Detachable Wings
There are inconsistent results that follow the various methods; the undocumented details make the difference.
The reason - ajbaker #2149 - works is it is UNDER the wing and uses a wide piece of VelcroŽ. This means that when the wing bends up in normal flight, the velco keeps the wings from separating. Velco on top and bottom would be better for rolls and inverted. ajbaker #2149 http://www.rcgroups.com/forums/showp...postcount=2149 The reason - kmihalkov #15630 - works is the stiff pieces on top and bottom of the wing around the CF rod and turns it into an "I-beam" with lots of support for the CF rod. kmihalkov #15630 http://www.rcgroups.com/forums/showp...ostcount=15630 The reason HobbyKing's (HK) blue velcro works better is the velcro is very stiff. In the many types of velcro I have, the "hooks" (grippy part) are always stiffer than the "loops" (passive part). This means the hooks should be the bridge part that goes between the two wings. In summery my opinion dejure (and dejour): 1) Velcro top and bottom. 2) Wide velcro or a section over the rod and another near the wing front. 3) Use stiff velcro and Bridge the wings with the stiffest part of the velcro. The servo wires need to be flush in a small cut slot to ensure they don't keep the wings from joining. The slot needs to be beside the velco so the wires don't interfere with the velcro. NOTE: Attach the wings without putting them through the body, flex them up/down/backwards and you can see the results of your design. Compare it to what you would expect if they were glued together. OWLPIC PS: All the years of "twitters" on this build-blog really makes it difficult to get the information that this blog was intended and is needed by those trying to enjoy a Bixler. At any time afterwords nonproductive comments can be replaced by the author with something of value to the hobby. |
![]() After all, the right answer is the one you choose |
Joined Feb 2012
For an autopilot you should trim the plane for level flight before activating the AP for the first time. If it doesnt have enough control authority it wont be able to make an unstable plane fly straight and if your your PIDs are wrong you could end up crashing. |
Latest blog entry: Flying in the Neighborhood
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
