Old May 20, 2012, 08:12 PM
mozzartusm is offline
Find More Posts by mozzartusm
Joined May 2011
I have read that 2200 mah is a good size battery for this plane but can I go bigger than that and if I can How much? I don't do fpv so there is no equipment on the plane.
mozzartusm is offline Find More Posts by mozzartusm
Old May 20, 2012, 08:37 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
It's a matter of weight and size, my 2700mah zippy compact is very skinny, though wider and longer then a normal 2700mah battery. It's total weight is 250 grams, considering I have a lot of extra weight with FPV equipment a stock bix could probably carry 2x2700mah without much problem, any more then that is going to have size issues with fitting it in and CG issues.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 20, 2012, 09:06 PM
gatorlynch is offline
Find More Posts by gatorlynch
gatorlynch's Avatar
United States, FL, Sarasota
Joined Mar 2010
Clipped Wing Bixler on 4S
Trying out my 28mm inrunner on 4S. I think I got a bit carried away on the full throttle runs. It was sooo much fun - while it lasted.
I'll be replacing the motor with a power up 400 zoom 2200 kv outrunner -
http://www.headsuprc.com/servlet/the...00-Zoom/Detail
Clipped Wing Bixler on 4S (1 min 28 sec)
gatorlynch is offline Find More Posts by gatorlynch
Old May 20, 2012, 09:09 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by Virginia Jim View Post
Guys:
I have attached one of those voltage detector/alarms from HK to my Sky Surfer, that beeps whenever the average voltage of each cell drops below 3.4v (actually 3.4 x 3 = 10.2v).
http://www.hobbyking.com/hobbyking/s...Detector_.html
according to the spec sheet:
http://www.hobbyking.com/hobbyking/s...7X151250X0.jpg
Unfortunately the ESC on my SS seems to be cutting off the motor before this alarm is activated.
Thus I need to set the ESC cutoff for a lower voltage, but I have never found any instructions for programming the stock ESC. I wrote Tim at ReadyMadeRC for this information, but since he has not yet gotten back to me, I assume retrieving this information is taking some time.
Does anyone on this thread have programming instructions for the SS stock ESC?
Thanks.
VJ
I am curious also about programming instructions for my SS ESC. I have a Version 2. I would presume they do not supply the same ESC across the versions so each may be different.
AJ
Any idea how to find out about programming the stock ESC?
Eagle202 is offline Find More Posts by Eagle202
Old May 21, 2012, 01:45 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Jim, before you change the ESC setting you might want to think about a couple of things.
1) Is your HK cell alarm accurate? Worth checking with a decent voltmeter as many of the cheap ones aren't.
2) 3.4 Volts/cell under load is low for modern LiPos. Particularly if you are drawing modest currents from the battery, it wil be almost exhausted by the time it reaches that voltage under load. Maybe the ESC is being sensible and turning off the motor with a decent reserve.
John
Guys:
Thanks.
VJ
jj604 is online now Find More Posts by jj604
Old May 21, 2012, 02:40 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ
Nope. No idea at all. I know that the Turnigy programming card does NOT work.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 21, 2012, 04:31 AM
asaak is offline
Find More Posts by asaak
asaak's Avatar
Joined Mar 2012
small
Hi guys,
I want to glue the small part cnc motor mount for my bixler. http://smallpartscnc.com/index.php?r...&product_id=50
I want to glue it ( only to one half of the fuselage ) with CA + activator. Am I doing it right? Do you guys think it is better to do it wit a polyurethane glue instead? It can't be gorilla glue because I am not from EEUU but I can buy another brand here in my country.
Thanks guys!
asaak is offline Find More Posts by asaak
Old May 21, 2012, 04:34 AM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
I would use 20min epoxy. That way you can make sure it is positioned right too.
Grazer is offline Find More Posts by Grazer
Old May 21, 2012, 06:48 AM
asaak is offline
asaak's Avatar
Joined Mar 2012
why is it then that I read somewhere that epoxy won't be an option for bixler? is it going to melt the foam?
Old May 21, 2012, 07:50 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
gatorlynch,
I'll be replacing the motor with a power up 400 zoom 2200 kv outrunner.
That motor's not rated 4s. You gonna chance another one?
Or do you know someone's running it 4s?
IFlyRCs is offline Find More Posts by IFlyRCs
Old May 21, 2012, 08:20 AM
gatorlynch's Avatar
Joined Mar 2010
No, I'm going to run it on 3S. The previous owner had this motor in it, and the higher kv (2200 vs my inrunner @ 2000) should provide enough of a speed bump to keep me happy.
I learned my lesson - my left thumb has very poor impulse control. BAD THUMB!!!
Thanks for the heads up (no pun intended), though.
Old May 21, 2012, 09:33 AM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
Originally Posted by asaak View Post
Hi guys,
Thanks guys!
Well, I tried Gorilla Glue, CA, and hot glue after 2 flights or so, with my BC-3536-5, the glue as loose again, so my salvation was 15 minutes epoxy.
All the best,
Geotete
geotete is offline Find More Posts by geotete
Old May 21, 2012, 09:56 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
AJ
Thanks. At least you saved me a few steps since I own one of them.
I have never purchased an ESC before that did not come with a plane. Do the manufacturers provide info as to which card could be used with the ESC being purchased?
Old May 21, 2012, 10:18 AM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Sometimes, yes. But they almost always come with printed instructions for stick programming. Or where to find a PDF online. Or not. LOL. Sometimes you have to go looking...
shunyata is offline Find More Posts by shunyata
Old May 21, 2012, 12:10 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
+1. I could not have said it better. Well done.
AJ
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
