Old May 25, 2012, 04:17 PM
elcid79 is offline
Find More Posts by elcid79
elcid79's Avatar
Joined Apr 2012
So my room mate crashed the crap out of my sky surfer today from toysonics.
The fuse. is hosed, as are the control arms. He broke an aileron off, and did some other minor damage to the canopy etc. The question is.
Banana hobby seems to cary replacement fuselages. They are only about 20 bucks.
If I can successfully detach the vert and horiz. stab, would that work with the parts I already have. Or am I hosed and need to buy a new plane. <He is footing the bill, but I don't want to make him pay any more than necessary.> Thanks!
elcid79 is offline Find More Posts by elcid79
Old May 25, 2012, 05:04 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Broke my Bix today, too. Spar snapped in a high g pursuit turn after a bandit (crow) but the wing stayed on and I was able to land OK. Looked (and flew) a bit funny with the one wing having about 30* dihedral!
Since I have the wings securely glued on as a result of a previous spar failure and subsequent repair and reinforcement I'm not sure if I will try to repair it again. Methinks a new airframe is in order.
Ted
G550Ted is offline Find More Posts by G550Ted
Old May 25, 2012, 05:11 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
A few people sell fuses, though I would make sure the one you get from someone is compatible (differences between versions). Honestly I would buy a kit if possible to have replacement parts for the next break :P.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 25, 2012, 08:38 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
You can try to patch it back together but without and pictures I could be making a big assumption. You may have a bigger mess than can be repaired.
Instead of just the fuse go get a complete new kit with all of the body parts. That way you know it will all go together properly. You can also make some upgrade modifications that might make it better than the old one
Don't throw anything away. You can use the tail and elevator to make a stick type plane without a fuse that will fly pretty good.
Eagle202 is offline Find More Posts by Eagle202
Old May 25, 2012, 08:40 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Ted
Ouch!!. Was it a stock spar or was it reinforced with a second one inserted into the stock one?
Maybe you should stop chasing those crows. Looks like he won that battle.
Old May 26, 2012, 12:31 AM
mozzartusm is offline
Find More Posts by mozzartusm
Joined May 2011
Originally Posted by yannc View Post
So, I had a bad crash today. I was doing an aerial video of the place I work and my landing area was smaller than usual. Anyway, I hit a tree and broke a wing....
http://www.flickr.com/photos/4542420...in/photostream
Is this fixeable? Which glue should I use? I have foam glue and hot glue.
Can the wings of the Skysurfer be bought on their own?
http://www.readymaderc.com/store/ind...roducts_id=739
mozzartusm is offline Find More Posts by mozzartusm
Old May 26, 2012, 12:51 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Originally Posted by mozzartusm View Post
Thanks for that linky link,now for some reason i want to fly with reckless abandonment
Limited flyer is offline Find More Posts by Limited flyer
Old May 26, 2012, 01:08 AM
Joined May 2011
The customer service is very good. He ships very fast and stands behind his products.
Old May 26, 2012, 01:13 AM
Joined May 2011
http://www.readymaderc.com/store/ind...ex&cPath=53_92
Old May 26, 2012, 07:42 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I wish there was more detail specs on the brushless motor for the skysurfer. I still don't know the specifics on wattage or amps.
I just picked up an inrunner 2835 2200kv 640w brushless motor for $14 that AJ recommends. That and an inexpensive 30A ESC will be a nice upgrade for my SS.
Old May 26, 2012, 08:10 AM
G550Ted is offline
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Reinforced.
Ted
Old May 26, 2012, 11:05 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Reinforced.
Ted
Wow. Maybe you should use a steel bar instead of a carbon tube.
Old May 26, 2012, 03:29 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
This is generally done for better wind penetration (and fighting off crows)
jrjr is offline Find More Posts by jrjr
Old May 26, 2012, 03:41 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Need to cover the darn thing in Kevlar and add flares to confuse the crows.
Or just stay away from the birds and just fly in the other direction.
Old May 26, 2012, 04:47 PM
Joined Oct 2011
Hrm, RC Flair system is an interesting concept...
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
