Old May 30, 2012, 08:18 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by Prof100 View Post
No offset required. Both of my Skysurfers have the motor on fuselage centerline and they fly fine. I suspect a warped wing is causing people to counter the flying problems associated with such problems by putting in a some side thrust.
Straight on center is my recommendation.
Thx this is how I have it but it flies like crap, suspect warp fuse and wing after crash.
nakelp86 is offline Find More Posts by nakelp86
Old May 30, 2012, 09:37 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Check your decals too. If they lose adhesion to the wing they can lift and act as control surface modifiers. AJ Baker discovered the problem.
Prof100 is offline Find More Posts by Prof100
Old May 30, 2012, 09:53 AM
elcid79 is offline
Find More Posts by elcid79
elcid79's Avatar
Joined Apr 2012
The channel that mine sits in is slightly offset also. It looks 100% intentional.... But I could be wrong...
elcid79 is offline Find More Posts by elcid79
Old May 30, 2012, 11:00 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Gyro Classes for anyone interested in learning how to use them on airplanes
Originally Posted by CPMBOY View Post
thx prof & AJ for the gyros infos....I have three heli gyros...GY520/spartan (used)/GP780 and 3 helis....1 active/1 upgrading/1 still in the box.....so no worries here, Im already familiar with the HH and Rate mode. Maybe, I just opt for cheap but decent gyro out there....
1. Any recos guys?....and
2. What (the most) control surfaces (ail/rud/ele) that u guys put a gyro to?
You are welcome. That Prof100 guy is always one upping me So, I am gonna one up him this time. Here is the thread all about gyros that was started by the guy (Melnic) that Prof100 mentioned.
The one up is the video class that you might be interested in that is given by another pretty knowledgeable guy (RC Powers). Enjoy....
BTW- If the old man one ups me again, I am sending 2500GENE over to his house to reverse the direction on all his gyros. That'll learn 'em.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 30, 2012, 11:08 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
more about SkyS motor offset
It is intentional. That is the way it is made. What Prof100 and I are saying is that it is OK (preferred by me/us?) to have the motor go straight back with no offset. All three of my SkyS's had a slight CCW offset (when viewed from the top of the plane). The one with the stock motor is still offset and flies the same as the two with no offset. At least, for me, I can see no difference at all. Of course, since we are dealing with aerodynamics, any difference in the motor offset has to make some difference. I am just saying that I cannot detect any difference. So, in summary, offset(tiny)/no offset - choose one. IMO, neither one is wrong.
AJ
Old May 30, 2012, 02:50 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
They all look ok. made couple flights today and all of a sudden plane flew pretty well LOL
Vid coming soon :-)
Old May 30, 2012, 04:13 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Or one could take the crappy decals off and lay down some paint., just sayin
Limited flyer is offline Find More Posts by Limited flyer
Old May 30, 2012, 04:16 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I achieved a nearly 2 mile glide today with only 120 meter altitude loss
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 30, 2012, 04:49 PM
Limited flyer
Joined Dec 2011
Thermals and wind were in your favour.
Old May 30, 2012, 05:27 PM
Joined Oct 2011
Yeah there was some thermals going on for sure, I broke my personal ground record while flying FPV and made it to 3km before my video started getting unusable (happened FAST too :P), so I turned on RTH, cut throttle and turned around, I was at 500 meters when I turned, and was at 380 meters when I got back close to myself . I did notice some thermals in the flight, for a good 1/2km I didn't even lose any altitude, actually gained a few meters.
I am still learning to ride these thermals too, every time I try to keep the lift going it seems like I lose it :P.
Old May 30, 2012, 08:03 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
Hello, what is the proper name for the little brass pieces that go between your control wires and the horns? I want to buy a replacement and I can't find the right term for them. Thanks.
dsmack is offline
Find More Posts by dsmack
Old Retired Guy
United States, WA, Spokane
Joined Feb 2012
Originally Posted by yannc View Post
Completely. My worst landing ever. I should just have gone full power when I saw the plane was not going down and I was going to overshoot.
Yep, going around is sometimes your best bet! You do have a beautiful place to fly there.
May I ask the general location?
Don
dsmack is offline Find More Posts by dsmack
Old May 30, 2012, 08:13 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
are they linkage stoppers?
Old May 30, 2012, 08:51 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Linkage Stopper HK Part No. OR016-00601
That's what I've used.
Make sure the nut holding it doesn't stop the whole thing turning. If it has to be loosened to do that then put Loctite on the thread or a dab of contact adhesive (ADOS F2).
If the linkage stopper doesn't turn as the surface being moved moves, then it will bind and tend to reduce the amount of surface (elevator, rudder) movement you can get.
Mac50L is offline Find More Posts by Mac50L
Old May 30, 2012, 11:48 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Well here is the video from this morning, I guess got to be rain cause plane flew like a dream LOL
Rain (5 min 10 sec)
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
