Old Jun 05, 2012, 04:39 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by kmihalkov View Post
Hi guys
my solution is another
It is not self evident. The last picture looks like you nailed on the wings which I don't think you are suggesting.
Prof100 is online now Find More Posts by Prof100
Old Jun 05, 2012, 04:51 PM
kmihalkov is offline
Find More Posts by kmihalkov
Germany
Joined Sep 2011
that is my mistake
The both part of the wing are not nailed. They are not permanent connected.
I use 3 mm screw with "Nylock Nuts" before flight.
kmihalkov is offline Find More Posts by kmihalkov
Old Jun 05, 2012, 05:12 PM
Prof100's Avatar
Joined Jul 2007
that is my mistake
Excellent. I like a solid mount. I used to use rubber bands but with how I fly it I simply glued in my wings.
Old Jun 05, 2012, 10:29 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Excellent suggestion, I would do it but down the road i am to order spare set of wings so a can have a clipped wing version,any suggestions on a glue that would hold, but also easy to seperate?I know the answer is in this big giant thread, but there must be one kind soul that can provide me with a suggestion or two.
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 06, 2012, 11:48 AM
Germany
Joined Sep 2011
Hi guys,
I have to much read in forums and saw very good decisions
I want to share my HK Bixler build
Motor mount:
I used PVC pipe for warm water and aluminum sheet.
Old Jun 06, 2012, 12:15 PM
Prof100's Avatar
Joined Jul 2007
WOW, what a superb build and fine craftsmanship. I think your approach will get a link in the front of the thread. (Right AJ?)
Make sure you Check the CG because that's a lot of extra weight on the tail.
Old Jun 06, 2012, 12:27 PM
Germany
Joined Sep 2011
thanks Prof100
I can upload much different photos
b.t.w CG is 66 mm but ... with 2 x 3S 2200 mAh
but without any camera, stabilization, OSD ....
Old Jun 06, 2012, 12:42 PM
Limited flyer
Joined Dec 2011
You really went all out, feel proud, take a bow.
Prof, you glue your wings in, is it permenent,or can they be taken off for maitence, and if so what glue do you use.
Thanks in advance.
Old Jun 06, 2012, 01:00 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
thanks Prof100
I do like the build and the photos. Nice job.
I even see an arming switch which is used almost exclusively with Nitro Fuel planes. While I do like the idea of turning off the ESC with this switch I would still want to disengage the battery. Maybe a plug on the outside that breaks the battery lead circuit.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 06, 2012, 01:02 PM
Germany
Joined Sep 2011
Wing Part
I add additional carbon tube 6 mm. I used "Dremel" to make the additional slit.
For the Wings-spar I used 8 mm carbon tube.
In this tube I glued 3 x 3 mm carbon tubes
Attention !!! - they are glued only from one side. For the another side from the 8 mm tube I used only PVC Stopper (tube).
So the wings spar is stable by twist.
Old Jun 06, 2012, 01:10 PM
Prof100's Avatar
Joined Jul 2007
Thanks in advance.
No epoxy or CA was used. As I recall, I think I used Foam Tac or simply hot glue so a long bladed knife can cut through the glue. I glued them in over a year ago.
Old Jun 06, 2012, 01:11 PM
Limited flyer
Joined Dec 2011
Not that i don't mind watching your build process,{nice job by the way}what is your end game? F.P.V. ship?
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
