Old Jun 01, 2012, 12:27 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Can someone tell me wich propeller i can use with stock configuration on a bixler for better performance? and will this fit to it? http://www.hobbyking.com/hobbyking/s...idproduct=7634
timtimtim is offline Find More Posts by timtimtim
Old Jun 01, 2012, 01:05 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
That link takes you to a 4000mah battery on Hobby Kings website not a propeller.
Eagle202 is offline Find More Posts by Eagle202
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
a 4000mah battery would not make a good propeller....
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jun 01, 2012, 02:10 PM
Joined Apr 2012
Oh damm, so it cant fly if i mount that big pack like a propeller Bad URL but is that a Nice pack for the bixler, And Will it fit in the fuselage? Can you give me a link to a good prop that works with stock propmount?
Old Jun 01, 2012, 02:24 PM
Joined Oct 2011
I don't think you would have a problem getting it in there, though it is 300 grams, which I have flown with 300g of batteries before (2200 + 1300).
Old Jun 01, 2012, 02:48 PM
Joined Apr 2012
Ok what battery are you using? And How about the prop?
Old Jun 01, 2012, 03:07 PM
Joined Oct 2011
I am using Zippy Compact 2700mah 3s (it's kind of long and thin), and weighs in at 200 grams, then I use a 500mah for my FPV gear which weighs in at roughly 50g.
Old Jun 01, 2012, 03:22 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
T3,
6x4e has been found to be best. Check Post 3, #15. Doesn't have to be a TGS brand.
HTH,
Ted
G550Ted is offline Find More Posts by G550Ted
Old Jun 01, 2012, 04:56 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Guys, if I go down in the drink (see att) will she float and can I power her back for collection and will the swans eat her?
Want to do a low fly over water with cam but it will be my first attempt...
ands is offline Find More Posts by ands
Old Jun 01, 2012, 05:39 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
She will float. Then the gators will attack and chomp the wings off.
It's a good idea to have a plan to get it back in as in a boat or fishing pole you could cast out and hook it with. Even a trained beaver would work but don't count on an aardvark as they lie and don't swim as well as they claim to.
2500GENE is offline Find More Posts by 2500GENE
Old Jun 01, 2012, 06:25 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
6x4 is the most popular.
I like to fly lightweight. So, I use the stock 1300mah LiPo and a gyro. As far as a prop is concerned, please stick with the recommended 6x4 TGS (or APC) props. There are too many cheapo props that will put you in extreme danger if you use them (i.e. even though the GWS orange prop is readily available, it WILL throw blades at the rpms the stock motor delivers). For your own safety, stick with the recommended props. That is why they are named by brand.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Jun 01, 2012, 07:49 PM
G550Ted is offline
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
AJ
Well, that's why they are designated as 6x4e for high RPM applications and not DD or HD, etc. Again, 6x4e (or 6x4E if you will), brand doesn't matter.
Ted
Old Jun 01, 2012, 07:52 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
I have used APC exclusively untill I lost my second bix for good{99% sure the custodian kept it}, but when i put togeather the third one, i could not find an APC replacement, so i found a park zone 6x4 and works every bit as good, not saying APC is a bad choice, but they are equal in performance.
First bix i trashed finding out the hard way what it could NOT do.:-].
Limited flyer is offline Find More Posts by Limited flyer
Old Jun 01, 2012, 08:55 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
If she lands up-rite without getting the electronics wet you will still have a hard time powering it back to land with out a way to steer. More than likely she will just go around in circles.
As for the swans eating a foamee!!! Maybe if they are related to goats. Although they may peck at it if they feel it has intruded into their habitat.
If you live down in Florida like Gene and I do then Gators are a real possibility.
Old Jun 01, 2012, 09:12 PM
Joined Oct 2011
A gator ate my plane! ROFL
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
