Old Jun 04, 2012, 05:08 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Originally Posted by ajbaker View Post
I agree. His posts contribute absolutely NOTHING. Newbies always try to showcase their lack of experience or knowledge. I haven't blocked anyone from this thread yet. Maybe I need to start with him.
AJ
Agree, but don't block. Just don't bite. Personally speaking, you have been a great help and I like the flow of the chat on here.
Some ideas are great, some I think Mmmm; not so sure, but that's for me to decide.
Keep up the good work... don't bite.
ands
ands is offline Find More Posts by ands
Old Jun 04, 2012, 05:18 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
question
Originally Posted by G550Ted View Post
With aj's conclusion that what he needs is "an external sBEC to circumvent his heat problem."
I DO agree with your statement that it should not toast his ESC.
There should never be an issue of two different 30a ESCs getting "smoking hot" running a stock motor in this model. Something else is going on and I seriously doubt it has anything to do with the BEC portion of those ESCs. 30a ESCs most always have a BEC of at least 2a and often 3a rating/capability which won't overheat with 4 servos even on a 4 cell battery unless at least a couple of the servos are stalled. If all of the controls are working OK then all of the discussions to date are not applicable and using an external BEC (or UBEC or whatever one wants to call it) will not be a cure to his problem.
As NorCalMatCat pointed out, at max power the stock motor draw is about 17 amps. Even on the bench for a couple of minutes I would not expect a capable 30a ESC to overheat. First thing to do is to check the load with a watt meter. Also feel the motor and bullet connectors to see if any or all are getting hot. Does the motor make any strange sounds? What size prop are you running? Does he have another model that he could test his ESC with? Maybe he really is just unlucky and got two bad ESCs.
Bottom line is he needs to do more troubleshooting, and if he can't isolate the problem let us or others know of all the particulars to see if we can offer a possible solution. A UBEC is most likely way down the list as a cure.
Ted
For the most part, I agree. Let me back up to the obvious. If he has a brand new plane and did not exercise the control surfaces, that could be the most likely cause of his heat problem. Since he does not have a watt meter, I was taking my best guess. Since I read your post, it got me thinking about the control surfaces thing. But, to be the most help to him, what else would you suggest that he check? (keeping in mind that he does not have some of the tools that you and I take for granted).
AJ
P.S. For you only, what do you think would happen if it is a control surface problem and he used an external sBEC? Would the ESC or sBEC still get hot? I do not know the answer to this hypothetical situation. I have never tested that thought before.
P.S.S. For the rest - I promise I will get back on topic.
ajbaker is offline Find More Posts by ajbaker
Old Jun 04, 2012, 05:38 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I recommend to anyone that does not have one, go get a Multimeter right now :P You can get one from Harbor Freight for Free to $6 (They often give away with coupons their cheap $5 one), I use it and it works fine, though it only handles up to 10A for amperage reading, but it is invaluable for testing stuff, if you have the money to invest I would get a model in the $20 to $50 range that IS capable of testing higher amps, and in this hobby it is a tool you will find quite valuable, and useful for other things too .
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jun 04, 2012, 06:00 PM View Post
G550Ted
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior). It is temporarily hidden while G550Ted edits it. Show it to me anyway.
Old Jun 04, 2012, 06:07 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
AJ
To be honest I suggested all of the issues that I could think of that might cause his problem. Without more data I don't know. That would include him powering the model and not running the motor to see if multiple stalled servos might be the cause, but I think that quite unlikely. Then again, like you, I've never tested that situation.
Ted
PS - It's not so hard for either of us to banter a point if we stick to the issue, and I mean that in an honest way.
G550Ted is offline Find More Posts by G550Ted
Old Jun 04, 2012, 06:08 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Sea Gull posting
OBTW. Don't bother to waste your time composing another snarky, threatening PM to me because it doesn't work on adults.
Your friend,
Ted
As usual, you newbies always resort to personal attacks. I actually feel sorry for you.
AJ
Old Jun 04, 2012, 06:19 PM
G550Ted is offline
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
AJ
Ahh... "Newbies", post count, "silliness", "Note that the post was made by the administrator." (meaning you), etc., ad infinitum.
'Nuff said.
Old Jun 04, 2012, 06:21 PM
Joined Oct 2011
Actually someone kindly pointed out to me the meter I mentioned above can do up to 10A DC, but you have to be careful with multimeters and amps because if you go over the spec it's easy to let the magic smoke out of one :P.
Old Jun 04, 2012, 06:33 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
+1. You are right on. My son blew one up by putting it on 10A and then putting the leads across 12v DC on his motorcycle. FWIW - There is a fuse inside. But, I know what it is supposed to protect. My son's meter was "smoked" out. I can only imagine what a high power LiPo would do to it. Good note on using caution.
AJ
Old Jun 04, 2012, 06:38 PM
Scooch is offline
Find More Posts by Scooch
Scooch's Avatar
United States, NJ, Jackson
Joined Nov 2011
Just to add some info. It is the stock setup, engine, prop all stock. The ESC did start to get hot while on the bench. I was not moving any control surfaces while running the motor. I'm not sure why you would want to continually do that anyway. I don't think it is a control surface issue. The ESC was out of the plane at the time. After running it, I did feel the motor and found it to be hot as well. I pulled the fuse apart earlier and checked to make sure that the motor was not rubbing on the foam. It's all clear.
Scooch is offline Find More Posts by Scooch
Old Jun 04, 2012, 06:40 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Most have a replaceable 10amp fuse inside. Install a higher amp fuse and then the smoke will come out if over amped.
Now I need a beer.
2500GENE is offline Find More Posts by 2500GENE
Old Jun 04, 2012, 06:43 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
You need to check you motors amp draw with a watt meter. If you don't have one then just replace the motor. That would be the cheapest way out.
Old Jun 04, 2012, 06:44 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Ha.... The big guy in the video is your son. Right?
AJ
uh..., no.
Old Jun 04, 2012, 07:48 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Actually most of those cheap digital meters have very limited ranges and can be overloaded. The really cheap ones do not have any fuse protection.
The best way to tell if you have a good or cheap meter is to check what the CAT rating is. A really good meter has a CAT III at 600V. A lesser meter has a CAT II at 600V but may have a CAT III at 200V. The really cheap units won't say what their CAT rating is. They are the ones that will easily smoke or worse electrocute you if you try to measure anything above 50V.
The best way to measure amperage is to use a clamp on meter. Some of the cheaper clamp-ons only measure AC amps. You usually have to spend more get one that has DC capability.
When it comes to electricity you have to decide which is more important; your life or saving a few bucks.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 04, 2012, 07:57 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I do not think the SS stalls easily, it can stall but it's not like stalling a P51 :P
I agree that a P51 or for that matter just about any of the old war birds will easily stall.
I can testify that the SS can and does stall even with the wing dihedral. It will also recover from a stall better than most planes. You just have to learn to override your internal desire to power out of the dive and just let the plane's natural gliding ability to do the work.
It took me at least 2 OS stalls crashes to learn not to panic.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
