Old Jun 09, 2012, 10:14 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Slide rules? You guys must be AMA members. lol
epyonxero is offline Find More Posts by epyonxero
Old Jun 09, 2012, 10:35 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Just old. But wise.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 09, 2012, 11:33 PM
Gotwings is offline
Find More Posts by Gotwings
Joined Jan 2012
Originally Posted by geotete View Post
Well I was amazed with you capacity to play Tetris! Because I also have the FY-31, also need a video TX, and have almost everything that you have but I needed a bigger pod, in layer's, for all the electronics!
How did you managed to put everything inside, with that pod? Do you have more photos with the inside layout in detail?
I'm thinking seriously about the DOSD, because it's only one unit and I can use PPM, so I will have less cables...
It's OK to have a CG in the 70mm? I'm on the 65mm but I need to had more unnecessary weight to get the plane leveled.
Geotete
First, nice setup - never seen that CF(?) rig. The use of a battery right under the canopy mount had way to much front weight on mine (i'm starting to think i may have way to much tape/fiberglass on the nose). I ran a strip of soft sided velcro down the entire bottom of the BIX interior. On the bottom of both the DOSD, battery and FY31A, I used the hard sided velcro (and to add extra cushion, I first used the sponge pads on FY31A for stability, then added velco to the bottom ). The DOSD is pushed to the front of the nose, then the FY31A... I cut a hole in the nose for the GPS and used 100mph tape to hold in place.
The battery sitting just under the back side of the VX mount pushed the CG to 55 to 59 mm... I really had to push it back to get a nominal 62 to 65 cg... (and recall, I originally had a 3s2p setup), the 2200 mAH battery was FAR in the back about 1/2 past rear edge of wing, then the 3300mAH battery just under wing with an AUW of 3.2#...).
Gotwings is offline Find More Posts by Gotwings
Old Jun 09, 2012, 11:53 PM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
Tip Stall
Originally Posted by Gotwings View Post
.... It went up and 2 seconds later, nose down. This the maiden voyage ......
These mysterious crashes are usually "tip stalls", something the Bixler is very prone to. Fly slow and turn slightly and this plane will fall out of the sky as if it had had a malfunction.
The only way to recover is to gain speed, but you need altitude for that. The best
is to accerate towards the ground and pull up at the last moment. Less nervy and equally sucessful is let go of the right stick and level out at the last moment. Practice on a simulator.
OwlPic is offline Find More Posts by OwlPic
Old Jun 09, 2012, 11:58 PM
OwlPic is offline
OwlPic's Avatar
Joined Jun 2010
Detachable Wings
Originally Posted by Limited flyer View Post
... glue in the wings to the fusalage, and to go one step furthur, as in also glue the two wing,halves together ...
The Bixler wings would get damaged trying to fit it in my sedan. Need removable wings.
We have been putting wings on for years with X-crossed rubber bands. The Bixler has some complications that need a little different solution.
Old Jun 10, 2012, 12:12 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Then check ou post 15630 from a guy called kmihalkov .
He's got a better than average solution.
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 10, 2012, 01:36 AM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
What is the difference between a conventional "tractor" prop and a pusher prop?
Scooch is offline Find More Posts by Scooch
Old Jun 10, 2012, 01:47 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
With a pusher prop, you use a tractor to plow.
With a tractor prop, you use your wife.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 10, 2012, 01:53 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Need some info
Originally Posted by ands View Post
Just for fun
If you have a thing 125mm wide and you want it 487mm wide, whats the persentage of enlargement? not to scale i might add
On my slide rule, I got 390% (i.e. 125mm * 3.9 = ~490mm). I have no idea where GENE got his numbers. On a calculator, I got 389.6%. Hmmmmm...
I tried the % of increase that 487mm is over 125mm and got 289.6% (i.e.the length that needed to be added (362+125=487) - and then 362/125).
Where do your measurements come from and what do you need the % answer for?
It is not clear (to me) what you are looking for. But, 389.6% or 289.6% is correct depending on what exactly you are asking.
Example: If you have a 10 foot board and want increase to a 40 foot board, what % do you need it increased by - 400% or 300%? Clearly, it is 4 (400%) times longer than the original board. But, the 30 feet was "added" to the board by 3 (300%) times. The difference lies in the word "added". The popular answer to your question (As is) would be 389.6%. I am pretty sure this is not too far off topic....
AJ
Old Jun 10, 2012, 02:29 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by OwlPic View Post
Having spent several hours studying the detachable wing ideas, I think I see a problem. It manifest it's self as a broken Carbon-fiber (CF) rod.
1) Velcro doesn't hold the wings in compression and allows a small gap and thus stress to form around the rod during flight.
I am the designer of the rubber band method (I know, so what....). The important thing about that is I don't use it anymore. I currently use the "NEW" velco method. The first velcro strips are attached to the wing halves. Then, a much longer strip goes THROUGH the wing saddle (on the bottom) and holds both wings together. For me, it is the next best thing to gluing in the wings. I totally agree with the "OLD" velcro method that you mentioned. With that, the velco can come loose and you would not necessarily notice it. You can see the new method in the post on Page #1 - Post #3 - Step 6. While I put the post there, I have not found out who the designer is. I hope one day he steps forward and claims credit for it. The most important thing is to use a design that WILL hold the wings together for an entire (even rough) flight (duh-put capt obvious pic here). There are several other designs that I guess work for other folks. But, I use this one 100% of the time because I have had ZERO problems with the design.
AJ
Old Jun 10, 2012, 02:42 AM
Reegor is offline
Find More Posts by Reegor
USA, CA, San Diego
Joined Apr 2007
Originally Posted by iwik View Post
Hi,
Why is it that planes always find the most destructive or in unreachable area to get into.
I was flying in a park that had a small reserve no bigger than 100metres by 30 with thickly
wooded area and i could not find it.
Mind u i have had another Bixler on order as i really love flying this and new some day would need another one.
Regards
Les
It's like the tree-magnets that many expensive planes carry. Only for FPV planes, they look for wilderness areas, then dive.
Have you tried an alarm? Attach one to an RX channel, and it will sound a loud noise if it loses signal. If you have a spare channel, you can put it on a switch on your TX. Otherwise, you can just Y-cable it onto any channel, and if you lose the plane just turn off the TX.
The noise is loud enough that you can locate the A/C from 50 feet away. Or so I've read - I've never had to use mine. They cost from $5 to $20 from various sources.
Reegor is offline Find More Posts by Reegor
Old Jun 10, 2012, 04:29 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Originally Posted by Eagle202 View Post
My slide rule is a K & E Log-Log scale type. New when I bought it in 1971. Old now. At least it doesn't run on batteries.
Oh, one of the new ones, mine is 1960. The new one is mid '60s. No batteries, no wonder I couldn't find the battery compartment lid....
Mac50L is offline Find More Posts by Mac50L
Old Jun 10, 2012, 04:39 AM
Mac50L is offline
Joined Oct 2011
Wing retention - I use a steel 2 mm wire which hooks over the 3M hooks under the wing. Its ends have a reverse curve and there is a rubber band, parallel to the wire, that goes over these to capture the wire. To remove the wings, flick the rubber band off the wire, unclick the wire from the hooks and pull the wings apart.
Props - the lad I was flying with today was offered a 6x5 by another flyer and after I reamed it out to fit he tried it. Just that little bit better than the 6x4 that I was flying with.
Old Jun 10, 2012, 07:14 AM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
AJ
389.6% Correct answer AJ.
ands is offline Find More Posts by ands
Old Jun 10, 2012, 07:18 AM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
I didn't want to "loose" space inside the fuselage, so my servos are in the tail, and because of that I have a heavier tail.
Your layout is great for everything, I really need to move the CG on mine, I don't want to add more unnecessary weight.
The 65mm is the ideal, but what are the safe margins?
NorCalMatCat, since you also are flying with the FY-31 can you share your layout, and setup?
Geotete
geotete is offline Find More Posts by geotete
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
