Old Jun 02, 2012, 06:32 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by fabric8 View Post
I took a trip to the local dollar store with the intent to pickup some plastic tablespoons or measuring cups to use as air scoops to cool my ESC. Then I stumbled on a wine pourer + cap. The cap, if cut in half, would be perfect
I decided to mount them by the servo openings, since there are already holes there. I have my ESC mounted right behind one servo, so it gets air from both openings
I had those in my dad's bixler, but his ESC was still warm after flight, so I picked up some aluminum heatsinks at the local electronic used parts store for under $0.95. I cut out the heat shrink and removed the stock aluminum plate. There's some rubbery layer between the aluminum plate and the chips which I believe helps conduct heat to it. So I reused it with the heatsink cut down to to fit right over the chips. Finally, I used some tiny rubberbands to help hold it in place
After my flights today, my ESC was cool to the touch. Will report back after I fly a full pack.
A warm esc is normal. If sized properly the heat is coming from it being a linear bec which uses a resistor to drop voltage for the RX and servos.. A switching bec esc will be cooler.
Also installing a heatsink is usless if you leave the plastic in between it and the esc. It needs to be mounted directly on the esc's metal to transfer the heat to the cooling air.. EDIT: after looking again I see you cut the plastic back....eyes getting old. My bad.
I like the air scoops. Did you drink the wine before or after the install?
2500GENE is offline Find More Posts by 2500GENE
Old Jun 02, 2012, 07:59 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
You don't think he'll admit it if he did, would you:}
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 03, 2012, 02:41 AM
golf_lake is offline
Find More Posts by golf_lake
Australia, SA, Munno Para
Joined Sep 2011
I have lost the screws that hold the motor in, yer I know slack as.
Can anyone tell me the length and size of the stock motor screws please
Yes I will lock tight them this time
golf_lake is offline Find More Posts by golf_lake
Old Jun 03, 2012, 03:34 PM
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
Flew the Bixler again today with no wind. I had to add a washer to the nose even with my 2200mah 3s lipo up at the nose. So I think the CG is not at the spar where I had read somewhere that said it was. But with the washer, the plane had a perfect glide angle.
So my question now is with powered flight. At half throttle, the plane flies nice and level. But at 3/4th to full throttle, the plane climbs on its own at about 45 degrees.
Do I need to tilt the motor downward to correct this?
fabric8 is offline Find More Posts by fabric8
Old Jun 03, 2012, 03:46 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
That would make it worse. Assuming the airframe is proper then decreasing the angle of the motor would help keep the nose down under power.
Old Jun 03, 2012, 04:13 PM
fabric8 is offline
Joined Sep 2011
By "decreasing the angle", do you mean I should angle the motor toward being parallel with the fuselage?
Meaning, when viewing it from the back of the plane, angle the motor so the tip of the spinner goes downward?
Old Jun 03, 2012, 04:15 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Now that you have a chance, why not convert over to a PCV mount? Use a 1 1/4 to 1 inch PCV bushing (adapter) with a X mount. You can find the bushing at any hardware store that sells PCV water pipe.
Old Jun 03, 2012, 05:44 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
The PCV bushing is just too easy of a upgrade. However, SOTOG's CNC mount is even easier.
Prof100 is offline Find More Posts by Prof100
Old Jun 03, 2012, 06:46 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Yes, little at a time until it acts the way you want it to.
Old Jun 03, 2012, 06:51 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Why waste perfectly good beer money on something you can make yourself for less then a buck?
Old Jun 03, 2012, 07:17 PM
fabric8 is offline
Joined Sep 2011
Perfect. Thanks for the confirmation. Will try that and report back.
Old Jun 03, 2012, 07:53 PM
bigdogg1 is offline
Find More Posts by bigdogg1
United States, IL, Kankakee
Joined Jan 2011
Sky Surfer - ESC Question
Could anyone give me an approximate idea what the amp draw would be with a stock motor and ESC. I am planning on using an APC 6x4 Prop. Will the stock parts handle the prop ugrade? Part 2, Has anyone used a digital meter as a watt meter as described somewhere within this site as a $3.00 watt meter. is it safe and or accurate ?
bigdogg1 is offline Find More Posts by bigdogg1
Old Jun 03, 2012, 08:05 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I used the next size up from that one. 1 1/2 to 1 1/4. Then, yesterday, I finally tried the one above. I avoided trying it because I did not want to do all that grinding with my dremel and a drum sander. Well, as you know, it only takes about 5 mins. (or less with experience) to make it the right size to clear outrunners and about 1mm or air clearance. So, I am a convert now. I threw away the other two adapters that I used before (1 1/2 to 1 1/4). I should have followed your advice a long time ago. Ah well, better late..........
You know, I don't ever remember you posting a video showing YOU flying. I am not sure that you even know how to fly (airplanes - not bricks). Got any proof? huh? huh? huh?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 03, 2012, 08:13 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Harbor Freight meter
Originally Posted by bigdogg1 View Post
1. Could anyone give me an approximate idea what the amp draw would be with a stock motor and ESC.
2. I am planning on using an APC 6x4 Prop. Will the stock parts handle the prop ugrade? Part 2,
3. Has anyone used a digital meter as a watt meter as described somewhere within this site as a $3.00 watt meter?
4. is it safe
5. and or accurate ?
1. Here are the #'s with an APC 6x4 and using the stock 1300mah LiPo:
17.18Ap
10.56Vm
186.5Wp
2. Yes. Easily.
3. Yes. I have 4 of those meters. They are routinely $3.99 on-sale.
4. Yes.
5. Yes. I checked it with another DVM and it is perfect.
AJ
Old Jun 03, 2012, 08:14 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
AJ
I've seen the ones where Gene terrorizes his dogs with that RC truck.
Where can I get a cross piece that fits the stock motor? I'm not sure of the exact size and screw hole alignment.
Vince
Eagle202 is offline Find More Posts by Eagle202
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
