 is offline
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
Use a Y connector and plug both leads from the ESC'S into it and plug the Y connector into the receiver.
You may also plug both ESC leads into separate channels at the receiver and mix the two channels in your TX (assuming you have unused channels and a TX with mix capablity).
Either way you should disconnect one of the power (red) leads from the two ESCs to the receiver so a single BEC is powering the system. Or disconnect both red leads and use a separate switching BEC to power the receiver and servos.
You can often get away with leaving both ESCs powering the receiver but it's not a good practice.
pmullen503 is offline Find More Posts by pmullen503
Old Jun 12, 2012, 03:44 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Read your posts.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 12, 2012, 03:46 PM
cassb is offline
Joined Apr 2005
Doesn't think you can reverse the motor direction via the radio programming (I just got a DX7 from rcrick in Classifieds!).
I guess I'll have to cut/swap the motor wiring then and just use a 'normal' prop on the plane from now on.
Old Jun 12, 2012, 03:57 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
You can't reverse the motor direction with any transmitter that I know of. You can reverse the motor direction with SOME ESC's (like Hacker and I sure there are others). But, generally, you have to swap two wires (as suggested by wilem). I hope that works out for you. BTW, you might want to start using 3.5mm hardware so you can swap motors around in different planes.
AJ
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
